I am putting on goodyear 235/85R16 14 ply tires 110 psi I think the standard rims are not enough to handle the high pressure. I can not find any rating stamped on the rims.
WHere is a good source for rims for my dexter axles??
WFTREE
__________________ NEVER FORGET, NEVER RELENT, NEVER DISPARAGE 09-11-01
1999.5 F450 CC 4x4: 315 RWHP 710 TQ 6 speed with BD short shifter; 60"CA; South Bend clutch; Ported BB turbo; Spearco 6.0 charge air cooler; pop off valve; dieselsite I/C boots; 203 degree thermostat; pillar mounted pyro, boost coolant temp guages; engine mounted fuel pressure; HX hose; shimmed regulator; Tymar intake; zoodad; Banks brake; 4" DP to 4" exhaust to Aeroturbine muffler to 4" chrome stack; diesel power flip chip, 85 gallon aux fuel; Dahl 100 heated fuel filter; in tank mod, Hella FF driving & fog lights,
Part No. Size Bolt Circle Center Hole Load Rating Price
K2128701 16"x6" 8-6.5" 4.885" 3315 lb. $42.95
</pre><hr />
The load rating is the key. On a 16"x6" wheel, a load rating of 3,315 pounds = 110 PSI. A load rating of 3,042 pounds = 80 PSI.
Go to southwestwheel.com They are a sponser here. They have the 16X7 Alcoas with the 110psi and 3750lb max rating that those LT235/85-16G tires require at full load. You can not correlate the maximum pressure of trailer wheels with just a load rating or vice versa. A dedicated trailer tire ST235/80-16E has a load rating of 3420lbs at 80 psi. Always check both psi AND lbs on both tires AND wheels to make sure that no ratings are exceeded.
Are your wheels 6 or 8 lug? According to Dexter's wheel division you have to go 8 lug to get 110 PSI rating at 3750 lbs. IOW if you are just getting stronger tires with 6 lug rims you can't do 110 PSI to take advantage of the tire....
I just went through a big hassle with a 14,000 lb gross dump trailer I bought new with only 12,000 something total rated tires on it...so I'm up on this right now
[img]/ubbthreads/images/graemlins/crazy.gif[/img]
