Truck pulls - Diesel Forum - TheDieselStop.com
Old 11-23-2005, 06:07 PM   #1 (permalink)
Truck pulls
Has anyone ever entered their truck in the truck pulls? I considered doing it over the summer but wasn't sure if I should with an automatic tranny. Good idea or bad idea? You don't see a whole lot of diesels, especially old ones at the pulls. I'd be kind of curious to see how the old truck would do. Any tips from those who have pulled?
Trevor in MO
85 F250 extended cab 2WD, 6.9, C6, 4.10, no soup bowl, "ram-air", Pioneer CD player, 4 Bose Speakers from an H2 Hummer, Polished Aluminum Outlaw wheels
redbeard85 is offline
Old 11-23-2005, 07:18 PM   #2 (permalink)
My Photos: (14)
Re: Truck pulls
[img]/ubbthreads/images/graemlins/smile.gif[/img] Not to make anyone mad, but if you pull against a pretty much bone stock Cummins, you will lose unless you have some serious modifications. I would also assume a good Powerstroke serious competition. At our local pull, we have several guys show up with NA 6.9's and just can't even begin to compete. There is one guy there that has a 1 ton dually Cummins, he full pulls in the dually class every year. He has the pumped tuned but makes little to no black smoke, has slant cut stacks as well, so I would think if it were really cranked up it would be obvious, anyway, this year places 1-4 were Cummins, 5 a power stroke then like 6-12 Cummins, then a couple of old 6.9's, one turbo, one not! I remember all this cause my best friends son runs the pull and my best friend and I try to help him out scoring etc.
I had thought about entering my truck, but once I saw that, I figured why put that kind of pressure on the old girl just to get my tail kicked. Now in the modified class, there are a couple of 6.9's that do well, problem is, they have big bucks in them to get them better than a Cummins or Powerstroke and when those owners spend some big bucks well, there you are, getting your tail kicked again.
1987 F250 6.9 4X4 - T19 Trans, 4.10 Dana 60 Front/Ford 10.25 rear, Dual Rear Wheels, Carter P4594 electric fuel pump, Restrictive air filter opened up, Firewall repair kit installed, new clutch m/cyl and pedal bracket, bushings etc.,7.3 fuel filter conversion, Solid state controller OEM (new controller and Motorcraft GP's), Headlights converted to relay system with 65/100 Watt Cold Ice bulbs, Class V Hitch (10,000lb WC/15,000lb WD), Air Horns, Cadet 7' X 9' flat dump bed, 5 ton grainmaster dump hoist.
sle2115 is offline
Old 11-23-2005, 07:52 PM   #3 (permalink)
Re: Truck pulls
Check the rules of the pulling organizations. I have gone to local pulls where they let the NA Fords, without turbos, pull with the gas trucks. These were stock classes. I have had the itch with both of mine, but am afraid I will destroy something if I do. Give it a shot and have fun. Matt
If It Ain't Broke, Fix It 'Til It Is
97 F350 XLT RC 4X4 PSD/E4OD
HENRYETTA: 87 F250 XLT RC 4X4 6.9/C6
http://community.webshots.com/user/mb97psd
MB97PSD is offline
Old 11-23-2005, 08:06 PM   #4 (permalink)
My Photos: (14)
Re: Truck pulls
Unfortunately, that is not the case at my local pull. Matter of fact, we have very few (none this year) gassers pulling in the stock class, might be the reason huh? Pulling against a turbo'ed diesel didn't sound appealing to them either. The gassers at that pull are all modified.
sle2115 is offline
Old 11-23-2005, 10:02 PM   #5 (permalink)
h2odrx's Avatar
Re: Truck pulls
so how do you hook up?
goose neck?
or what does the sled look like any links to see it?
we have a local mud bog, but i don't know about pulls?
