4.30 gears and 35inch tires - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 10-24-2012, 04:51 PM Thread Starter
I can't seem to find the perfect rpm range towing with 3.73 gears and 35inch tires. So I want to change gears. I have talked to several rear end shops and all of them recommended 4.30 gears. Just wanted to get some feed back from anyone running 35inch tires with 4.30 gears.
2000 F350 Crew cab Long bed 4x4 7.3L Diesel, 4inch procomp lift with 315/75/16 tires, 123,000 miles, 6637 air intake, zoodad mod, 4inch MBRP turboback exhaust, AIH delete, Isspro Ev2 Gauges EGT, Boost, Trans temp, DP Tuner F6 high idle, 80T, 80E, 120 Race, WW, just installed T500 HPOP, JW valve body.
renyren is offline
post #2 of 11 (permalink) Old 10-25-2012, 08:23 PM Thread Starter
Nobody has gears other than 3.73? I am trying to get real world data. I made my appt for Monday.
renyren is offline
post #3 of 11 (permalink) Old 10-26-2012, 02:37 AM
snoboy's Avatar
I have 4.30 gears. Based on the fact that my truck came with 31.7 tires and 3.73 gears I installed 4.30 gears and slightly taller 32.7 inch tires, this now gives me roughly a 4.17 final drive.
Your 35s with 3.73 gears are giving you a current final ratio of 3.38. If you install 4.3 gears and keep the 35s you'll be running 3.90s. That would be a decent ratio. my next tire will be 33.4 which should alter my final drive to apx 4.10. IMHO anything around 4 to 1 is gonna have decent get up and go.
-12/02 built 6.0
-FX4 Lariat supercab 4x4.
*Truck modifications*
-Banks turbo back exhaust
-DJs Fuel+ Intensifier fuel system
-SCT X3 DJs "tow w/ Jake brake"
-Dieselsite frame mounted coolant filter
-4.30 gears
-BD Diesel CCV kit
-Fumoto drain
-Autometer Cobalts in woodgrain pillars.
-Nitto Terra Grappler LT305/70/16
-Concept Patterns "burnished" F/R diff. covers.
-Ride-rite airbags
-KYB Monomax shocks
-Torklift Superhitch
-Current oil: Rotella T6 5w40
snoboy is offline
post #4 of 11 (permalink) Old 10-26-2012, 08:49 AM
SmokeyWren's Avatar
My Photos: (45)
The math is not hard. You can find tire size calculators on the internet, but I don't trust them to use the right math.
The change in percentage of the tire revolutions per mile is equal to the percentage of change in rear axle ratio.
Stock tires on your Y2K 4x4 PSD were LT265/75R16 with 655 revs/mile. 35s have about 600 revs/mile. Revs/mile is included in the specs for most new tires.
655 minus 600 = 55, divided by 655 = 8.4%
3.73 + 8.4% = 4.04
So the pure math answer is you need 4.04 axle ratio to have the same "feel" with the 35s as you had with the stock tires and 3.73 axle. However, the 35s are taller and wider than the stock tires, so they have more aerodynamic and mechanical drag. So you need a bit more than 4.04 to make up for that difference in drag. Therefore, 4.10 ratio should be almost perfect to get you back to the stock performance.
4.10 is a 10 percent change in ratio. 4.30 is a 15 percent change in ratio. Not a huge amount of difference. If you want more grunt off the line, or want to tug a heavier trailer up a steeper grade than the stock setup could comfortably achieve, then the 4.30 is for you.
Those same percentages will apply to engine RPM at the same corrected speed, or actual speed per GPS. So with 4.30 ratio, your speed will be 15 percent slower because of the axle ratio, but 8.4 percent faster because of the taller tires. The difference of 6.6 percent you can count on. At 70 MPH true speed with the stock tires and ratio, you will actually be going only 65.4 MPH with the 35s and 4.30. Converted to engine RPM, 70 MPH true speed with the stock setup is 2,000 RPM. 70 MPH with 35s and 4.30 ratio will be 2,132 RPM.
Not bad. If you have your speedo corrected to 600 tire revs/mile, I suspect you'll really like the new setup with 35s and 4.30 ratio. Except for the hit in MPG. The increased drag of those taller, wider tires combined with the lift is going to clobber your MPG.
But no, I don't have any seat experience with that setup.
SmokeyWren is offline
post #5 of 11 (permalink) Old 10-26-2012, 01:14 PM Thread Starter
Thank you very much. My MPG is not that good right now. For some reason my truck is happy anything over 1900 rpm. The truck has plenty power but i have to tow at 60mph out of OD or 67+mph on OD to get my rpm's up enough for the truck to not lug. The truck is not my daily driver and my future plan is to get a 5th wheel that will be 10000+lbs. Every rear end shop I talked all recommended 4.30's. They all sid for the money 4.10 is not a big enough change. I just wanted to get some real world data and I think I just got it so thank you for all your help I go in Monday and am going to go with the 4.30's.
renyren is offline
post #6 of 11 (permalink) Old 10-26-2012, 01:15 PM Thread Starter
Oh and yes my spedo has been corrected.
renyren is offline
post #7 of 11 (permalink) Old 10-27-2012, 07:41 AM
SmokeyWren's Avatar
My Photos: (45)
Then you are using the wrong tune. With 8,000-pound trailer, My '99.5 needed 60-tow to be able to cruise in overdrive at 1,800 RPM without downshifting for every little bump in the road. On the plains I could usually ease down to 1,750 RPM. But with a 10,000 pound trailer, 40-tow would probably be the best tune for towing at 1,800 RPM.
