Old 12-16-2007, 05:31 PM   #1 (permalink)
TLG
5th wheel towing with 20inch tires
Thinking about taking the plunge, but can't seem to find any Super Cab lariets within a 100 miles. Have located a few FX4's, but they all have the 20 inch tire option. It sure makes that rear end look high. Was wondering if anyone has installed a 5th wheel hitch in a 350 with the 20 inch tires. If so, how much adjustment did you have to do? Thanks
2008 F350 CC LB. 6.4 Lariet SRW
2007 Montana Mountaineer 329RLT 5th wheel
2008 HD Electra Glide Ultra POSE
TLG is offline
Old 12-16-2007, 06:49 PM   #2 (permalink)
Re: 5th wheel towing with 20inch tires
The 20" wheels actually come with tires about the same height as the tires that come on the 18" wheels.
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
My Pictures
DD- SILVER 11/97 F350HD XLT RCLB Auto 3.55LS 4x4 OFFROAD
Mods: Redneck straight-pipe, TS/2L Moto chip.
smokyred is offline
Old 12-16-2007, 07:04 PM   #3 (permalink)
MDarrough's Avatar
My Photos: (18)
Right, overall diameter is very close.
'08 F-350 CC 4X4 Lariat, SRW, Dark Blue Pearl w/Silver trim, every option but Nav and moonroof.
Ordered 10/16 - Born 11/14 - delivered 11/26
pic
Pulling a 2008 Jayco Eagle 5er - pic
SOLD - '01 F-350 - pic
MDarrough is offline
Old 12-16-2007, 10:09 PM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Close, but still a difference.
F-250 Lariat 4x4 stock tires will be 275/70R18, 627 revs/mile, 33.2" diameter.
Optional 20s would be 275/65R20, 605 revs/mile, 34.1" diameter. That's almost an inch difference in diameter, and 3.5 percent difference in revs/mile.
Converted to something meaningful, when the F-250 with 18" tires was cruising at 1,900 RPM, the one with 20s would be cruising at 1,833 RPM at the same speed.
The static loaded radius of the 18" tire is 15.54". The static loaded radius of the 20" tire is 15.93". So with everything else being equal, the difference in the height of the top of the tailgate would be 0.39", or almost a half inch.
SmokeyWren is offline
Old 12-17-2007, 04:33 PM   #5 (permalink)
scottbob99's Avatar
I tow a Sundowner 10' LQ trailer with my F350 with factory 20's. No problems, see picture.
Truck and Trailer picture
2006 F350 Lariat Crew Cab 4x4 LWB SRW 6.0 Auto, with Tow Command and 20's.
Member of AMA, NETRA, NEMX, AQHA and NERHA
scottbob99 is offline
Old 12-17-2007, 07:57 PM   #6 (permalink)
SmokeyWren's Avatar
My Photos: (33)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: scottbob99</div><div class="ubbcode-body">I tow a Sundowner 10' LQ ... </div></div>
Surely that's a typo? That looks like a forty footer to me. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
Old 12-17-2007, 09:50 PM   #7 (permalink)
Hook'em Horns!'s Avatar
That's one dang long 10 footer!
2005 Chev Duramax/Allison 3500LS DRW Crew Cab
B&W 30K-Turnover GN, Putnam XDR 15K, A/T Revos
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 9'Flat-GN
A/T Revos
DON'T STEAL! The Government Hates Competition
Hook'em Horns! is offline
Old 12-19-2007, 10:56 AM   #8 (permalink)
scottbob99's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Hook_em_Horns</div><div class="ubbcode-body">That's one dang long 10 footer! </div></div>
It has a mid tack also, I left that out as most non horse people don't know what that is. It measeures 36.5' tip to tail!! [img]/forums/images/%%GRAEMLIN_URL%%/eek.gif[/img]
Old 12-19-2007, 11:31 AM   #9 (permalink)
SmokeyWren's Avatar
My Photos: (33)
So now I assume you meant that the LQ part of the trailer is 10'. Most horse trailers with living quarters (LQ) have an 8' to 12' long LQ and the rest of the trailer is for tach room and horse stalls. Some have an even bigger LQ part of the trailer. Sundowner makes one with a 17' LQ, tripple axles and over 40' long. It requires a "real truck" to tow that one. [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Old 12-20-2007, 07:53 PM   #10 (permalink)
96STROKE's Avatar
My Photos: (6)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: TLG</div><div class="ubbcode-body">located a few FX4's, but they all have the 20 inch tire option. It sure makes that rear end look high. Was wondering if anyone has installed a 5th wheel hitch in a 350 with the 20 inch tires. If so, how much adjustment did you have to do? Thanks </div></div>
Man, I have NEVER seen a F350, or in fact any full size ford truck with 20" tires!!! [img]/forums/images/%%GRAEMLIN_URL%%/crazy.gif[/img] My work car has taller tires than that. [img]/forums/images/%%GRAEMLIN_URL%%/cool.gif[/img] 20" tires are bearly bigger than the brake rotors. I quess the plus side, is there would be next to no rubber, should be very cheap tires, exactly what load rating are these tiny 20's? And does this tire size option come with a very tall rear end gear ratio or is the top speed approx 38.5 MPH???
I would recomend going with 18" or 20" WHEELS and then 33"-35" TIRES. [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady
Photos
96STROKE is offline
Old 12-20-2007, 09:47 PM   #11 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 96STROKE</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: TLG</div><div class="ubbcode-body">located a few FX4's, but they all have the 20 inch tire option. It sure makes that rear end look high. Was wondering if anyone has installed a 5th wheel hitch in a 350 with the 20 inch tires. If so, how much adjustment did you have to do? Thanks </div></div>
[img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img] </div></div>
How about some 22.5" Tires and Wheels:
A/T Revos
Old 12-20-2007, 11:21 PM   #12 (permalink)
u2slow's Avatar
My Photos: (16)
If they end up too tall.... have you thought to horse-trade at an autowrecker? Or just buy 17" take-offs? Maybe they will even swap them around at the dealer for you?
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw
u2slow is offline
Old 12-24-2007, 05:00 PM   #13 (permalink)
Lightningfast01's Avatar
If it has factory 20's it probably has the light rear springs. I added air bags for a customer that hauled a 5er with 20's. The light rear leafs were losing the battle. I haul on 17's when I have the choice.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
Old 12-24-2007, 09:56 PM   #14 (permalink)
Do it..
2007 Designer, 2008 SRW F350
Pics
Makes the truck look small dont it??
1970 Cyclone Spoiler 429CJ,
1970 Cyclone GT 429CJ,
1979 E150 Van (Daily Driver)
1979 Fairmont
2008 F350 Superduty Lariet 4x4, Built 4/23/07. Jayco Designer Fiver, 36'
Traded: 2005 F350 SuperDuty Lariet 4x4 Crewcab LWB.
1970Cyclone is offline
Old 01-28-2008, 05:12 PM   #15 (permalink)
Old Mose's Avatar
I pull a 30' 5er w/no problems. Just hook it up & go.......and definitely get the 20's!
RJ
2008 F-350 Lariat 4x4 LWB Crew Cab, 6.4, Auto Trans, Job 2
NRA Life Member
Old Mose is offline
» Site Navigation
» Home
 > FAQ
