5th Wheel Hitch - Diesel Forum - TheDieselStop.com
Old 04-08-2006, 06:02 PM   #1 (permalink)
5th Wheel Hitch
Hello,
I have been pulling a 33' travel trailer for about 3 years now. I am in the process of trading it in for a 5th. wheel. Who makes the best 5th wheel hitch and why. The trailer will weigh about 13000 lbs loaded.
Thanks,
Rick
2004 F350 KR,LB,SRW,4X4,18" wheels - Loaded,
Added: Line-X, Isspro EV gauges, Prodigy, C-BETR mirrors, Huskey liners, PIAA-1500 Back-Up, Rancho 5406, RETRAX, Fumoto, XM Radio
RootDoc is offline
Old 04-08-2006, 09:23 PM   #2 (permalink)
Re: 5th Wheel Hitch
Well, most would say it's a matter of preferencs, but I like my B&W. You have the option of a gooseneck, and when you remove the adaptor, it's flush with the floor of the bed. Also very durable, and reliable. I believe all the big names such as Reese, and Draw Tite and Putnam make quality products. You just have to figure out which one suits your needs, and how much you want to spend................Dave
Dave
11
#3
FOREVER THE MAN
LEGENDS NEVER DIE
1997 F350 CC DRW 4X4, Black. Centaurus2 conversion. Banks IC & powdercoated tubes. Stage 2's by Full Force Performance,BDP Dom 66, BDP Fuel system , TS 6 pos chip with Bills & T Wildmans burns, AFE intake, 4" exhaust. Gear Vendor Overdrive. E4OD with Suncoast Pro-Loc TC, 4.10 gears. Sky's RSK, Kelderman air ride, Bilsteins, 40 gal Transfer Flow. Alcoa's. Pioneer stereo, full floor and overhead console.
As of now 391 & 740, Going for 400
pictures > http://community.webshots.com/slides...986&key=uYblzs
97Strokerman is offline
Old 04-09-2006, 01:36 AM   #3 (permalink)
Re: 5th Wheel Hitch
I was considering a companion type hitch, but then I got to thinking, now I have to worry about 2 connections and since I don't really need a gooseneck hitch what's the sense?
One thing I would say is bigger is better.
I just broke a 15K Eaz-Lift hitch when I was down in Loisiana in Feb. The hitch has been in the truck since new and never gave me a problem. The welds let go on the square tubing that braces the yoke. What I figured happened was, I got cut off just north of Daytona and I hit my binders so hard I split a brake line. I think that might have weakened the welds on the brace, anyway by the time I got into New Orleans, after pulling out of a fairly rough parking lot in a truck stop, right away I noticed that my trailer was dog tracking about 2-3' to the left, got out, thinking I broke a shackle or something on a trailer axle, it was caused because the yoke holding the 5th wheel plate was leaning to the left, severely. It's a wonder I didn't drop the trailer into the back of the truck pulling out of the truck stop.
At any rate, if I were buying a new one, I'd be going with at least a 24K leaning more towards a 30K. And get one that will drop into common sized bed rails, just in case you need to replace it. My bed rails for example were spaced 1/2" wider than a Reese.
I couldn't find one to fit in Louisiana, but I was fortunate enough to get a exceptional welder to repair mine up and it got me home. I was looking at about $1400.00 to have a new one with new bed rails installed, but I got lucky and found another one Eaz-Lift (they were discontinued about 5 years ago), so I'm going to really brace and build the one I found up.
At any rate, I'd like to mention if it wasn't for Kenny over at Camping World in Hammond La., I don't know what I would have done. He and the folks at Camping World were nice enough to find me a campsite for the night, and Kenny came over with his truck and towed my trailer to Punkin Center Campground, so my wife and I had a place to stay while we figured out what to do with my hitch. Kenny wouldn't take anything for his troubles, all he asked was if I ever seen him broke down of the side of the road in Canada, to pull over and help him, or any other camper for that matter, that was in trouble. Kenny, the people over at Camping World and Punkin Campground restored my faith in humanity, I'll till you. I highly recommend them to anyone and if anyone's in their neck of the woods, and are talking to them, say hi to them, from Randy in Canada, would you please!
One thing for sure, I'll be doing from now on, is, everytime I stop for fuel or what have you while towing, I'll be checking my hitch over with a fine tooth comb, looking for metal fatique, cracked welds, etc., etc... That's why I'm saying, the bigger, the less likely that's going to happen, it's when you get into extreme circumstances like I had braking, that takes it's toll on equipment.
