Old 11-19-2006, 01:26 PM   #1 (permalink)
mudguppy's Avatar
My Photos: (12)
5'er or GooseNeck dolly??
Oh towing gurus.....
just wondering out of curiosity, why do you not use a dolly for pulling a 5'er or GN trailer, just like semi's that pull tandem trailers????
obviously if you had a truck this would be unnecessary, but what about an X or 2500 'Burban??? i understand it would have to be under the weight limit for the vehicle. but are there other reasons this isn't done - sway, control, or just cause backing is a royal PITA????
just a thought. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Travis
'03 F350 Dually, 6.0, Supercab, longbed, 4.10 LS, sport pkg, extremely RED, STRAIGHT PIPED, SCT Xcalibrator, full guages
- Job1 programming, Harpooned, Skweeker Mod, Zoodad Mod
- Did that thing that you're not supposed to talk about
'79 Bronco, 468cid Ford 460 marine motor, C6/NP205
Previous -'99 F250, Rg Cab XLT, 7.3/6spd, 3.73
Project truck
- '96 Cummins, 215hp/5spd, Diprocol guages, Plate & AFC full fwd, hi-capacity external lubrication system
To add: 2 1/2T axles, 46" goodyears, etc.
mudguppy is offline
Old 11-19-2006, 02:42 PM   #3 (permalink)
Re: 5'er or GooseNeck dolly??
The reason a semi can do it is first the truck weighs 20,000 pounds and the trailer on its back weighs around 30,000 pounds. While the trailer on a dolly weighs weighs 30,000. So your pulling vehicle has 50,000 pounds and the trailer has 30,000. Where you could do the same thing with an ex but if the ex weighs 7,000 and a fithwheel weighs 15,000 you can see the difference. You cant get enough weight on the towing vehicle.
Early 99 Ford F-350 4X4 Extended Cab Dually, 4 in lift, 6spd, dual 5in stacks,ts 6 stage, zoodad, ccv, tymar,
240,000 miles and counting
1993 Ford F-350, 4X4, Fuel Injected 460, MUD TRUCK, 40in super swampers, Dana 60 Front, Dana 70 Rear, 10in home made lift.
1982 Mustang 302 HO
HOURS TO BUILD, SECONDS TO BREAK
mflores is offline
Old 11-19-2006, 02:43 PM   #4 (permalink)
mudguppy's Avatar
My Photos: (12)
oh. [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]
i figured that if i could think of it someone else has already been doing it for years.
so, since i've never seen one on the road, they aren't popular?? not preferred??
Travis
Project truck
mudguppy is offline
Old 11-19-2006, 02:47 PM   #5 (permalink)
mudguppy's Avatar
My Photos: (12)
why would you need weight on the towing vehicle in this example?? if you have the proper distribution (i.e. hitch wieght) on the dolly axle and that axle has brakes, why would you need weight on the towing vehicle (if not for stopping)???
Travis
Project truck
mudguppy is offline
Old 11-19-2006, 03:16 PM   #6 (permalink)
It would be like pulling a bumper pull trailer with out any weight on the tow vehicle. It would try to throw around the tow vehicle. You will always need some tounge weight.
1982 Mustang 302 HO
mflores is offline
Old 11-19-2006, 04:15 PM   #7 (permalink)
BlueMule's Avatar
My Photos: (12)
If you look at the pics of the converter you can see that the GN ball or 5th wheel is mounted ahead of the axle. That will provide all the tongue weight you need for the tow vehicle.
BlueMule is offline
Old 11-19-2006, 04:44 PM   #8 (permalink)
BlueMule's Avatar
My Photos: (12)
I've seen a couple of them around here:
A flatbed gooseneck trailer full of new trailers with a converter behind it and then another flatbed gooseneck with more new trailers.
And a breadtruck converted into a camper towing the back half of a pickup converted into a trailer. The trailer had a GN hitch in the bed and it towed a trailer full with a sandrail and a bunch of quads and dirt bikes.
BlueMule is offline
Old 11-19-2006, 06:14 PM   #9 (permalink)
JimTJr's Avatar
My Photos: (6)
I dont think it would be safe to pull something like that with a smaller tow vehicle.
[/ QUOTE ] NOT SAFE????
