Vibration in Drivetrain/Rearend?
I am having a bad vibration when driving my truck. When the vibration starts, I put the truck in neutral to coast and it is still vibrating. I was thinking it was either coming from the rear end, hanger bearing, or transmission. I raised the rear end up and rotated the wheels. The passenger wheel rotates freely, but the driver side wheel is a bear to turn. It sounds as if the brake is rubbing on this side more. Also, when I rotate the passenger side tire, the driver side wheel does not move and vice versa. These should spin in the opposite directions when turned. Do you think my brakes are messed up, bad bearings in axle, gears? Anyone have recommendations on where to start?
1987 F-250 6.9L 5spd 315K Miles 2wd Reg Cab Custom