1995 F-350 XLT Crew Cab Dually 5 spd - Basically Stock - Used everyday for work & play (pulling 1989 36' Airstream Landyacht 5th wheel around the countryside to stock car races). I've owned the truck since new. I'm fortunate enough to be the 4th owner of the Airstream.
Randy
CascarFan is offline
Old 04-09-2006, 07:54 AM   #4 (permalink)
Re: 5th Wheel Hitch
Most hitches are pretty much the same with a few exceptions. PullRite slider is certainly different. It is an autoslider and I believe still unique in the field.
Some have different latching mechanisms - many claim what they have is best. Gain an understanding of how each latches and thoroughly know how yours works - how to properly hitch - whatever you select.
Here is a page of links for almost every mfg out there.
http://members.cox.net/bruce.wittmei...elHitches.html
Bruce & Carolyn Wittmeier
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, DP-Tuner 40/80/120HP, Chrome Step, Line-X bedliner, Jordan Ultima 2020, AirLift 5000 Airbags, DiPricol gauges
wittmeba is offline
Old 04-09-2006, 03:03 PM   #5 (permalink)
Re: 5th Wheel Hitch
Assuming you have the tow package (wiring to rear bumper) there should be a connector behind the fuse panel and behind the vertical cross member on the right side of the opening. You almost need the cable to know what the connector will look like in order to find it...its not easy.
Once you locate that, the other end just connects to the brake controller of your choice.
wittmeba is offline
Old 04-09-2006, 04:32 PM   #6 (permalink)
Re: 5th Wheel Hitch
Get a hitch that pivots sideways and back and forth so when you are hooking up the truck and the trailer will not need to be level. If you want overkill for your trailer I would suggest 18000 to 20000 hitch rating. If you are old like me get a hitch that comes apart in pieces so when you want to take it out or put it in the bed it will be easier. I use a 20000 lb rated reese hitch with a 16000 lb 5th wheel with eccellent results. The only downside to most 5th wheel hitches are the rails don,t come out of the bed. good luck.
Y2K 350 DRW PSD Lariat CC LWB 4.10 auto trans, TLS, Mag-Hytex Diff cover,Amsoil in Trans and Diff, Pillar mounted Spa tech dual gauges, aux trans cooler.Fumoto oil drain valve. Oil Guard bypass filter. AIS, 3 1/2 down 4 inch ex
Coolinthem is offline
Old 04-10-2006, 09:06 PM   #7 (permalink)
Re: 5th Wheel Hitch
I see a lot of adds for Mor/ryde,TrailerSaver by Hensly, Super 5th by Pullrite, and 5th Airborne by fabex. Does anyone have any knowledge or experience with these? Are they worth the extra money?
Thanks,
Rick
RootDoc is offline
Old 04-11-2006, 12:43 PM   #8 (permalink)
My Photos: (9)
Send a message via ICQ to RonRosewall
Re: 5th Wheel Hitch
I have been using an RBW hitch for the past 8 years and have had no problems with it. I keep it covered with a Truxedo roll-up cover when not hitched up. So it doesn't see the weather as much as some and is easy to take apart and remove from truck with one person.I have been impressed with it and others have came up to me and asked how I was able to hook up so easily and quick.
'06 F-350 DRW CC King Ranch 4x4, True Blue over Arizona beige w/8 foot box, 6.0-PSD, 5SPD TORQSHIFT, 4.10LS, Line-X, Remote start.
Pulling 3685FL Montana 5th wheel
(SOLD)'04 F-350 CC King Ranch 4x4
(SOLD)'00 F-250 CC Lariat 4x4
My Pics
RonRosewall is offline
Old 04-13-2006, 02:12 PM   #9 (permalink)
Re: 5th Wheel Hitch
I too have the RBW Li'l Rocker and would recommend it.
2002 F350 4x4 CC DRW Lariat 7.3 auto 4.10 LS diff.(bought 5-05 @ 76,000 miles) Pyro, Boost, and Trans gauges. AIH delete. Tru-Cool Max trans cooler. Magnafine filter. Royal Purple MAX synthetic ATF. 55 gallon aux bed tank. 2LO Mod.
