Why is it so loud - Diesel Forum - TheDieselStop.com
Old 02-02-2009, 11:15 AM   #1 (permalink)
Why is it so loud
We all know how loud our diesels are under the hood. What I was wondering
is exactly what component under the hood is making all the noise? Is it the injector pump, valve train or what? And knowing what it is, how can I quiet this beast a little. Its not comming from the exhaust just under the hood.
Jason Eschete 86 F-250 6.9L 180K miles
jasoneschete is offline
Old 02-02-2009, 12:04 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Most of the noise is the compression knock of a diesel.......
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 02-02-2009, 03:23 PM   #3 (permalink)
CDX825's Avatar
My Photos: (11)
Send a message via AIM to CDX825 Send a message via Yahoo to CDX825
Synthetic oil quiets them down quite a bit.
-Justin
1984 F250 6.9 C6 2WD Push Button Wellman GPs, No Soup bowl. Wix 33439 Water Separator, Carter P4594 fuel pump, Custom 3" Exhaust, NTZ Oil Bypass Filter, VDO Vision water temp gauge, ISSPRO EV Pyro
http://photobucket.com/CDX825
CDX825 is offline
Old 02-03-2009, 03:38 PM   #4 (permalink)
big99diesel's Avatar
Lucas Engine Stop Leak Or Oil Stabilizer Will Quiet It Down.
2003 F-250 6.0 74000miles Reg Cab 2wd.
big99diesel is offline
Old 02-03-2009, 05:14 PM   #5 (permalink)
1dieselman's Avatar
My Photos: (12)
Do you still have the insulation attached under the hood. If not maybe some hush mat glued in its place might help.
Jack
Sold: 94 F250 xcab, E4od, 4x4, IDI 7.3 turbo (Put the gears, lift, and goodies on the 97)
97 F250 XLT CCSB 4x4, PSD, stump puller heavy duty E4od, fast spool turbo, deleted ebpv, 203* t-stat, high pressure X line, 140v Idm mod, 6637 filter, 60hp chip, 3" downpipe 4" shorty exhaust, 4" lift, 4:10 gears, 35" tires, over 300,000 miles
1dieselman is offline
Old 02-08-2009, 01:45 PM   #6 (permalink)
rmr
Mine used to be really loud until I had the IP timed.
It was to far advanced and now it's way quieter, smoother running. When it's warmed up anyway
1986 F250,Regular cab,XL,4X4,6.9, 4 speed,
2006 Chevrolet Silverado 2500HD, 6.0,gas, 4X4, reg cab
rmr is offline
Old 02-14-2009, 01:12 AM   #7 (permalink)
1987IDI's Avatar
My Photos: (14)
I've always been told its a mix between the high compression combustion of diesel and the injector pump/mechanical injectors.
1987 F250 XLT Lariat
Regular Cab 2x4 6.9L 5-Speed
Homemade Propane Injection.
RUNS ON PURE WASTE MOTOR OIL!
No more diesel for me...
1987IDI is offline
Old 02-14-2009, 11:59 AM   #8 (permalink)
Thanks for the info everyone. Right now she is in a few pieces but should have her back together in a few weeks. I'm painting the accessories under the hood so I cant crank her up yet. I will try the synthetic oil and lucas engine stop leak. I added a hood insulator mat but didn't run her yet. Also how do I check the timing on her I have an old timing light but I never used it. I was also wondering If I should remove the exhaust manifold and clean it out. I work on Detroit diesels at my job and I had one's exhaust manifold caked with 1/4 inch of crud
Old 02-14-2009, 12:20 PM   #9 (permalink)
1dieselman's Avatar
My Photos: (12)
You need the feret adapter to use a timing light. There should be no reason to clean out the exhaust manifolds on this as opposed to a detroit especially a two cycle that has spent to much time idling.
Jack
