16" 5-lug trailer wheels? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 04-22-2005, 02:31 PM Thread Starter
Anyone know wher to find a pair of 16" x 6" or 7" wheels with the 5-lug x 4-1/2" pattern found on my Wells Cargo tool trailer? I don't care if they're plain steel, aluminum, whatever. I have some 235/85/16E tires which would work great on my trailer, but need the wheels. The sidewalls are stiff as hell, and the tire is rated at around 3100#ea, so I'm not worried that they're not specifically trailer tires. Should I be?
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 General A/T on factory Alcoas, F add-a-leaf, new alt x3, fuel pump x3, water pump x2, vac pump x 3, PS pump x3, SD starter x3, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, newer black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, new fast-spool turbo 7/11, 317k miles on 18 Oct '14; probably won't run forever but neither will I
JoshR is offline
post #2 of 8 (permalink) Old 04-22-2005, 08:21 PM
SmokeyWren's Avatar
My Photos: (45)
Re: 16" 5-lug trailer wheels?
No such animal at Southwest Wheel. http://www.etrailerpart.com/trailerwheels.htm
Then you'll probably have to replace the entire axle(s) on the trailer with an axle that includes 6 or 8 studs in the hubs.
Or probably less expensive is to replace your current 5" wide wheels with
stock number CW128696MS
size 15" x 6"
bolt pattern 5-4.5"
wheels from SouthWest Wheel's eTrailerparts.com, then buy new ST225/75R15D tires. That's what I did. But don't try to mount those tires on your current wheels unless your current wheels are 6" wide.
No need to worry - LT235/85R16 are fine and dandy as trailer tires. They come standard on many of the heavier RV trailers.
But for 15" tires, stick with ST (special trailer) and not LT (light truck) tires.
SmokeyWren is offline
post #3 of 8 (permalink) Old 04-26-2005, 06:12 AM
Try www.uniquewheel.com They are aftermarket wheels but watch the load rating. Looks like 2000 pounds.
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
post #4 of 8 (permalink) Old 04-26-2005, 09:07 AM
SmokeyWren's Avatar
My Photos: (45)
Good find!
Yep, in their series 297 wheels, they have 5 different 16" wheels with 5-hole bolt circles, but the load rating is only 2200 pounds per wheel, or total axle rating of 8,800 pounds on a tandam-axle trailer. That should be good for up to around 9,500 pounds GVW for a tandam-axle tag trailer or 10,000 pounds GVW for a tandam-axle 5er or goose.
Also determine the PSI limit of those wheels and don't inflate the tires to more than the wheel limit. Probably 44 PSI, but might be as low as 35 PSI. At 45 PSI, the tires have a load capacity of 2,030 pounds. If the wheels allow 50 PSI, then the tires will have a load capacity of 2,205 pounds per the load/inflation table at http://www.goodyear.com/truck/pdf/LoadInflLTMetric.pdf
Unique Series 297
Black "SOFT-8" Steel Wheel RWD
<font class="small">Code:</font><hr /><pre>
PART NUMBER RIM SIZE BOLT OFFSET BACKSIDE SHPG. WT. CENTER BORE LOAD
CIRCLE (+/-)MM SETTING RATING
297-7712 16X7 5-4.5 0 4" 35 3.3000 2200
</pre><hr />
post #5 of 8 (permalink) Old 04-26-2005, 10:55 AM
My Photos: (13)
Can you use truck rims. Chevy and Dodge both have 5 hole 16" wheels on their half ton trucks.
Ag__Teacher is offline
post #6 of 8 (permalink) Old 04-26-2005, 03:54 PM
SmokeyWren's Avatar
My Photos: (45)
Yep, and it turns out you can order them from Discount Tire.
Black steel 16" x 6.5" with 5 on 114.3mm hole pattern are less than $40. (114.3mm = 4.5")
http://www.discounttire.com/dtcs/fin...-4.5*5-4.5%2F5
post #7 of 8 (permalink) Old 04-27-2005, 01:02 AM
My Photos: (18)
That's what I have on mine. Got them at BIG O. I needed more rail height height even after flipping the axles, Put on 7.35 x 16 trailer tires e rated.
Just have to be careful, I now only have about 2-3 inches between the duals but no problems so far with about 15,000 miles on them and I go over some VERY rough territory. (that is why I need the rail height).
I am weighing in at about 8500 lbs
garyT
2002 250SD,4x4,XLT crew,6Spd.,4"ATS exhaust,ATS housing,SP Intake,,Edge Evo, Southbend CLutch CON OFE,BD short shifter, ITP Boost Regulator, Warn Preminm Manual Hubs.
DYNO: 325 hp 728 ft lbs
garyt is offline
post #8 of 8 (permalink) Old 04-27-2005, 08:00 AM
SmokeyWren's Avatar
My Photos: (45)
After reading this I noticed a new Dodge 1500 CrewCab in a parking lot. Yep, only 5 lugs. With 20" tires and wheels! [img]/ubbthreads/images/graemlins/eek.gif[/img]
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
