water separator - Diesel Forum - TheDieselStop.com
Old 11-29-2006, 08:30 AM   #1 (permalink)
water separator
Does the &.3 idi water separator / filter unit fit on the 6.9 with no modifications, what is the easiest kind of new water separator to install and have the filters be reasonably priced? what micron fuel filtration do our 6.9's need? Thanks
86red250 is offline
Old 11-29-2006, 10:54 AM   #2 (permalink)
My Photos: (23)
Re: water separator
yes you can use it. Even better though, is one of the aftermarket water/fuel filters that do not require the seperate bottom piece and fit the existing 6.9 filter head, such as the Baldwin BF1222.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, Moose Mister Injectors, Hypermax Turbo, Intercooler, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 11-29-2006, 11:10 AM   #3 (permalink)
Re: water separator
Do I understand this correctly, if I got the Baldwin piece, i would just screw it onto the original 6.9 head? 5mins & your done? Same filter?
thanks
Doug
1994.5 F-350, 4X4, CC, LB, PSD
2001 Dodge X-tra cab 4x4 diesel play truck.
1956 Mercedes Unimog 411 diesel of course.
Nelly is offline
Old 11-29-2006, 05:18 PM   #4 (permalink)
Re: water separator
Better off using one of those CAV water separators found on farm tractors worldwide.I saw one of those on ebay and they do the job very well.
Rocketwagon is offline
Old 11-30-2006, 07:36 AM   #5 (permalink)
Re: water separator
thanks again for everything., I have an extra factory fuel water separator. Does anyone have a good thing to say about it? I want to try either mine or the extra. on the top there seems to be stamped in over one pipe with an arrow pointing to the other. in/out would be so much clearer. IS in the one with the arrowhead over it?
86red250 is offline
Old 12-01-2006, 03:39 PM   #6 (permalink)
My Photos: (23)
Re: water separator
Correct.
As for the factory water seperator, the design flaw is this. It has a rubber plug which seals from the inside out. There is no filter before this unit, and so all the crap settles down around the sides of the plug. When you pull the ring to drain it, some of the crap falls out, but a lot of it doesn't. Then when you let go of the ring, the plug captures dirt between itself and the surface it is to seal against, resulting in an air intrusion. As for its ability to catch water, it works fine.
- Mel
agnem is offline
Old 12-01-2006, 07:36 PM   #7 (permalink)
Re: water separator
Hey mel, I looked up the baldwin BF1222 thats the one without the h2o in fuel sensor tap they want 38.00$ bones for it,do you know if it can be cleaned?
1986 F250 Lariet 6.9 4x4 C6 ,BW 1345 TC,Dana44 IFS front axle, Sterling 10.25 rear axle , dual pod{ oil press, coolant temp,} push button start, push button GPs, 146,000 orig. miles , orig. HD gaskets, GRP 31s batts.
1trickymarie is offline
Old 12-01-2006, 09:00 PM   #8 (permalink)
Re: water separator
It makes an excellent paper weight. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
01 F250 XLT 4X4 7.3 Auto tran.373 LS.Dark Highland Green.Green fuzzy dice.XM satilite radio.New gauges in the box.AIC. Walker 21470 muffler.Oil Guard bypass filter.Dura Lite air cleaner.transmission by Jerry's.More $$$ Needed.
85 F250 "Fred" 4X2 XL 6.9 Auto trans.AC. AM FM radio. Coming soon Fairmont 307 Hyrail gear.
<font color="blue">My Photos
www.ctpowerstrokedieselclub.com
Trackspeeder is offline
Old 12-01-2006, 10:44 PM   #9 (permalink)
Re: water separator
Check out this fuel filter with the old dirty fuel filter added in. The number is 190056331908.... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
icanfixall is offline
Old 11-07-2009, 01:02 PM   #10 (permalink)
Sorry, old post, but trying to find a replacement fuel filter w/built-in water separator for my 1987 6.9L. RACOR doesn't make them anymore and the Baldwin BF1222 is sized for the 7.3L header (1 inch) and not the 6.9L header (7/8 inch). Anyother options???? Thanks in advance.
InTheDogHouse is offline
Old 11-07-2009, 04:48 PM   #11 (permalink)
Joe Mc's Avatar
My Photos: (39)
2 micron for the final fuel filter. I use a 30 micron as a per-filter on my Racor unit and a 2 micron at the stock filter location.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Joe Mc is offline
Old 11-07-2009, 05:07 PM   #12 (permalink)
Racor model 225 or model 445 will bolt on the firewall in place of the stock water separator. Filters for them are available in 2, 10, or 30 micron. Much more effective water separator unit than the stock 6.9 or 7.3 units. Plus it filters the fuel before the lift pump.
Evel486 is offline
Old 01-02-2010, 11:18 PM   #13 (permalink)
I just got done removing the factory fuel/water separator from the firewall of my 84 F250. I removed the assembly so I could service it, and I noticed that one of the PO's had repaired a hole in the cannister. I was also unable to spin the cannister off. I wound up crushing the cannister and tearing a hole in it. Through the hole I could see a crappy looking filter element. I replaced the entire unit with an AC primary filter head, part# G438957. I'm putting a Carquest 86418 spin on filter with a drain valve on it, rated at 12 microns. The only thing I wish I still had was the water-in-fuel sensor.
snowfighter3 is offline
Old 01-02-2010, 11:29 PM   #14 (permalink)
Hey guys The number for the AC filter head in my previous post is no good. I got the number right off the top of the head. Go figure. Anyway, I got the filterhead off of a GMC topkick truck.
Old 01-02-2010, 11:30 PM   #15 (permalink)
87CrewDually's Avatar
I'm going through this right now on my 87 6.9. I already have a filter head so I've been matching Napa water seperators/filters to the head i have. So far I found a bunch with drains and 2 with a sensor port too. The problem is with the sensor port they get expensive, $46 for a Napagold 3604 with drain & sensor port @ 8 micron. My other option is a Napagold 3405 14 micron for $21. Half the price.
87CrewDually is offline
