Obviously I have the 7 pin round trailer plug, but I'm wondering if there is a flat 4 blade anywhere I can use? I just got rid of a Dodge Ram, and I bought a Hoppy kit that had the 7 round and 4 flat side by side.
I barely ever use the 4 flat, so I don't need to buy the kit (if they make it??) for this truck, but I'm wondering if Ford included a 4 blade somewhere I can use when I need it.
Re: 2000 Excursion...is there a flat 4 pin anywhere?
My 2000 and my 2001 f350's both had the 4 flat right next to the 7 pin on the same bracket. I would think the X came with the same set up, unless you bought the X used and someone added the 7 pin themselves because it didn't come with it from the factory. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Yea, normally they are side by side, so your outlet is probably aftermarket. You can jsut buy an adaptor and keep in the truck for if you ever need to use a 4 flat.
The X only came with the 7 pin hitch mounted connector with a 7 to 4 pin plug in adapter usually in the glove box in a bag along with the pigtail to wire in the dash mounted brake controller.
FMT
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
