Old 12-15-2007, 12:30 PM   #1 (permalink)
05 F-350 trailer wiring needs
I have 05 f-350 cc dually, tow command system. The previous owner put a 6-way plug in place of the 7-way and i need to wire it back up. My question, does anyone have a wiring schematic with the colors and stock wire locations of where they were on the 7-way??
The previous owner cut the wires so the quick connect option is out.
2005 Ford F-350 CC Dually Lariat
2005 Ford Escape (wifes)
2003 Ford Focus
1975 Ford 2600
2001 Exiss 4 horse gooseneck
http://i222.photobucket.com/albums/d...a/IMG00393.jpg
ryan_n_va is offline
Old 12-15-2007, 12:41 PM   #2 (permalink)
Hook'em Horns!'s Avatar
Re: 05 F-350 trailer wiring needs
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ryan_n_va</div><div class="ubbcode-body">I have 05 f-350 cc dually, tow command system. The previous owner put a 6-way plug in place of the 7-way and i need to wire it back up. My question, does anyone have a wiring schematic with the colors and stock wire locations of where they were on the 7-way??
The previous owner cut the wires so the quick connect option is out. </div></div>This should help.
4,5,6 and 7 way diagrams color codes also
2005 Chev Duramax/Allison 3500LS DRW Crew Cab
B&W 30K-Turnover GN, Putnam XDR 15K, A/T Revos
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 9'Flat-GN
A/T Revos
DON'T STEAL! The Government Hates Competition
Hook'em Horns! is offline
Old 12-15-2007, 07:02 PM   #3 (permalink)
thanks
Got it all wired up and bolted back and tested the lights on the trailer. Seemed to all work. Got another issue will post a new topic.
2003 Ford Focus
1975 Ford 2600
Old 12-16-2007, 08:18 PM   #4 (permalink)
I also went ahead and put in my gooseneck plug in the bed today. Solder all my connections, sealed the holes. Last thing to do is put the last 6" of wire in some loom and wrap with tape. I had a whole roll of elextrical tape and misplaced it somewhere.
While i was testing it out,i managed to accidentally blow the fuse for the trailer parking turn signals. I accidently touched the ground and left turn signal when using my test light.
20 amp fuse under the hood. I didn't have a 20 amp mini in my collection but had a 25, should this be okay as a temp fix till i get some more assorted fuses??
2003 Ford Focus
1975 Ford 2600
Old 12-16-2007, 10:46 PM   #5 (permalink)
If you are 100% certain that the wire for that circuit is not grounded, you should be OK TEMPORARILY. The problem is that the additional 5 amps exceed the capacity of the wire it supplies and you could end up melting a wire, or worse starting a fire.
If the circuit is functioning normally (no dead ground) it will not cause any problems, but there is no way to tell.
I would suggest you put in a smaller amp fuse if you have one. Better safe than sorry.
2007 F-350 Crew Cab King Ranch SRW 6.0L FX4 -100% Stock. B&W Turnover GN Hitch.
And a bunch of other stuff with engines... all of which require a wrench.
FarmerK is offline
Old 12-16-2007, 11:15 PM   #6 (permalink)
thankfully i am 100% certain there are no issues. I just accidentally grounded it out using my test light. I was able to find a 15 amp fuse, will put that in tomorrow evening. Didn't figure it would cause a problem since the fuse only gets used if a trailer plugged in.
2003 Ford Focus
1975 Ford 2600
