Whats the cheapest way to get an engine - Diesel Forum - TheDieselStop.com
Old 11-29-2005, 10:23 AM   #1 (permalink)
My engine is going bad and I need to replace it. What is the cheapest way. I have been looking at buying a complete or wrecked truck to take it out of because I need a couple other parts such as a transfer case and maybe a turbo upgrade. I would then just put my old engine in the truck and sell it. I have also looked at buying a used engine and that has seemed like a pretty good way to do things. Being able to rebuild the engine would be very nice but I do not have another truck to drive when I rebuild the engine. If anyone has any other ideas it would be appreciated.
99 f-250 powerstroke XLT auto 4X4 35" pro comps, Dp-tuner 80 econ tune
clorine12 is offline
Old 11-29-2005, 10:47 AM   #2 (permalink)
Re: Whats the cheapest way to get an engine
Would not be the 'cheapest' way, but I would buy another means of transportion, rebuild what I have (to my specs [img]/ubbthreads/images/graemlins/smirk.gif[/img]), then sell the other transportation when my 'specs' are met.
I already have 4 trucks (3 6.9s) that I'm working on and all the 6.9s are operable. Gathering parts for a rebuild on my '86 4x4.
Rick
86 F250 N/A 4WD w/HomeGrown Propane, Poly Spring/Body Bushings, PushButton GP Controller, 3.55L rear, Goodyear WorkHorse II XTRA Boots, 248k miles, Rotella 5-40W Synthetic
Rick_Hipp is offline
Old 11-29-2005, 01:53 PM   #3 (permalink)
Another reason that i don't want to rebuild that I do not have the time. I go to school and work in the summer. I might be able to rebuild it next winter at school but I would like to put the new engine in the spring. I also do not plan on having the truck for more than 5 years and I do not put very many miles on it.
Old 11-29-2005, 09:48 PM   #4 (permalink)
Blasphemy !!
1985 6.9L, F250 Regular cab 4x4.
shazaam000 is offline
Old 11-29-2005, 11:14 PM   #5 (permalink)
NAPA has a good kit(bearings gaskets ect) But your local rebuilder will probably be cheaper on pistons. I went through my 6.9 for $1900.00 not including injectors or pump. My labor of love was also for free to R&R and assembley. It does include crank turned , heads rebuilt and 1 sleeve installed. Problem I got now is if I sell the truck I would be selling the motor and giving them the truck for free to carry it around in. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
84 f-250,4spd man,2wd(so far)
93 f-250 E4OD 7.3 non turbo(so far)2wd
2001 f-250 stroke
I'm a lucky man,I get paid to walk where the Devil dances
RGVsmokey is offline
Old 12-04-2005, 01:51 PM   #6 (permalink)
rent uhaul truck remove and replace engine [img]/ubbthreads/images/graemlins/eek.gif[/img]
you may get a fresh rebuilt 7.3.
return uhaul say thanks pay week rental
1988 F250 dually 7.3 IDI Banks Sidewinder C-6 with GearVendors overdrive 3.55 ring gear
Amsoil 5w30HDD with full flow / bypass filters,
Evans coolant and Amsoil conical air filter.
AMSOIL ATF in the transmission, AMSOIL gear oil in the diff.
20MPG city 25/28 hwy
IDIABUSE is offline
Old 12-04-2005, 05:06 PM   #7 (permalink)
towcat's Avatar
bad idea.
firstly, U-haul does mark the motors, I used to have to record the numbers when they showed up at my machine shop. There's a couple of obvious tags and a couple of hidden ones.
secondly, with them watching closely over the motors, they obviously prosecute on a felony of that nature.
suggestion.....
buy a wadded up truck with a running motor, they are still around but getting harder to find. Don't know where you're at, but if you hit the online classifieds or the equipment auctions, you should be able to come up with a truck for less than $2k. I know of one in Watsonville, CA today that the guy wants 1k for the truck and its about as ugly as sin but runs great.
86 f250 6.9IDI, 4spd 4X4 "the runt"
89 f450 rollback carrier 7.3IDI, ZF5, 4X2(in memory of...)
90 f450 conventional towtruck 60"CA 7.3IDI, E4OD, 4X2
92 f350 CC 7.3IDI, ATSturbo*intercooled*, ZF5, hydrostop, 4X2 "the nebuchadnezzar"
...Quack Quack................*P.A.K.*...
red pill or the blue pill? make your choice and pm me.
7/03 mini meet pics
towcat is offline
Old 12-04-2005, 05:35 PM   #8 (permalink)
he just said cheapest, some people dont care how, I always thought about it, remebering all the swaps done back in the day when hurst rentals rented out shelby mustangs.