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 11-19-2006, 07:26 PM   #10 (permalink)
I was up in albany a few weeks ago, I saw some old guy pulling a full blown semi trailer with dolly behind a dodge dually!!! I was at a signal light and I saw him down the road coming around a corner and I was like ***!?!?!? He even had a handicap tag hanging from the mirror. Old guy was about 90 YO.
I hope he was only going a few blocks, because since the trailer had air brakes, it would have NO BRAKES behind a pick up.
I would do it IF I was just going around the block with it and would NOT go over 15 MPH!
It's definatly a bad idea.
'93 Ford F250 w/ 7.3 IDI diesel (no turbo) E4od auto. SC/LB 2WD, but hey, got 3 attenas. retired government vehicle.
'26 tall T coupe on '67 scout frame w/400 Ford/C6
'00 Dodge Ram 1500 SC/SB w/318/5spd 4X4 3" SkyJacker lift 33-12.50X15 Perreli Scorpions
'01 Dodge Ram 1500 Quad cab/SB w/360/auto 4X4 NO LIFT!!! Running 33-12.50X15 Hi-Tech-Retreads with Green Diamonds (alternative to studs!) on saw blade chrome wheels.
'62 Caddy 2dr, "slammed" with air bag suspension. I can literaly set it on the ground!!!!
'48 CJ2A w/'61 over head valve engine
'77 Chevy Caprice, rare 2 door! Built 350 4 bolt mains. Weyand high ram intake, Headman Headers, dual glass pack "cop callers", TH350 with high stall converter and B&M "street/strip" kit (churps the tires hitting 3rd @ 90MPH!!!!)
'84 AC 5040 w/ loader
'71 Dodge D200 w/'69 vette 327 & powerglide
'97 Morgan built 20' tilt car hauler
'01 Morgan built 16'cattle trailer
Ford 9N
Ford 8N
JD model 40C crawler
shitface is offline
Old 11-19-2006, 07:37 PM   #11 (permalink)
I would want it to be way further forward than in the pic!
Ford 9N
Ford 8N
shitface is offline
Old 11-19-2006, 10:06 PM   #12 (permalink)
BlueMule's Avatar
My Photos: (12)
WHY?
How much weight do you think needs to be one the tow vehicle?
How far do you have to slide a 5th wheel on an 18 wheeler to get the weight off the drivers and up on the steer? It doesnt take much. Its the same thing. As long as the pin or ball is forward of the axle it will transfer weight to the drawbar.
It's not like a pull trailer where no tongue weight equates to to much weight behind the axle and the tail wags the dog.
BlueMule is offline
Old 11-19-2006, 11:02 PM   #13 (permalink)
WHY?
It's not like a pull trailer where no tongue weight equates to to much weight behind the axle and the tail wags the dog. <font color="red">Really? I think the dolly is a trailer in &amp; of it's self, seems to mee it needs plenty of tongue weight? </font>
How much tongue weight do most 5th wheels or GNs have? 1500lbs? Seems to me like I'd want about 750 on the truck hitch &amp; 750+ the dolly axles own weight on the dolly tires. I can think of a few places where the trailer would push you right off the road with out having enough weight on the rear tires. I don't know? Just my opinion. [img]/ubbthreads/images/graemlins/confused.gif[/img]
Ford 9N
Ford 8N
shitface is offline
Old 11-20-2006, 04:54 AM   #14 (permalink)
BlueMule's Avatar
My Photos: (12)
[/ QUOTE ] No! It doesn't. Look at the dolly thats used to pull a set of thruway doubles. A tandem axle bogey is completely freestanding and the only weight on the pintle of the lead trailer is the weight of the drawbar itself. Or how about the draw bar on a transfer dump. Again the only weight on the hook is the drawbar weight and you have to pick that up with one hand while you back the truck up to the trailer.
[/ QUOTE ] Thats 50% of the weight you want to transfer to the tow vehicle. I think thats way to much. I wouldnt want more than 10-15% The whole purpose of they dolly is to convert it the trailer from a "semi" to a full trailer so that all the lead vehicle has to do is provide the means to propel and steer it.
BlueMule is offline
Old 11-20-2006, 09:18 AM   #15 (permalink)
I dont know about you, but I dont want 15,000 pounds hook to the bumper with only 750 pounds of tounge weight.
1982 Mustang 302 HO
mflores is offline
