Just wanted to drop a note on my new 5th wheel hitch.
I got a Curt MFG Q5 slider 5th wheel hitch, 20K rated.
I could not be happier with it!
I works awesome and was an excellent value.
Hitch with slider and mounting rails was 749.00 plus 149.00 install. And Layton Truck and Equipment did an outstanding job on the install.
Now I know that 20K is overkill for my 8k trailer. But the Curt 20K hitch was less money than the Reese and Drawtite 16K sliders were here in town. Plus the 20K slider is beefy. Also the hitch itself has a unique design that I really like too.
Check out their web site for more information. Curt
I orginally wanted their 16K hitch the E5 but Layton does not stock it so it would have only saved my 50 bucks. However on the web the E5 slider was going for 549.00.
Anyway not a brand I have seen mentioned here and wanted to share my experience.
Tim
2001 F-250 Crew Cab, short bed, 4x4, 4R100 with VB tuned by Travis's Automatic Trans, Lariat, Snugtop shell, Line-X bedliner, 265/75/R16 GY Silent Armor. DIY open element air filter. DIY 4 inch exhaust, from stock DP back to 45 degree turn down. Quadzilla Recon XZT moniter- EGT, Trans temp, Boost. DP tuner Stock, 40T, 40T high altitude, 80E, Curt MFG Q5 20K slider hitch, P3 brake controller, ATS housing. Blue Bullet
Sold-- Bright RED 1996 F350 XLT, 4X4, CC, 4.10 gears ,E40D, SRW, Rebuilt E40D at 190K with a 3yr/36K mile warrenty, by Travis's Auto Tranny 719-574-8104. Big Red
Proud Member of the NRA, helping to protect our American Rights!
Looks nice, you can't go wrong with more weight capacity than you need. And if you buy a heavier trailer later on then you won't have to buy another hitch.
The plate almost looks like a Binkley/Holland. I really like the B/H and have a 32K head that's mounted on a 4" gooseneck tube for an inverted 5th wheel set up. Been thinking about converting it to use in my truck. Someday.
CaptRon
May 2003 F-350, CC, DRW, 6.0L, 6sp man, LB, Al Wheels, Moon Roof, 52gal tranfer tank. Hitches: Draw-Tite 16K 4X and B&W GN, 8040lbs GVW. Towing 35' Newmar Kountry Star 5th Wheel Camper, 14,000lbs GVW, or Wells Cargo 24' Car Hauler, 12,000lbs GVW.
'Looks good. I went with the Superglide in my sig mostly because of the narrow street that I live on and stabbing that long rig into the driveway. I went with the 24k capacity (overkill) because I thought the 16k was borderline for my 14,000 rig and the 18k Superglide hadn't come out yet.
Ain't these sliders great!
2005 F-350 Lariat, 6.0 PSD, Torqueshift auto trans, crew cab, SRW, short box, FX4, ESOF, limited slip dif., tow command, upfitter switches, 6 CD changer, Lariat Lux. package, camper package, engine block heater, adjustable pedals, reverse sensor, triple A-pillar gauge set (Autometer) with pyrometer, trans temp & voltmeter, MBRP 4" cat back exhaust w/5" dual wall chrome tip, dark shadow gray/ med. flint interior.
2008 Big Horn fifth wheel by Heartland RV model 3670RL. 38' long, 4 slides and all the goodies.
I went with the Air Hitch Technology 25K hitch for my 15,000# 5'ver. I can't say enough about how great this hitch is. It takes all of the bounce, banging and roll out of towing and makes it much easier on the trailer, the truck as well as me and the DW.
DRDON
2008 F350 Lariat CC PSD 2WD Auto. 172" Dark Blue Pearl Clearcoat Metallic/Pueblo Gold 5"Chrome CabSteps Camper Pkg. HD Alt. Tow Command Upfitter Switches, 25K Air Safe Hitch, Retrax Cover, Timbrens, WOLO 120 db air horn, and more.
2007 Ameri-Camp Summit Ridge Reserve 40' 5th wheel trailer, 3/Slides, chrome wheels, Mor-ryde suspension, dual A/C, theatre system, solid surface counter tops, king bed, power jacks front/rear, 50 AMP service, sealed underside, heated tanks and more. MY PICTURES: http://good-times.webshots.com/album/558384049kmtqSi
