Question? This was my 1st tow with my new truck (see Sig)My last truck had the 7.3l in it. When pulling at 55-60 mph truck would be running at ~2000 rpm in Tow/Haul and ~1600 rpm out of Tow/Haul, is 1600 rpms lugging the engine? should I keep it in Tow/Haul?
My 02 with the 7.3l never had a problem towing at this speed/rpm and if I came to a small incline the turbo would just spool up and carry us over it without down shifting, on this truck truck downshifts, I take it this is normal. Different Beast I guess.
I must say the Integrated brake controller is great, you do not feel the trailer braking as with the old truck/brake controller.
__________________ 07HEMI4ME
Purchased a 2007 Dodge, ThunderRoad Edition, QC, 4x4, 5.7L HEMI on 11/30/07.
Traded in my Travel Trailer for it, so no need for a Diesel.
2003 EB Expedition 5.4L
2006 F350 Lariat, 6.0L PSD, Crew Cab, FX4, 4x4 PURCHASED BACK BY FORD! on 8/28/07.
i keep my truck in T/H whenever i'm towing my trailer...when i had my pyro on the truck while towing my trailer, i noticed that i could really get the egt's up when the rpm's were low and i wanted to accelerate or maintain speed going up a moderate grade without downshifting...1600 rpm's is fine for steady, flat cruising..
throttle response has been a good indication for me ...if i give it a little go pedal with a load, and the rpm's don't move, i know i'm just making heat in the motor and goose it to get it to downshift...you'll get used to a motor that spins faster..
On flat ground, it is my experience, RPMs should be around 1700. When towing over mountains or hills, I get the best performance when the RPMs over 2,000. I keep an eye on EGT and Boost. I try to keep my boost under 25 lbs.
Experiment a bit and you will soon see where you get your best performance.
I find that the tow/haul and general towing performance is way better then my old 7.3 01 PSD.
[b]*2004 F-350 Lariat King Ranch DRW Crew Cab -Loaded ** ADDED: Retrax Rolling Bed Cover-J&J Billet Grill-LineX Bedliner-Pro Flap Mudflaps-Weathertech Window Guards-Silverline T-304 Polished Flo-Thru Muffler,4" Pipe and Double Walled 5" Tip-3 Gauge Di Pricol Pod-Firestone Air Bags-16K Lil Rocker 5th Wheel Hitch-Prodigy Brake Control-Bilstien Shocks-WhiteNight Backup Lights-CBetr Convex Mirrors-Ford Color keyed Body Side Moldings-Veneerz Burl Dash Kit-Excursion Rear Cupholder w/Rear Radio Control and Power Port-Garmin Street Pilot III GPS-DEI Python 881XP Security System w/Remote Start-IPOD Direct Integration with Factory 6CD Radio-Burlwood and Leather Steering Wheel = Born 9/25/03=Adopted 10/09/03
*2001 F-250 Lariat w/7.3L Diesel Power Stroke - Sold 10/09/03
I guess I will have to, the old 7.3l if it downshifted and went to 2600-2800 you really knew it this one (6.0l) it seems to like it.
Also this was flat land (Florida)
What about fuel mileage? the 7.3L like to be kept under 2000 rpm, what is compareible in the 6.0L? 2200-2400 rpms?
Lugging a diesel certainly is the death of these engines. Watch your gages and experiment with what speed vs rpm vs your gages for your best bet. I don't own a 6.0 so I really am unsure about the 1600 RPM. It certainly is less cubic engines than the 7.3, so I would "assume" they require a few more RPM's to stay in their working range.
Since your tranny is automagic and controlled by the computer program in the PCM, you're not smart enough to lug the PSD engine. The PCM is smarter than you are, and knows when it should downshift to prevent lugging the engine.
Hand shakers are different. The driver has to know when to downshift to prevent lugging the engine. But not with your TorqueShift tranny. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
I thought you are susposed to get your best gas mileage by trying to keep the 6.0 under 2000 rpms while towing? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2005 F-250 4x4 Crew Cab PSD "SOLD"
2006 F-250 4x4, Crew Cab, Diesel, Lariat, Short Bed, 3.73,. Captain Chairs, Tow command, Upfitters, Moonroof, Alarm system with remote start, Rhino Liner, bug shield, mud flaps, and Ziebarted! Sold!
