I am in search of some two inch blocks to lift my 5er so that it will be level when I am hooked to my lifted truck. Does anyone know where I can purchase these blocks. The leafs under the trailer are only 1 1/2" wide so truck blocks will not work unless I have them cut down. Any info would be appreciated. Thanks again.
Early 99 F-250 4x4 c/c sb, 4" pro comp leveled, 6 rs 9000's,35's on weld typhoons, bushwhacker flares, 4.10's, 6.0 cac,tymar, 4" s/s exhaust, dp-tuner F-5 programming,BTS valve body, isspro gauges, ranchhand front, alpine 400w system in cab,33' denali 5'er.
If you don't have your axles "flipped" the blocks will not help you.
2001 7.3L F450 4x4 CC Automatic Fontaine Conversion 4:30 Limited slip Reyco Granning Full Air Ride Supension, Transfer Flow Fuel System, 4" MBRP turbo back, gages, pryo pre turbo.
Build Date 03-12-01 in KY. Towing a 34 foot Thor Tahoe toy hauler 5er.
2004 F250 CC SB XLT 6.0 Automatic Gauges Big Walker Truck Muffler towing a 23 foot American Freedom with a buggy inside
The leafs came on top of the axle from the factory, so I need blocks. If they had been on the bottom like the saleperson told me they were I would have just flipped them. I should have looked for myself instead of listening to a salesperson.
If you are close to a metal slavage yard , buy the size blocks you want. If you can, drill the correct hole throuh the center. you will also need a pin to locate on the spring pearch, probably take the one out of the existing blocks. Then get longer u-bolts and install.
I did just as Oldman said to do, I went with aluminum bar stock and cut the blocks to size and drilled the pearch hole. Using aluminum was fine on the trailer because there is no power being applied and it is easy to work with.
2005 F-350, 6.0 PSD, Lariat,4x4,CC,LB,Torqshift,7" ProComp StageII Lift,MX-6 Reservoir 6 Way Adjustable Shocks, 37" BFG M/T, 18" Mazzi Hulk Wheels, Duel Steering Stabilizers, 6 Piece Billet Grille, Isspro 3 Guage A-Pillar, AFE SS 4" Turbo Back Exhaust, 4:56's, Firestone Air Bags, SCT by ID
I went to the local spring\suspension shop and purchased some 2" blocks and longer u bolts for my fiver. I also changed out the tires\wheels from 225-75-15 to 235-85-16 load range E truck tires which gave me close to 2".
2001 F250 cc 4x4 PSD, Monster Box tranny,Tru-cool cooler,AFE Magnum Force,ATS turbo housing,DP Tuner 3pos chip ,4" Magnaflow exhaust,Isspro gauges,4" lift,Donahoe Racing front shocks,Bilstien rear shocks,33" Firestone Destination MT's on 16x9 Weld Sidewinders,Bushwacker OE flares,Warn winch mounted on Warn Trans4mer,Viar on board air, Reese 16K 5th wheel hitch,Timbrens, Prodigy brake control,Alpine stereo w\amp and JL Audio subs.Protected by a Viper alarm.
I went to a metal shop and had the right size blocks (width & lenght) made out of solid steal. I did'nt feel comfortable with those casted aluminum blocks with 9K-10K #'s on them. I drilled it and and use a grade 8 allen head bolt and bolted it to the spring. The allen head was the perfect size for the perch locating hole. Get longer u bolts and your good as gold.
Good Luck
Big E
Big E and family of Three
2002 F250 4X4 CREW CAB PSD 4" LIFT
4" turbo back exhaust*custom tymar*DP tunes*Polished ATS housing*6.0 intercooler*Chromed intercooler pipes*H/O chromed Alternator*Dieselsite boots*203 thermostat*40K Trucool*FTVB*Manual TC lock-up*EBPV brake*AIH delete*boost Annihilator*Custom CCV*ITP/KCM (HPX)*Coolant filter*08 diff cover*DI fuel shim kit .055 @68 psi*engine mounted fuel gauge*custom engine cover*triple gauge*((XM))
297Hp dyno 2/11/07 (I need more power Scotty!!)
Waiting for install
pre-pump mod
2004 Keystone Sprinter 297fwbhs 5th wheel
with most of the goodies
Just wanted to say thanks to everyone for all the info. Decided to buy some stock material and build my own. Was just on a time crunch to get it done and thought there might be someone out there that sold them. Thanks again. VH
