Considering a 2000 DRW 7.3L 6spd with 4:10 ...anyone out there that can give me some idea of the mileage to expect towing a horse trailer of around 10K lbs.
97 F250, 4X4, CC, DP, 4" Magna-Flow exhaust, Tymar Intake, BTS 4 Position Chip; BTS Tranny; Baby Swamps,Tru-Cool Max,Autometer 3 gauge A-Pillar,HX,Hot water mod, Centramatic balancers;Correct-Trak;Rhino-liner, SKY-FI, Prodigy Brake Controller, Bilsteins all around, Royal Purple in the Diff, Pro-Tech Headache Rack, N-Fab Nerf Bars, Heated Seats..aaahh. Auto-Dimming Mirror with Temp/Compass; Polk Audio with SONY Head Unit. GOS Headlight Harness with Diode Mod.
Sounds like I have a pretty similar rig to what you are considering and towed a similar load, 4H w/weekender LQ, never rolled over the scales with it, but 6700 lb empty, so between the three horses and tack I would say about 10k. Although I never burned through a tank with trailer, I would say it was averaging about 12-13mpg towing to various barrel races around Reno. I base that on getting a real consistent 16-17 mpg empty, last tank was 16.88 mpg. I can't give any current numbers with that trailer as it was sold in favor of a stock combo. Hauled it real nice, set the cruise and the truck never slowed on the hills. Never got a chance to drag it up Donner Pass though I'm sure it would have been fine. Although I will admit I do drive to conserve fuel.
I am not a dually, nor do I have 4.10's or a crew cab....but I do have a 7.3L with a 6 speed, and towing a 28ft enclosed trailer with a toyota pickup in it, some spare tires, tool and parts the trailer is sitting right around 10K and I get 13 mpg's ish towing around Northern Cal. About 16-17 empty...
Silver Metallic 2008 F-350 Lariat, Crew Cab, PSD, 4x4, Auto, MoonRoof, Medium Stone Leather, Heated Captains Chairs, Tow Command, Audiophile, Camper, Tow and Off-Road Package...
White 2002 F-350 XLT, Standard Cab, PSD, 4x4, 6 speed, Donahoe 3" leveling kit, 305 Toyo AT's, Bilsteins, Air Bags, AutoMeter Pyro and Boost Pillar Gauges...
At 10K you can get 12 maybe a little more with a light foot.
Anything heaver than that and you are set for 10 or below.
My truck (in sig) got 10-11 pulling anything from 7k to 15k lbs, without the chip and injectors. That was based on nearly 100k miles of driving and towing up to 2/3rds of the time. I like to drive the speed limit when loaded and 6-8 mph over when empty (max 78 mph). Empty at those speeds avg'd 15 mpg and up to 18.5 mpg if I slowed down to 60 and drove 'smartly' (read: not very often!!).
I'm pretty sure I get better towing mpg's now and I'm towing a 10k lb 5ver all over the country for work. I cannot quantify my milage now, because I do not accurately measure the fuel (SVO and biodiesel) I put in my truck. (I have gone as far as 5,400 miles on one (30ish gals) tank full of diesel)
I'm not cheap - I'm just BROKE!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, LSD, 4.10's NAPA 6637, zoodad, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, Mobil 1 in trans, t-case & diffs, LUK clutch, Swamps single-shots!!! Vegistroke-inspired WVO system w/over 65,000 miles so far! (deadheaded, 70psi VO, looped VO return, cheap (PSD) fuel pump, 190 deg VO BEFORE the heads!), DP-Tuner F5 - stock-high idle-40t-60t-80e-100 - Lovin' it!! 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness with 100/80 watt bulbs and aircraft landing lights for driving lights!
2000 Excursion 4x4 Limited - Frybrid/V3 SVO conversion install in progress! (exclusive 38 gal aluminum under-truck VO tank )
We tow a 36 foot triple slide 5th wheel weighing 15K with a 99 F350 CC Dually w/4:10 and ZF6, 227,000 miles. We have towed most of the interstate system east of the Mississippi and easily average 10 plus mpg. The "sweat spot" with this combination is 2000/2200 RPM in 6th gear on level ground, long grades, i.e. MT Airy, NC is 2000/2200 RPM in 5th gear.
Airfooter, are you sure you didn't mean 540 miles? Or is it because you also had a tank (or tanks) of bio-fuel that you were burnin in addition to the diesel? 5400 mile/ 40 gals = 135 mpg ???????????
If you really got that kind of mileage burning diesel, while hauling a trailer, then I think the Ford engineers may just want to talk to you.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2003 VW Jetta TDI auto, 90k miles, all stock, no mods, 41 mpg most days. A rocket in disguise...
Repairs: alternator, brake switch (x2), power window wire harness, #4 glow plug, glow plug wire harness -TRADED as of 11/24/2008
Newest purchase - 2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available yet)
It is all about drag and not so much weight. You will do better with a horse trailer that you will with a 5er. I get 9.5-10.5 with the 5er. Guys I've talked to with horse trailers seem to do better than 12.
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum. Winter Operation (How I Do It) Hard/No Start? Check here first
short_stuff
It was still 10-12mpg overall, I put SVO in a different tank. 5,400 miles was how long it took to use a whole tank of diesel. I only consume diesel when I start up and shut down. 7 - 10 miles of burning diesel and I can drive ALL day w/o using another drop. That trip was GA to SoCal and back.