I just finished a 1600+ pulling trip with my trailer and two horses. I averaged 11.13 mpg running 65 to 75 mph (rougly 1900 to 2100 rpms). The tranny downshifted on pretty much every hill, boosting RMPs up to about 2400 or so.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
are 20" wheels stock on this truck? maybe that is why rpm is so low. with the same 3.73 gears matt
Yes they are
I'll take 11 MPG, I was getting in the low 10s pulling at 70 MPH (2,000 rpm) on th e7.3L
The last leg of our return trip was interstate ~16 miles, I set the cruise on 70 and the darn thing kept wanting to downshift for every little overpass and even on the flat sections, bringing RMPs to 2200-2400 range, the 7.3L never did this.
I guess IM going to have to re-adjust to towing all over again. We are going to East TN the 1st weeek of June, it is going to be a long trip if the truck will not hold 70 on flat land with wanting staying in shift all the time, it might just drive me crazy.
Yes they are
Remember that overall tire diameter is more important than wheel size. It is completely possible for the 20" tire/wheel combo to be the same diameter as say a 17" tire/wheel combo. I haven't done any actual comparisons myself, but I wonder what the diameter of the stock 17" tire/wheel combo is? I also wonder what the diameter of the "stock" 20" tire/wheel combo is? I believe my 18" tire/wheel combo is about 33" but will measure again to make sure. Overall, I doubt that marginal differences between tire/wheel sizes will make that much difference in RPMs.
My truck never offered to downshift on flatground, unless I decided I needed to pass somebody [img]/ubbthreads/images/graemlins/smokin.gif[/img].
Yes they are
Just messured them and the 20" wheels and tires are 33"
Different beast indead, I traded from 7.3 manual (1800 to 2400 RPM when pulling) to 6.0 auto and after 22,000 miles it still dosn't feel right to turn a diesel the 2800 to 3200 [img]/ubbthreads/images/graemlins/blush.gif[/img] RPM the 6.0 likes to run with the auto when pulling hard. With 4 tons of hay and over a ton for the trailer, or the slide in camper and boat it will pull any grade at speed and gets 10.5 MPG or more while doing it, so it can't be all bad, I just can not get used to it [img]/ubbthreads/images/graemlins/tongue.gif[/img].
When the warranty is up Maybe exhaust and custom SCT will make it all better [img]/ubbthreads/images/graemlins/smile.gif[/img] , at least I will get TC lock in 3/4 not just OD.
2004 F350 Lariat CC LB FX4 Auto, camper package, superhitch, rear susp air bags, Rancho 9000 shocks, 800W/1600W 115v power converter, Ultralite gauges in overhead 4 gauge pod, 04/04 build and engine Reman shortblock at 34,000 Due to oil leaks, MBRP turbo back, SCT extreme street by ID
10.5' camper, 20.5" Bayliner Cuddy 5.0 V8
1999 Kawasaki ZRX1100
I'm in the middle of a short vacation to So. Cal. from Nor. Cal. Pulling my 5th wheel I averaged 12.2 until I got to the grapevine which dropped to 11.5 because of the grade. The 5th wheel is running at about 10,500 loaded. Tow/haul up the grade remained steady at 27-2800 rpm with actual speed 55-60mph. Truck did a grat job--no complaints! This wasn't my first tow, but the longest one with the truck broken in. Mike.
2004 F350 Lariat 4WD SRW CC 6.0 PSD Dark Toreador Red/Arizona Beige, Leather Every option but Moon Roof & Kitchen Sink, Fumoto valve, Wildcat 31QBHS 5th wheel
The 20" are 60 series and the 18" are 70 series. Which means the sidewalls are smaller. So the overall tire diameter is the same for both tires even though the rim is bigger. 33 inches. If you mount a 65 series tire on the 20" rim, then you will get a taller tire.
The tow/haul mode tries to keep the engine in the powerband. You'll notice coming down a slight grade in tow/haul at maybe 30mph, it'll keep the engine in a lower gear in the 2000 rpm range, vs the older 7.3L trucks would upshift to a higher gear and you'd loff along at 1200-1400rpm. If you needed to accelerate, the 6.0L is already in the power band, The 7.3L would have to downshift to 3rd or 2nd and then give you power.
If you are worried about seeing your tach at 2800rpm when climbing a hill, wait until you see it at 4000rpm coming down hill!
11 F350 CC Lariet SRW LWB Tuxedo Black
Scorpion bed liner and Truxedo tonneau cover
B&W turnover ball
