Old 07-19-2008, 04:31 AM   #1 (permalink)
235/85R16 tires
I've done a search and I'm reading as many relevant threads as I can, but it would help me if I can get some recommendations and comments regarding my particular situation.
I need to replace my original equipment 5 year old Goodyear Wrangler HT (LT235/85R16E) tires on my 35 ft 5th wheel. I've had 3 problems with these over the years, so don't want the same kind of tire. The 5th wheel weighs about 13,500 lbs with about 2500 on the pin, so I need 4 tires for 11,000 lbs load. I'd like a generous fudge factor, so I'm looking for a capacity of around 3,250 lbs for each tire. I know that averages 500 lbs excess per tire, but I have never weighed each tire position separately. I have wheels that will allow 110 psi.
The Denman Express ST Radial, ST235/85R16E, 10 ply, 80 psi, 3640 lb load looks good. $135 each. Made in Mexico. I'm looking for comments, suggestions, recommendations.
Thanks.
Dean
2003 F-350 Lariat, dob 3/6/03, 6.0L auto, CC, 4x2, SRW, LB, white/parchment, 3.73LS, capt seats, 6CD, adj pedals, chrome steps, roof lights, heated TT mirrors, reverse sensors, Line-X, X-Monitor, Pullrite hitch, Prodigy controller, Ride-rite air bags, tool box, mud flaps, wheel well skirts.
2003 Carriage Cameo LXI F34CK3 5th wheel, triple slides, fireplace, 2 A/C, R21 insulation, Mor-Ryde suspension, Honda EU2000i generator, Motosat Datastorm mobile satellite Internet/TV receiver, Trailair pin box.
dminz is offline
Old 07-19-2008, 06:44 AM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Thanks.
Dean
I recommend Michelin XPS ribs for the trailer. Commercial tires with steel belts. Made in England. Pricey but I will get more than 100,000 miles on the rear tires and 70-80,000 on the steer tires.
haul_n_horses2 is offline
Old 07-19-2008, 08:59 AM   #3 (permalink)
My Photos: (27)
I agree, but I get the lesser priced Costco Michelin LTs LT235/85R16E and they do fine. My trailer came with Toyos which I also got good service from.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 07-19-2008, 04:02 PM   #4 (permalink)
The Michelins in that size only have a load rating of 3042 lbs. Any other ideas?
dminz is offline
Old 07-19-2008, 07:22 PM   #5 (permalink)
Lt265
My truck has LT265/75R/16 tires and they have a max load rating of 3415 at 80psi. You would have to make sure your rims can take the wider tire.
2002 F250 Stock PSD Crew Cab SRW pulling Same Montana as old truck
PREVIOUS TRUCK 97 F250 PSD 3.55 Draw-Tite Slider, pulling 2850RK Keystone Montana DIY Exhaust brake with TC Lockup
Autometer Tranny Guage and Pyrometer. Superchips Towsafe.
redtopman is offline
Old 07-19-2008, 11:25 PM   #6 (permalink)
spg
The Michelin XPS Rib is your best choice. I was under the impression that all 235/85R16E tires were rated at 3042#
2001 International 4700LP T444E 210HP Allison AT545 3.38
spg is offline
Old 07-20-2008, 02:44 AM   #7 (permalink)
Does anyone have an opinion on Denman's?
dminz is offline
Old 07-20-2008, 07:27 AM   #8 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Yes, but only if there is an "LT" in front of that 235. The Denman trailer tires are ST, not LT. Click on the following link, then scroll down to the last tire on the page. 3,640 pounds weight capacity @ 80 PSI. http://www.denmantire.com/catalog/22.pdf
Goodyear makes a similar trailer tire in close to that size. Marathon ST235/80R16E has a weight capacity of 3,420 pounds@80 PSI. Goodyear Marathon®
The Michelin XPS Rib is a great trailer tire, but they cost a great price too - $237.04 base price each at Sam's Club. Sam's Club - Michelin® XPS Rib® - LT235/85R16E
I have them on my pickup, but for my trailers I'd probably go with the Denmans and save a bunch of money up front. But for the F-250, I'll pay the extra and run the Michelin XPS Ribs.
