2008 F-350 blown stop/turn trailer fuse - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 12-26-2008, 10:58 PM Thread Starter
I think I blew the stop/ turn trailer fuses on my 2008 F-350. I located the fuse box under the hood and the manual said that fuse #21 and #22 are for the right and left trailer stop/turn lights. From what I can tell from the diagram the fuse appears to look like a little black box instead of the thin clear ones I am used to seeing in a vehicle.
Am I reading the diagram correctly? If I am will Napa or Pep Boys carry that style of fuse? Do I have to replace with that style?
Matt
classicbronco is offline
post #2 of 2 (permalink) Old 01-13-2009, 11:44 PM
Flywheel's Avatar
I don't know the 08 diagram - but it sould like you may have it upside-down. Sounds like you are looking at a relay
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
