Thanks again, LMJD. I am new to searching and buying for auto parts online. Can you recommend a site that sells either a Mitsubishi or Nippondenso starter for this engine?
1984 F250 4x4 Super Cab, 6.9L, 4spd. ATS Turbo
If you already had a worn out Mitsu or Nippondenso, for the best quality parts and overhaul job I'd advise you to take it to your local autoelectric shop. Since that's not the case I guess Napa or Rock Auto would be your best bet. It appears some of the low-end on line parts outlets pedal rebuilt starters, alternators, etc, using nothing but offshore cheap foreign components.
Since Rockauto does not seem to carry either of those two brand names for this engine, and I do happen to have a Napa in my small town locally, I'll go in and check with them to see what they have to offer. I try to stay away from the cheap offshore components whenever possible. Thanks
Certain foreign stuff I'm OK with but not with others. The one online parts house that had all the components for me to do a complete rebuild appeared to be low end foreign stuff. I ended up taking the starter to a local auto electric shop and he overhauled it with the best quality parts and the total bill was only $104----can't beat that. That original starter (Mitsu) lasted me 19 years and over 230,000 miles. Both armature bearings are huge and high quality. The brushes were about shot which they ought to be after all those years.
Thanks for the info, LMJD. I am certainly not what I would call a "mechanic", but after disconnecting both batteries, I removed the starter motor no problem. I then took it down to our local NAPA store, and went over the options they could get for this engine. The one I decided on was listed as a Mitsubishi Replacement. It is the 4N-6265, new, with gear reduction (OSGR starter type), and the paperwork it came with says "starter model: Mitsubishi". It says "NAPA New" on the motor, and made just this year. It definitely looked slightly different, and I was concerned about it not being a Mitsu brand, which is what I wanted (or a Nippondenso), but the worker at Napa called someone and confirmed that it should be interchangeable with the Delco that I had in it before.
I tried installing it today and it appears to be 3/4" longer than what I had, preventing it from fitting. $180.00 - this type of part would not be exchangeable/refundable, correct? I could get another Delco, which does have a 3 year warranty they said, but it sounds like most folks here recommend avoiding that brand. Their were remanufactured options, including both basic and premium options, although I think they were going to be Napa also, and I would prefer new, over a reman.
Any suggestions from the wise folks here would be greatly appreciated. Anyone with a different specific starter # from my 4N-6265, that they could recommend? Besides Napa, our small town also has a O'Reilly and a Autozone. I doubt I could find or trust a local auto electric shop to rebuild the one I took out of my truck, or could wait for them to do the job. Thanks
4N-6265 is what I installed on my previous 7.3l F350 and it fit perfectly. Cranked the engine over as fast as one of those Hot Wheels cars with the toothed stick you pull, too.
1990 Jeep Wrangler Sahara, 4.2l, 5-speed, Dana 30/35 w/3.07s (for now!), 33x10.5x15 BFG Mud-Terrain KM2s on 4" Rough Country springs. Engine being rebuilt after an awesome afternoon in the mud LOL
Where is it hitting? If something related to the turbo is in the way then I think you'll have to look for the shorter Nippondenso starter (NAPA 4N0208, for example.) But 4N6265 IS the correct NAPA new starter when I look it up by your vehicle on the website.
I can get the gear side kind of in place, but when moving the opposite (flat) side, I can't seem to get it past a narrow steel metal line... Very tight and limited space in general. I do not know what the part are, that are in the way...
I'll see if I can get my mechanic friend over here to my house, and maybe he would either be able to fit it in, or at least know what parts are in the way. Thanks guys. It is good to know that I have the part that should be the right one.
My friend who is a good mechanic came over today and was able to install the new Napa starter. He said the cross member and a fuel line were what I could not get around, but he was able to do it with out much difficulty. Cranks and turns over very smoothly now Thanks again for all the reply's from you folks about this issue.