Because of the HP curve with a towing tune, you engine simply doesn't make enough horses at less than about 1,800 RPM to be able to tow a heavy trailer without constant downshifting.
Towing MPG drops like a rock when the tranny downshifts from OD to direct drive. And locking out OD when towing is a sure way to kill your MPG. So for best MPG you want to tow at the lowest RPM your engine can handle without frequent downshifting for slight grades. 1600 RPM is the torque peak, so that's the goal, but you're too low on the HP curve at 1600 RPM to have enough horses hooked to pull the load. With a stock 7.3L engine, you need about 1,950 to 2,000 RPM. You say with 80-tow it's about 1,900. With 60-tow, mine was 1,800. But with a 10,000-pound 5er, I'll bet 40-tow would be right on the money to cruise at 1800 RPM.
On mine with stock final drive ratio, 1,800 RPM was 62 MPH. With 35s and 4.30, yours should be 6.6% less, or about 58 MPH in overdrive. Any faster and your MPG will drop.
post #8 of 11 (permalink) Old 10-28-2012, 08:13 PM
Greg03PSD's Avatar
I have towed 12,000 lbs with my truck on 35" tires with 3.73 gears. The transmission downshifts on most hills but the truck never has any problem pulling up the hills. I towed about 10,000 lbs from Texas to Connecticut and I never felt underpowered, although it would have been nice to have those taller gears. I have an Edge Juice tuner and normally run it on level 3.
I think 4.30 would be fine for your situation. A 4.10 would give you the feel of stock RPM wise (as Smokey pointed out), but 4.30 will help you make up for the extra rolling resistance and aerodynamic drag. If I towed all the time, I would swap my gears from 3.73 to 4.10. Running 4.30 gears on 35 inch tires would be comparable to stock size tires on 4.10 gears - which is the gear ratio Ford installed in the higher towing capacity trucks.
Unloaded, I get around 15 mpg on the 35" tires with 3.73 gears. I didn't really keep track of the mileage when I was towing cross-country, but I would guess that towing 10,000 lbs on the same setup dropped me to around 10-12 mpg - I was having to stop more often for fuel, but I expected that with the load I was pulling.
2003 F-250 4x4, 7.3L PowerStroke
6" Skyjacker Z-link lift, 35" MT Baja ATZ tires
18" Wheels
Warn 16.5Ti winch w/ hidden mount
Front & Rear ARB Air Lockers
Dynatrac Free-Spin Front Hub Conversion
Edge Juice Programmer
Fabtech Ladder Bars
AutoEnginuity w/ Ford Enhanced package - Southern California - Just bring beer!
Greg03PSD is offline
post #9 of 11 (permalink) Old 12-04-2012, 02:29 AM
I'm glad to see you went with the 4.30's. You will be happy with them. I am running 255x85x16 and installed 4.30's a couple months ago. I could not be happier. Total curb weight is 19000-23000lbs.
2000 f250 4x4 x-cab long box, AIS intake, exhaust, ccv, zoodad, honed plenum, guages, DP Tuner with high idel, 60 tow, exhaust brake, 80 tow, 60 and 80 econ. 255x85x16 Toyo m55 and 4.30 gears.
mister is offline
post #10 of 11 (permalink) Old 12-14-2012, 12:39 AM Thread Starter
Thanks for all the help. I had 4.30's put in and so far I am very happy. Have only towed once but truck ran great and pulled good. Rpm's while towing are anywhere between 1800 and 2000 depending on speed. RPM's at 70 are 2150.
renyren is offline
post #11 of 11 (permalink) Old 12-15-2012, 11:22 AM
I re-geared a few years ago, based on Smokies advise. Running 35x12.50x16.5 BFG's, and had stock 3.73's. Same issues, always searching for the right gear and rpm while towing my trailers. Re-geared to 4.10's, and ALL is good in my towing world. Good power while towing my 13,500lb toyhauler, tranny does not hunt for the right gear, and good non-towing performance.
After the re-gear, 2100 @ 71mph, right where I was before putting the 35's on, and the power rolls on right where it was designed to.
I highly recomend 4.10's with 35's
2003 F-350 SD, 7.3 PSD, Auto, CC, LB, SRW, FX4, 4.10:1 Genuine Gear Ring and Pinions, Detroit Truetrac Differentials F&R, FabTech Ladder Bars, SuperChips 1705, EBPV delete, IH Up-pipes, Magnaflow 4" Exhaust, Ford AIS Air Cleaner, ISSPRO Boost, Trans, and EGT Guages, Kenwood DNX6160 with Nav & XM, Ford AIC, Brite Box, 203* T-Stat and Billet Housing, Tru-Cool 4739 MAX, ProComp StageII 4" Lift on Eagle 589's with 35x12.50x16.5 BFG AT KO's, Centramatics, WeatherGuard Toolbox, Rhino Liner, B&W Turnover w/Companion 5th Wheel Hitch & Firestone Ride Rite Airbags, PacBrake PRXB.
2009 Forest River XLR 3712SA ToyHauler
capt205 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