h2odrx is offline
Old 11-23-2005, 10:14 PM   #6 (permalink)
My Photos: (14)
Re: Truck pulls
At our local pull, you have to have a 5000lb or better hitch, preferrably a receiver style, you then use a clevis and the pulling trailer hooks to the clevis via a very serious chain. In the stock classes, that is all that is needed. In the modified classes, they require a second safety chain and an cutt-off switch wired to the truck so if it gets more than about 4 feet from the trailer, it kills the motor. Just in case a truck runs away it will be shut down in short order.
sle2115 is offline
Old 11-23-2005, 10:21 PM   #7 (permalink)
h2odrx's Avatar
Re: Truck pulls
cool, are there any sites for pulling?
h2odrx is offline
Old 11-23-2005, 11:57 PM   #8 (permalink)
Re: Truck pulls
Check out truckpulls.com. It has lots of info about pulls around my area. Look in the photos/video section and you will see what goes on.
MB97PSD is offline
Old 11-24-2005, 03:27 PM   #9 (permalink)
Gibson's Avatar
Re: Truck pulls
we had one pull a couple months ago. not a professional pull though. just a pull for personal trucks, no high performance non-daily trucks were used. I got 6th of 12 trucks. 1st was a cummins HO, 2nd cummins HO, 3rd stock powerstroke, 4th stock poweerstroke, 5th turbo idi, 6th me, 7th turbo idi, 8th powerstroke, 9th 6.5 chevy, and the rest were a 6.9 and 6.5's. I think we pulled either a 5K or 7K gooseneck sled on fresh river sand...........Gibson
D.T.Gibson
1.830.203.1460
new newer rig: '05 greyish/balckish Ford F-350 XLT Lariat, Crew Cab, 6.0L PowerStroke, Fx4, Leather and all the electric goodies besides a moon roof, auto trans, 3:73's, leveling kit. SCT Looney Tune stacked with Edge Juice with Attitude, and 4" turbo back exhaust. 91K.... blew HPOP and headgaskets. In shop for now. maybe by the 8th ill have her back with new long block! sweet!
newer rig: late '99 Red Ford F-350 PowerStroke, 4x4, CC, 4r100 Auto Trans, 3:73's, Stage Coach Conversion, 4" DP to 5" up to 6" stack, aFe Stage II intake, DP Tuner 4pos chip, dFUSER oil crossover line, 10K mod, AIC controller, '06 18" King Ranch Wheels. 225K.
new rig: CUMMINS POWERED '95 F-350 XLT, crew cab, Blue & white, ZF5-speed, 4x4 with auto locking hubs, 4:10 gears, 283K miles, 3" DP to 5" exhaust, Auto Meter A-pillar 3-gauge pod with EGT, Water temp and oil pressure.
Gibson is offline
Old 11-26-2005, 11:46 AM   #10 (permalink)
My Photos: (27)
Re: Truck pulls
Trevor in MO
Huff's done a few. I plan on runnin the 85 if I ever get it back together. You will need to crank the rpms up to 4,000 plus to even get close to competing with the street mod guys. A 6.0 with just a box is 400+HP so your gonna need to dig up some HP from somewhere!
IRAQI WAR VET AND PROUD OF IT!
2008 F250 FX4 6.4
SUPERF350 2006 F350
POWDER COATED CAC TUBES
PROJECT TRUCK 85 F250 4X4 6.9 6.0 IN IRAQ
superf350 is offline
Old 11-26-2005, 02:34 PM   #11 (permalink)
Re: Truck pulls
I would run mine in a pull but only with the driveline upto snuff and the propane workin some majic lol. There has got to be some potential in these IDI engines somewhere? Has anyone tried to buid one to make some seriuos HP? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
94 F250extended cab 4x4 turbo
ZF5speed 4.10 gears
jrcat is offline
Old 11-26-2005, 05:51 PM   #12 (permalink)
hesutton's Avatar
My Photos: (30)
Re: Truck pulls
Yes! Ken (land_yaght) has build some 6.9's that make good power. He dyno'ed one about a year or so ago that laid down over 400HP. Don't recall the torque. His place is DPS Performance . He used these HO 6.9's in pulling trucks. If you want to make big numbers with an IDI, and use those ponies to pull competively, give Ken a call.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
hesutton is offline
