2001 F450 - Diesel Forum - TheDieselStop.com
Closed Thread
Old 01-04-2009, 10:44 PM   #1 (permalink)
2001 F450
I am looking for a truck to pull my 5er with. I have found a 2001 F450 as follows:
2001 Ford F-450 Super Duty Lariat, 4X2 Crew Cab, Dually, 7.3 Power Stroke Turbo Diesel, Leather Captain Chair front seats with center console. All power (seats, windows and locks). NEW BRAKES and HD AUTO TRANS. Original Alcoa aluminum wheels with nearly new tires on them. Size is 19.5"
Custom "CLASSIC TRAVELER" conversion by FONTAINE. This includes fiberglass sides and gate, lighted step pads, couputerized air ride suspension (with dump valve) and Pullrite fifth wheel system.
This truck is super clean and drives and looks the very best. Non smoker driven, serviced regularly, very low miles for the model and has the RELIABLE 7.3 POWER STROKE TURBO DIESEL ENGINE
They are asking 18,500. I have been looking for information to see what I should offer or if this is a good price and have not had any luck finding that information. Does this seem like a fair price? Is there anything in particular I need to check when I inspect this truck?
rconkin is offline
Old 01-04-2009, 11:54 PM   #2 (permalink)
TonkaThunder's Avatar
My Photos: (6)
How many miles?
03 F-350 DRW Lariat 7.3,4x4 6-Speed, 4.10Gears , 4 inch ProComp lift, BFG AT LT315/75R16, 3 in. spacer between duals.
GT38R 1.0 Housing
Banks Monster Exhaust, w/Turbo Elbow, AFE Stage 2 Cold Air Kit, South Bend Stage 2 Clutch and Cyro'ed Flywheel
DP 80econ -Stuck there for now because someone stole my SCT box
2 Optima Red Tops
Auto Meter Boost and Pyro Gauges
8,200lbs---Cat Scale---Thats me and and 38 Gallons of Diesel
1987 Mustang GT Cobra Clone- crate motor, cage and more suspension than I know what to do with
Loves to run down Vettes and Vipers on the road course
34 Ft Kaufman Solid Deck 2-Car Hauler
TonkaThunder is offline
Old 01-05-2009, 12:16 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Originally Posted by rconkin View Post
"CLASSIC TRAVELER" conversion by FONTAINE...
When new, that was the best of the best, and they cost way up there too - over $70,000. Expect to pay a premuim for that Fontaine conversion with the air-ride suspension. If the PullRite SuperGlide 5er hitch is included, that's a $3,000 option right there.
I don't have any idea what the market value would be for a truck that nice, but If I had a big 5er or LQ, I'd really try hard to buy that one.
SmokeyWren is offline
Old 01-05-2009, 02:40 AM   #4 (permalink)
Bill1013's Avatar
Paid 17,000 for the truck in my profile/signature last May, had 126,000 miles on it . Looks to me like that's a steal, only that much for that truck. I had to put my own 5er hitch on, another $850 .
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 01-05-2009, 09:01 AM   #5 (permalink)
The mileage is 73,429. It does include the Pullrite hitch which is the low profile 25.5k hitch.
rconkin is offline
Old 01-05-2009, 09:09 AM   #6 (permalink)
tbpower's Avatar
You might want to call your insurance company to make sure they will cover it. A lot of them won't cover them because they are considered commercial. Maybe you have a business?
2000 7.3 powerstroke. PHP 6 position chip (stock,high idle,60tow,80dd,100hp,no start) . 6637 riffraff filter kit . AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. EBPV delete. Walker 21470 muffler. Riffraff FRX
tbpower is offline
Old 01-05-2009, 11:21 AM   #7 (permalink)
Location: Spring Creek, Nevada(Summer) Rainbow Acres, AZ.(Winter)
I would move a mountain to buy that truck if I were you.
Sounds to me like it is totally set up as RV puller and has been well taken care of.
The transmissions in the 01 models were problematic....primarily because of a "mechanical diode" problem that affected the early models in the year. Maybe that problem has already been addressed by the previous owner but even if it hasn't.....a custom built, heavy duty transmission would make that truck a "lifetime" truck that would serve you well for any later RV purchase.
JMHO
on edit: There are several insurance companies...GMA and Progressive for instance... will insure the truck as they are accustomed to dealing with heavier RV pullers.
2001 F550, Crew Cab, Royal Sport bed, John Woods transmission, 4.88 gears, DP F5 tunes, Gear Vendor overdrive, A pillar gauges, Banks Power Elbow, 4" turbo back exhaust, Cyclone fan, Zoodad, AIS intake, Westin Nerf Bars, 70 gal.aux tank(installed in the bed gravity feed), 10 wheel TireSentry pressure monitoring system, pulling a Dutchmen 35SRV toyhauler with a Harley Roadking Classic or a Polaris RZR in the "garage".
crrroger2 is offline
Old 01-05-2009, 12:24 PM   #8 (permalink)
I called my insurance company, Erie, and they will insure it as a pickup. The rate is almost the same as my 97 Dodge 2500 CTD that I currently drive so that is good. I also called about tags and in TN I have to put a J2 tag on it which is a 16k pound tag but is still not commercial. It is only 41.00 per year instead of 24.00 per year so that is also good. Now I just have to decide if I want to bite the bullet and buy it. My brother has a 2000 F350 w/ 7.3 and he has had good luck with it with the exception of some front end problems.
rconkin is offline
Old 01-05-2009, 12:44 PM   #9 (permalink)
tbpower's Avatar
Looks like an awesome truck. I would go for it. My Dad has an f450 for sale in KY if that falls through. It is an XL model with around 50k miles. It has a flatbed on it. It is a standard transmission with 4wd. Good luck!
tbpower is offline
Old 01-09-2009, 09:16 PM   #10 (permalink)
I have a 2000 F550 with the Fontaine conversion, all the bells and whistles.
I pul a 48' LQ race car trailer with it it tows it with power to spare.
The only drawback is the fuel mileage. They have the full floating 13.5 (I think) dana rear end. With a 4.88 gear ratio. The only way I can get 10 mpgs towing is to keep it under 50 mph. At 65-70 it gets 7 mpg towing.
Now that diesl is down a bit it won't hurt as much.
2000 F550, Auto, Fontaine body 114000 miles.
Use tow 48' race car trailer
rt1092 is offline
Old 01-09-2009, 10:20 PM   #11 (permalink)
I decided not to get this truck. I found another one that I liked better. Thanks for all the replies. The amount of information I got about this truck really amazed me.
rconkin is offline
Old 01-10-2009, 10:44 AM   #12 (permalink)
Just hafta know.......what did you "find" that you like better than a fully equipped, fully set up, low mileage, well maintained, and fairly priced 7.3 liter F450 PSD. They don't come any "better" than that.....unless of course.....you consider a similar F550.
TFPIC
Old 01-11-2009, 12:52 AM   #13 (permalink)
04 Dodge CTD 3500 DRW 4X4. It has leather like the 450 but the seats are heated and the passenger seat is power also. It already has the B&W turnover hitch installed. 305hp HO engine. If I could afford to have a truck to just pull my 5er I would have gotten the 450, but, I have to drive it to work every day. I went back and forth several times and I'm sure the wife was getting tired of me changing my mind.
rconkin is offline
Old 01-11-2009, 03:04 PM   #14 (permalink)
My Photos: (60)
Don't need to go second guessing the decision made.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Closed Thread