I have Denman ST225/75R15E on my 16' utility trailer. And speaking of fudge factor, I need 1,500 pounds weight capacity per tire and those thave 2,830. I hate tire problems when I'm hundreds of miles from home with a trailer, which I often am. They seem to be a good tire so far. But it will be years before I can say they are as good as the XPS or the Cooper Custom Trailer Plus.
I've been running Cooper Custom Trailer Plus ST225/75R15D on my 5er RV, but I'll probably replace them with the E-rated Denmans next time I need new tires on that trailer.
...so I need 4 tires for 11,000 lbs load.
That's 2,750 pounds on each tire. The Michelin XPS would be over 10 percent fudge factor at 3,042 pounds capacity. That would be plenty for me. But if you want more fudge factor, the Denmans will probably be a good choice, as well as save you over $100 per tire compared to the expensive XPS.
SmokeyWren is offline
Old 07-20-2008, 10:48 AM   #9 (permalink)
I would check with your tire company to see it the LT265's would fit on your rims. That would bring you up to 3415. I would think a 16 x 9 rim would work.
Old 07-20-2008, 02:03 PM   #10 (permalink)
SmokeyWren's Avatar
My Photos: (33)
They won't, per the tire makers.
Almost all trailers with 16" tires will have 6" wide rims. Those rims are fine for 235/85R16 or 235/80R16 tires. But LT265/75R16 tires require a minimum of a 7" wide rim.
Old 07-20-2008, 04:10 PM   #11 (permalink)
Didn't know that Smokey. According to info I have the 235 can have a rim width of 6-9 inches while the 265 requires 7 to 10 inches.
Look at this link.
Wheel / tire size calculator / comparer - RIMS-N-TIRES
You can call up your tire and look at the different rims with that tire. Also it shows what the rim spec is.
You are probably right although it just does not make sense for a mfgr to use the low end of the spec for these tires.
My 15 inch trailer tires are about 7 inches.
Maybe it is worth a measurement before buying new rims.
On my older 97 truck I had OEM 235's and replaced them with 265's but my rims were more than 6 inches wide. Never a problem
Old 07-20-2008, 05:17 PM   #12 (permalink)
Smokey,
Just checked out the new Montana specs. They all have 16x6 rims for the 235's. What a bummer. So I guess all mfgrs are doing it.
Glad you pointed it out. If I should get a new one I will order bigger tires and rims along with 7K axles. I like a margin of safety.
Sorry dmiz.
Old 07-21-2008, 01:05 AM   #13 (permalink)
I'm real ignorant about rims. I just know I'm getting the same size tire. The approved rim width for my old tires is 6.0-7.0. For the Denman's, it is 6.5. Is that close enough or is it something I need to look into further?
I appreciate all the good advice here, and I haven't seen anything that would keep me from getting Denman's. However, I may post the same question on an RV website just to make sure. That doesn't mean that I don't value the advice I've received here.
dminz is offline
Old 07-21-2008, 10:28 AM   #14 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Per the Tire and Rim Assn. (TRA), all tires in size 235/85R16 require a rim between 6.00" and 7.00" inches wide. The Denmans wouldn't be any different. I suspect Denman picked the 6.5" wide rims to calculate their specs, but it's okay to mount those tires on wheels that are 6", 6.5" or 7" wide. Of course, if you use a different width wheel than the one they used to calculate the published specs, then the tires mounted on those different width wheels will have slightly different specs for things like C.S. and O.D. But listing the specs for all possible different wheel widths would clutter up the table too much.
The main concern for trailer wheels is max inflation pressure they are designed for. Those Denman tires can hold up to 80 PSI, but some trailer wheels are designed for a max of 65 PSI or even 50 PSI. So look at the specs for your wheels (probably stamped on the inside of the wheel so you have to dismount a tire to see the specs). Your wheels are probably fine for 80 PSI, but you'd need new wheels if you decided to upgrade to load range G tires that can have up to 110 PSI.
Old 07-21-2008, 03:19 PM   #15 (permalink)
Thanks. I replaced my wheels a couple of years ago with all-aluminum 110 max psi wheels. So I could use G-rated tires, if you recommend any of those as being better in my circumstances.
dminz is offline
