Trim - plastic inlay
Hi all,
I have decided that I will repair / improve the trim on my truck. I have the chrome trim about 2 1/2" wide, with a 2" black plastic inlay. I have three pieces that have seperated and fell off (taken off to prevent eventual loss). I would like to stick these pieces back into place and for them to stay "stuck on".
Have any of you repaired your trim this way, if so what adhesive did you use. I have used contact cement in the past, but it didn't last too long (on another vehicle). I need something that will perform well at low temperatures - I have just moved to central northern BC and it gets a wee bit chilly in the winter and I really would like the plastic to stay stuck to the trim metal backing.
Any pointers from you good folks would be greatly appreciated.
TIA
John
1st Truck : It is used daily, 1986 F250 S/C, LB, 4x4, 6.9l diesel, after market turbo, C-6 auto, LS rear axles, 320,000km, original owner.
2nd Truck: used almost daily 2002 Dodge 3500 Turbocharged Cummins, auto, dually,