IDIABUSE is offline
Old 12-04-2005, 08:03 PM   #9 (permalink)
if stealing the neighbors is not ok then a used truck or a wrecked one
97 dodge 2500 4x4 cc lb 12V auto 3.54 pillar gauges 215 nozzels
31'TT at 8000 lbs
94 explorer
shorthair is offline
Old 12-06-2005, 02:25 PM   #10 (permalink)
My Photos: (23)
The honest answer seems to me to be "buy a motor with a truck still around it". It's been my observation that removed motors are worth more than ones in a truck. I guess that's because some people don't want to mess with parting out the hulk. I bought one that a tree had fell on for $600. I don't see you getting a running motor much cheaper than that. Check the for sale pages here.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, Moose Mister Injectors, Hypermax Turbo, Intercooler, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 12-07-2005, 12:05 PM   #11 (permalink)
I have an 84 F25 where I ended up on three occasions to weld the famous crack near the heat plug connection. The last time it leaked after installation that I decided to get an engine from a wrecker. I shopped around and came up with one, but as it turned out it was seized.
I contacted this forum and waqs told to purchase of a whole truck, possible an 87 model. I found in short order one advertised here. I had to fly to Tuscon, bought the truck after a short test drive and paid $2K. I drove it to SoCal and on a couple of weeks later to Mexico B.C.S., where my 84 was parked. It took 2 days for the removal and re-installation with the help of the local mechanic, another $200 and the truck runs like a champ. The new engine has more UMPF, and I ended up with lots of spares, including a nearly new, overhauled Transmission.
I'm glad I found this forum and followed the advise provided.
Manfred is offline
Old 12-07-2005, 05:05 PM   #12 (permalink)
My Photos: (14)
I have one out of an 85, not sure if it is the new model or not. It has low mileage but was owned and used by a local oil company. It came out of a 1985 that had 88,000 on the clock and I was assured by one of the guys who maintained them that it only had that many miles. The truck was scrapped as it sat and rusted most of the time. I have no idea HOW it was used, I brought it home, started it, and then cut the truck from around it. I planned on keeping it just as a spare, but figure if I ever do anything with the engine in the 87, I will rebuild it as it has some improved parts and I don't have to drive my truck daily. Not sure where you are or if this motor has the later casting that is not proned to cracking, been meaning to check that out. I have the Injection pump on my 87, but have a rebuilt one to replace it and planned to put the pump back on it, of course it would need timed after doing so. I also have the T19 and transfer case. PM me if you would like.
Scott
1987 F250 6.9 4X4 - T19 Trans, 4.10 Dana 60 Front/Ford 10.25 rear, Dual Rear Wheels, Carter P4594 electric fuel pump, Restrictive air filter opened up, Firewall repair kit installed, new clutch m/cyl and pedal bracket, bushings etc.,7.3 fuel filter conversion, Solid state controller OEM (new controller and Motorcraft GP's), Headlights converted to relay system with 65/100 Watt Cold Ice bulbs, Class V Hitch (10,000lb WC/15,000lb WD), Air Horns, Cadet 7' X 9' flat dump bed, 5 ton grainmaster dump hoist.
sle2115 is offline
Old 12-07-2005, 07:32 PM   #13 (permalink)
Seafarer12's Avatar
You would get a PSD [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Just check wreckingyards. Nothing is going to be cheap unless you throw a gas engine in it. One thing I learned the hard way nothing is cheap on a diesel.
Massey 65
Seafarer12 is offline
Old 12-07-2005, 11:43 PM   #14 (permalink)
I bought the one in my truck at a pick n pull yard on half price day. Got it complete starter a/c compresor everything for $80. Bought it just for parts but when the motor in my truck let go I tossed it in and it runs great. It came out of a wrecked local company truck whos maintence shop is usually above par.
Keith
2000 F350 Cab/Chassis CrewCab 4x4 DRW 7.3/auto "Hamilton Custom Cruiser Conversion" WesternHauler Bed 50gal TFI transfer tank 4" turbo back Exh. DIY intake w/Napa 6637
'88 F350 CrewCab SRW 4x4 7.3/C6/4.10LS Banks non-wastegated turbo NAPA 6637 airfilter 4" lift Airlift rear airbags 107k miles
'89 F350 CrewCab DRW 7.3/E4OD/4.10 124k miles
'86 F250 ext cab. 4x4 6.9/C6/3.55 arrowcraft dually conversion 45gal aft tank ?53k miles
'85 F350 Cab/Chassis DRW 55" Schwalbe Sleeper 7.3/T-19, 4.10, Banks Sidewinder wastegated Turbo Holley red tweaked inj.pump 6.2 governor and STACKS! The old 6.9 gave up after 445k miles.Stacked before stacks were cool since 5/85 **SOLD**
My Pics
'86 F350 Crewcab Dually 6.9/C-6/4.10 LS Racor seperator. 233k miles **SOLD**
'89 F350 Crewcab SRW 4x4 7.3/zf5/4.10LS 193k miles**SOLD**
85Hauler is offline
Old 12-07-2005, 11:52 PM   #15 (permalink)
h2odrx's Avatar
everything for $80.
WOW!!!
that is the kind of deals i like!! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown?
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
Exemptions from the excise tax
h2odrx is offline
