Water in Manifold - Diesel Forum - TheDieselStop.com
Old 11-14-2009, 05:55 PM   #1 (permalink)
Water in Manifold
So I took off the air filter housing to work on the fuel return lines and noticed that there was water down in the manifold. Maybe half a centimeter. I know the seal on the firewall is hardened and probably does no good. I can see a water line on the top of the air filter lid so I know it can collect there. The truck has been run in about two months. Also I used a pump and some small hose to suck out all the water I could find. I was able to get pretty deep on the passenger side of the manifold
Does anyone have any wisdom to share?
1986 F250 6.9 Diesel, 2wd
Bender123 is offline
Old 11-14-2009, 06:07 PM   #2 (permalink)
CDX825's Avatar
My Photos: (11)
Send a message via AIM to CDX825 Send a message via Yahoo to CDX825
Pull all 8 glow plug out and disconnect the red wire from the injection pump and crank the engine over. This will blow the rest of the water out of the engine. If you were to try and start the engine without doing so you would most likely hydro lock the motor and possibly bend a rod.
I would change the oil to because if any water got past the rings into the crankcase its not going to be a good thing!
-Justin
1984 F250 6.9 C6 2WD Push Button Wellman GPs, No Soup bowl. Wix 33439 Water Separator, Carter P4594 fuel pump, Custom 3" Exhaust, NTZ Oil Bypass Filter, VDO Vision water temp gauge, ISSPRO EV Pyro
http://photobucket.com/CDX825
CDX825 is offline
Old 11-14-2009, 11:23 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Part numbers for Hood to Cowl gasket
1980-1986 is part number E5TZ1502824A
1987-1996 is part number E7TZ1502824A
Are the new style replacement hood seals, try ordering off an internet dealer......
Proud Canadian BOOB man too!!
cdnsarguy is offline
