Old 12-13-2005, 08:48 AM   #1 (permalink)
14,000 lb weight distributing hitch systems?
I am looking for a heavier system to pull my 14,000+ lb toy box. I just bought the Reese Titan 2 1/2" hitch for my truck. I am now looking to upgrade the rest of the system. I am looking at the Titan weight distributing system and the Blue Ox system. Anybody have experiance with either of them? I have heard the Titan sway system is hard to setup.
Built4rocks is offline
Old 12-13-2005, 12:34 PM   #2 (permalink)
lincster's Avatar
My Photos: (22)
Re: 15,000 lb weight distributing hitch systems?
What kind of trailer do you have?
Are you sure on that weight?
I have not heard of a tag trailer being that heavy.
My buddy uses the Reese system. His is rated at 1700/14000.
The dual cam system is easy to set up.
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... man does this thing tow, Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
lincster is offline
Old 12-13-2005, 01:02 PM   #3 (permalink)
That's the Reese system I am looking at. I had heard the cam system was hard to set up. I am currently using their standard 12,000 lb setup.
My trailer is a 34' tri axle Campmaster with full living quarters and heavy Jeep CJ trail rig inside. The GVW on it is 15,0000lbs. When I pulled it from Ohio to the the Rubicon trail in California, I weighed it on the Flying J scales at a combined weight with my Superduty of 22,500 lbs.
2001 F250 4x4 Crew Cab Mods are just getting started......MBRP 4" exhaust,AFE Stage 2,full guages and Jody's 6 position chip. Glad I put the full Suncoast transmission in when the factory unit failed. Thanks TDS for all the good info and to all the TDS sponsers for great deals!
Old 12-14-2005, 01:40 AM   #4 (permalink)
Man that is alot of weight on a tag trailer.
1999 Dodge Cummins 2500 4x4 Quad Cab TST Power Max 3 w/remote, South Bend Clutch Con OFE, Auto meter Ultralite pyro,boost and fuel pressure gauges. Pacbrake
F & A.M. Lodge 266
GeorgeC
"I will own a fleet of Dodges first."
BarrySmith is offline
Old 12-14-2005, 02:08 PM   #5 (permalink)
For that kind of weight you need a SuperHitch or PullRite
I'm partial to PullRite's myself, they pull more like a 5r (no tail wagging)
This space intentionally left blank.
444turbodiesel is offline
Old 01-01-2006, 05:21 PM   #6 (permalink)
Just bringing it to the top again. I am getting close to buying and I need to decide between the Blue Ox and the Titan
Old 01-02-2006, 07:23 AM   #7 (permalink)
Don't know about the Blue OX but real happy with my Reese system. (Titan & dual cam) Ordered it over the net, installed it, & used it. I did think a lot about it and downloaded the instructions from Reese's site before buying it. Followed their instructions step by step and had no problems. Hardest part was deciding on a level place to do the final alignment. Wound up going to a closed Kmart parking lot. Followed the instructions and when I did the final check, indications were that it was correct. Went to a CAT scale and it checked out. Been on several short trips and one 2,400 miler. Couldn't be happier. I put it on cruise control at 65mph and just let the miles fly by. Good luck on whatever you decide.
2002 F250 XLT 7.3 Crew Cab 2WD Auto 3.73 AIS AIC 4" exhaust Superchips tuner Reese straight line towing system
K5OIT is offline
Old 01-04-2006, 02:06 AM   #8 (permalink)
I'm watching this post too. Buying a front kitchen travel trailer with a 1120 pound dry tongue weight. Trying to decide if my Ford 12500/1250 receiver and Reese 12000/1200 hitch will be enough or if I need to upgrade to the Titan receiver and hitch.
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
Old 01-04-2006, 05:10 AM   #9 (permalink)
AlH
Do you "need' a better hitch- depends.....are you a gambler? [img]/ubbthreads/images/graemlins/crazy.gif[/img]
If it isn't enough you just might need those "Depends" [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Personally I've always been a "buy a little better than you need" kinda guy rather than a "that's just good enough" kinda guy [img]/ubbthreads/images/graemlins/laugh.gif[/img]
96 F350 CrewCab BTS-E4OD 4.10 4x4 / Banks Git-Kit / 99-Intercooler / 99 Tahoe 25TB ToyHauler / 00 FourWheelCamper Pop-up
AlH is offline
Old 01-04-2006, 08:16 AM   #10 (permalink)
I pulled my 30 foot TT with a tongue wt of 1100 lbs ish for over 25k miles. worked just fine with the factory hitch on my 2002
powerboatr is offline
Old 01-04-2006, 10:50 AM   #11 (permalink)
I pull a front kitchen trailer (Arctic Fox) which has a reputation for being quite heavy. I put the putnam class V on mine. I also did the stiffener to the bumper like some have done. The feel is rock solid. My tongue weight is in the 1100# range. I had it weighed just after filling with fuel and I was not over any weight ratings.
JMHO
Housted
2007 RAM 2500 4x4 5.9 CTD Quadcab fiberglass Shell
Sold 2001 F250 4x2 Xcab 7.3 TD
My pics - http://community.webshots.com/user/edgwen1
housted is offline
Old 01-05-2006, 09:35 PM   #12 (permalink)
Thanks for the help guys. I think I am going with the Titan setup. I like the fact that it has the full 2 1/2" draw bar to match up with the hitch. The Blue Ox is only a 2" draw bar. I've been pulling the trailer on the factory 12,000 lb hitch with a 12,000 lb Reese weight distributing system for the last three years.(yea it's a bit over the limit) It pulls ok but it is showing signs of wear at all the moving parts. I will post up when I get the new system installed.
Old 01-07-2006, 05:43 PM   #13 (permalink)
The thing you have to be aware of is these types of trailers are heavier on the tongue unloaded than when you put something in the back and behind the rear axles. My smaller TT doent weigh near that muck but tounge weight unloaded is still at 1300 about 150 lbs less than with 3 ATV's in the back. I bumped up to a 1500/15000 setup.
2003 F350 SuperDuty CC Lariat SB Torqueshift,Front leveling kit, 285/75/16 Toyo MT's,Eagle Alloys,AFE Magnumforce,ITP Muffler Delete, Leer Canopy.
1979 F250 4x4 Built 400 4 speed 4 in.lift
2000 Weekend Warrior 26ft Toybox
2004 Yamaha V-Star 1100 Classic
pics
bikerforchrist is offline
