Old 09-12-2008, 11:31 AM   #1 (permalink)
4.30 Gear Owners, Any Regrets?
For those of you towing with 4.30 gears, is it worth it? Or is the MPG and RPM hit not worth the extra power when towing?
Driving Diesel is offline
Old 09-12-2008, 11:40 AM   #2 (permalink)
powerdome's Avatar
4.30's will be WAY too high of an RPM to take it down the interstate, and 60mph will be some pretty high rom's as well. 4.10's will work just fine and the motor is still screaming louder than i want it to
I wish i had 3.73's
2001 PSD, CCSB 4x4, 4R100, Precision Industries 1900stall TC,ISSPRO pyro-tranny-boost, Detroil Locker in rear, 35"pro-comp xterrains, 4" turbo-back to 6" stacks, Roll-bar, "Wreckers Special" light-bar, Dual In-Dash DVD, Polk Audio Door Speakers, 1200 watt Rockford Amp, 2 10" JL w1, Midland CB
powerdome is offline
Old 09-12-2008, 12:22 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Folks could give you a better answer if they knew what you're driving and hauling and towing. From other threads, I see you're talking about:
'07,F250,6.0,CC,SRW,A/T,3.73. ...close to the 23k GCWR... stock 20" rims.
For grossing near 23k with those almost-35" tires, you need at least 4.10 ratio. And if you ever tow in hills or mountains, then you'll wish you had the 4.30 rear end.
When unloaded with 4.30 gears and your tall ties, 70 MPH will be about 2,150 RPM. That's less RPM than "normal" F-350s with 4.10 ratio and 17" stock-size tires.
So for your load when towing with your truck, I'd insist on the 4.30 rear end.
But you were also talking about upgrading to a DRW tow vehicle. That's a little different because of the shorter tires on the DRWs. 70 MPH with stock-size tires and 4.30 gears on a DRW will be about 2,300 RPM. That's only about 100 RPM more than if it had 4.10 gears. I suspect your loaded to 23k MPG will be slightly better with the 4.30 gears than with 4.10, but your unloaded MPG will be slightly less. But towing a 14k 5er is serious business, so set the truck up for towing and let the unloaded MPG fall where it may.
SmokeyWren is online now
Old 09-12-2008, 05:42 PM   #4 (permalink)
lincster's Avatar
My Photos: (22)
I tow a 16,000lb 5er 90% of the time when driving my truck.
I have the 4.30 gears in my dually.
There are only a couple of hills I have to climb on my normal trip.
I am glad I have the 4.30 gears and not the 4.10s. At 2300rpm, the motor runs well there.
I don't worry about mpg as I bought this to tow and with the height of my 5er, it is like I am towing an open parachute anyway.
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... man does this thing tow, Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
lincster is offline
Old 09-13-2008, 11:12 AM   #5 (permalink)
dmd
That is when ya need 410 or 430.... Most of us can get by with 373 with
normal driving and some towing. If you drive most of the time unloaded
and tow the TT on vacation, then the 373 are usually just fine.. Towing
16k almost all the time is a complete different story..
'00 F350 Supercrewzer Lariet, PSD, Auto, 3.73, CC, 4x4, SWB, SRW, F250, Tony Wildman (Total Diesel Performance) 6-pos Chip, Custom 4-inch intake, 4-inch turbo back exhaust, ATS housing, ITP overboost eliminator / Packages: Trailer Tow, Camper, Off-Road. Overhead monitor DVD/TV/VCR (VCR under rear seat w/ 6 CD changer)
www.employees.org/~calridng (Offroad riding in California)
dmd is offline
