I need to find a tire with a load range at least that of stock tires, but need an aggressive AT or MT tire due to being in/out of fields with trailer.
I currently have procomp extreme MT 35/12.5x18. I love the looks and the traction of the tire, but they only lasted ~12K before they are needing replacement. I thought about the 19.5" tires, but I don't like any of the wheels that i have seen.
Please give any suggestions on tire.
Brian Moore
Brian Moore
05 F350 6.0 auto, CC, SWB, SRW, lariat 4x4
Early Broncos 66-77 from full hardcore rockcrawler to bonestock broncos.
Western NC
What weights are you towing? I will look at those tires as well.
Thanks,
Brian Moore
Brian Moore
Western NC
The trailer that get the most miles on it is a 24ft. enclosed loaded with 3 ATVs and a Rhino, 2 generators, AC, 40 gal water,toilet, tool box, compressor, spare tires and parts, etc, etc. I have never weighed it but it has to be between 8-9k and it has a lot of tongue weight. I dont have any fancy hitches and it pulls it perfectly.
I have 35x12.50 18 on my truck BFG AT and they are a D tire , but the load range in 3195#'s @ 50 psi max. I believe the stock ones i had were 3500? @80 psi and E rated Not much difference in weight cap.I love the BFG's best tire i have ever ran.
Tow Vehicle: 2008 F250 4x4 Crew Cab Manual 4x4 (No Auto 4x4 Here) Lariat Loaded, Leather, DVD player, Audiophile sound system, Memory seats, power extend mirrors, tow command system, tailgate step, bed extender, Rancho 4" lift with BFG 37/12.50 Rancho XL 9000 Shocks.
WHen I bought the Procomps, I could not get BFG ATs. I will look on BFG web site and see what the specs. are.
Thanks,
Brian Moore
Brian Moore
Western NC
Those Toyo's are tough and have heavy sidewalls. What is wrong with the ProCOmps? I was thinking of buying them and seeing you wore them out at 12K sounds insane! I got 60K out of my stock BFG Rugged Trails and 40K on my Nitto 20's and they are still good. I would cry blood if my thousand dollars in tires wore out in 12K!
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
I love my toyos got the 35x12.5x18 m/t. I have pulled 11k with a 2.2k truck camper in the bed no problem. Excelent traction in mud and snow and much quiter than many other m/t's.
I just took off a set of 35x13.5x18 Mickey Thompson® Baja Radial ATZ and at 3860lbs rateing they will handle anything!
Here are the specs. 5183LT325/65R1835X13.50R18LT127N79E3,860659.0-12.09.513.510.834.819/32
Great tires very quite unlike my 37" Toyos that I replaced them with...should have gotten 37" ATZ
Still have 85% tread left if your looking at used...PM me.
Cary
I run the BFG KO AT and Highly recomend them. I tow a lot, boat to powell in the summer and 12K 5th wheel year round.
My first set of BFGs were a load range D and I got 50k out of them before I replaced with current BFGs with the E load range. The E's do handle the 5th a bit better, but the wife hates riding in the truck empty anymore, even with the tires aired down for a better ride empty.
I dont know if you can get the BFGs in a load range E for that size wheel, but if you can I do recomend them.
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady Photos
Toyo also makes the MT's in 285/75R18 load range E. This comes out to 35.1''tall and 11.6''wide. This size is ideally suited for an 8'' rim which is the width of the factory Ford 18's. I am seriously considering this tire for my truck.
Thanks for posting about the toyo tires. That size has a 4080 lbs. weight cap., that is ~300lbs more than the Procomp.
Brian Moore
Western NC