2002 Holiday Rambler 30-SKS Alumascape fifth wheel
24 foot gooseneck livestock trailer
1940 McCormick Deering restored Farmall H, used weekly (the grand-daddy of International)
Used goats for rent
twobit is offline
Old 04-14-2006, 10:38 AM   #10 (permalink)
Re: 5th Wheel Hitch
I have the Pullrite Super 5th and the Super Rail system in mine. It is the best out there in my opinion for several reasons. No drilling to the frame. It uses stock holes and laminates the frame for strength. 4 holes in the bed is all you have when you take it out. The bed is completely flat and just as usable as stock when the hitch is out. Great latching mechanism that has been laser cut to virtually eliminate pin slop. The latching mechanism completely surrounds the pin so that there is no guessing if it is fully secure. 4 way pivoting head. You will pay more for it than other hitches but you get what you pay for.
sandjunkie is offline
Old 04-16-2006, 02:46 AM   #11 (permalink)
Re: 5th Wheel Hitch
I will second what Sandjunkie said. Pullright, Reese Signiture series, B&W, and a few others out there have better hitches than most.
I pull using a Reese 16K 4 way with the jaws that come together in the middle. I have a lot of Pin Slop in it. I am looking at a replacement also. I saw what can happen when the jaws come open. It wasn't good to the truck or trailer.
No matter what brand you get, look for one that the jaw(s) circles the pin. It will keep the Pin Slop from happening. It also is a safer hitch. It won't let go as easy as the other styles.
I am looking at the Reese Signature series with the pins that lock into the bed. I currently have rails in the bed and they can make hauling items a pain in the _ss. Its hard to keep the bed clean also.
The Pull Right is a good hitch but a costly one. At 1400.00 in Northern Calif. its mighty high. The Reese is a bit lower around 900.00 . The B&W is a goose neck hitch in the bed that comes out leaving the bed clear but you have to buy the fifth wheel hitch which is seperate( 500.00+) from the company for a total of about 1300.00 .
I am still looking for a deal on a good hitch. If anyone can recommend a good place for a deal let us know. Good Luck and good hauling. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1999.5 F350SD CC 4X4 Lariet LB, Auto w/John Wood Trany UpDate w/ 6.0 TC, Mag-Hytec trans pan, 373's, Vision 19.5 wheels w/ Toyo 245/70R19.5 "G" load rating traction tires, Superchips 1700 MAX Tuner, Triple Gauges on A piller, SP Airfilter Mod, SP exhaust brake, Banks cat back 4" exhaust, HX Hose mod, Rancho RS9000Xs, 2.5" Level Kit on Front, Slotted drilled rotors on front axle, Racor CCV Filter, coolant and trans filtration, 203* therm., Derale Trans cooler w/180*Therm.& fan. Headlight harness conversion w/ 2004 headlights & Silverstars
Towing a 30 ft. Holiday Rambler Alumascape 5th wheel with a Reese 16K hitch.
-IAFF Local 2881-CALFIRE- Retired 2-06
jcbenson is offline
Old 04-16-2006, 09:12 AM   #12 (permalink)
Re: 5th Wheel Hitch
JCBenson Check online prices. I got my pullrite with super rails for about $700 shipping included. It looks like the prices have gone up a bit since last summer and it would run about $900 now.
rv supply warehouse
Old 04-17-2006, 01:03 PM   #13 (permalink)
Re: 5th Wheel Hitch
To SandJunkie: Thanks for the tip. Great Prices. Locals are a rip off. Thanks again. JCB [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
jcbenson is offline
Old 04-26-2006, 12:11 PM   #14 (permalink)
Re: 5th Wheel Hitch
i got the reese signature 18k slider.... pivots both ways and i love it
i did my own install to save a couple bucks
try www.hitchesonline.com i save frieght because i live about 8 miles from the place.... just my 2 cents worth
2006 F250SD 4X4 Extended cab short bed 6.0 Lariat 6 speed manual
all stock for now
DA28 is offline
Old 05-03-2006, 06:42 PM   #15 (permalink)
Re: 5th Wheel Hitch
Well I'll be differant. I had (still have out back) a reese. I have switched to a Trailersaver by Hensley. Everything rides smoother, they are built with a Holland Binkley head , the best in the business IMOHO. The jaws are thicker, it works smoother, and when it is locked it is locked ( no levers or anything to flip to keep it locked). The down side is you are going to pay, $2200 last time I looked, but I would spend it again, but glad I don't have to. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Tom
2003.25 6.0, Born 2/03, 5R110W, XLT Dually Super Cab 4X4, 4:10LS, AIC, full set of gauges, Line-X Bedliner, Full MBRP exhaust, New turbo 5/3/05, 6 injectors (1,2,3,4,5,7,) 12/29/05, Inductive flash 3/8/07, .
2004 Titanium 5th 28E33, 2 Honda EU-2000's.
TC88 is offline
