I have a 96 with a 7.3. I was thinking of upgrading to a newer 7.3. My Dad offered to sell me his '06 6.0. I plan on towing a camper quite a bit. Probably a larger toy hauler. I'm just wondering what peoples opinions are on towing with a 7.3 vs 6.0. Is there any benefit versus the larger displacement to the smaller displacement. Or is the more power with a smaller package a better deal? Thanks for all info.
GO !
I think most will want more information. How much have you been quoted for the engine replacement? How much does your dad want for his 06? How much to you like your truck? How much do you like your dad's truck? Are they the same F250/350, CC or EC or SC, SB or LB? It's your money so remember that too.
2000 Ford F250 PS 4x4 long bed.
build date - 7/31/99
Truck mod(s) - performance
4" MBRP, TS 6 Pos.Chip (valet,hi rev, 50, 75, 100, OMG), BTS Valve Body, AFE Stage 2 Pro Guard 7, ISSPRO Guages, 203 thermostat, AIH Delete, Wicked Wheel, Edge EZ, ball joints with grease fittings, Detroit lockers front and rear.
Thanks to DPPI, Diesel Site and Heavy's Customs
interior/exterior dressing -
JVC stereo and speakers, Ranch Hand brush guard, TSC over the rail tool box, HiJacker 5th Wheel Hitch, Tekonsha Voyager, Down Underseat-Holding Apparatus
WARNING - Poweraid 400-595 is junk (my experience)
Soon - BTS Transmission and Torque Convertor, mud flaps
The 6.0 IMHO is not reliable enough for me to own. Since its your dads truck I would assume that you know what all has been done to the vehicle since he bought the truck. If the truck has been in the shop alot I would avoid it. If he has had really good "luck" with the truck that would be the only 6.0 that I would consider buying. I'm personally a big fan of the 7.3. Its a more reliable motor, Ford didn't keep it around for 10 years for no reason.
99 F-350 DRW Lariat 7.3 Auto- 280k,DP handheld tuner, no cat - Wrecked in Springfield, Missouri RIP, you will be missed!
1987 Mustang GT Cobra Clone- crate motor, and more suspension than I know what to do with
03 F-350 DRW Lariat 7.3 6-Speed 4 inch ProComp lift LT315/75R16, 3 in. spacer between duals.
Banks Monster Exhaust, w/Turbo Elbow
AFE Stage 2 Cold Air Kit
DP 80econ,80tow
8,200lbs---Cat Scale---Thats me and a full tank of fuel
My truck is a regular cab L/B, my Dads truck is a C/C S/B. The S/B is the only draw back to the truck. It runs fine, and he's had no problems with it. I should have been more clear on upgrading. I was going to move to a newer year truck. So I guess there isn't much difference between using a 7.3 or a 6.0 engine to pull with? Both do a good job? My old 7.3 did a heckuva job pulling a 15k fifth wheel camper. I don't have much experience pulling with a 6.0, so that's why I'm asking.
The 6.0 will tow MUCH better than the 7.3.
I had a 02 F250 and moved to a 04 F350. Hands down the motor had much more pulling power.
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... man does this thing tow, Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
If the truck has had no problems, the 6.0 & Torqueshift are a good towing combination. The trans has a much better cooling system than the 7.3s did and the tow/haul works well.
If coming from a 7.3, it will take a second or two longer to start, and will NOT need any additional power mods to make it better. If you feel the need to mod, gauges, and a 4" cat back are best. No new intake, no tuner needed.
I love my 03 & its fine stock.
OMC
The 6.0 will be fine until the warranty is gone. You can of course buy a 200K mile warranty. All the people I know with 6.0's have had trouble. One 04 is on it's third motor, another 04 had it's head gaskets fail at 15K miles and an 05 had a motor fail at 35K miles. My Uncle bought a used 04 and by 50K miles it had been in the shop 4 times. The past 30K miles have been trouble free though.
Most 6.0's bet better fuel mileage than the 7.3's and have more power so it's a win win. Diesel fuel at $4 a gallon with gas at $3 a gallon makes you wonder if a V10 would be a good buy.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
What if you kept the money you'd spend on the new truck and put half of that into mods for your old 7.3? $5000 would have your old truck running laps around the new 6.0 and you'll be spending a whole lot less and turning heads while your doing it...not to mention I'm a 7.3 believer.
i have had both a 95 stroker, a 96 stroker, 01 stroker , and then bought a 05 puker 6.0 liter worst mistake ever. Went out last week and found a old 7.3 and gonna sell the 05. Maybe i just got a bad on but i would be leary
__________________ 2005 f-350 kingranch long box.83,000miles 5'' exhaust,sct tuner tunes by tadd 1995 f-350 crew cab long box 5 spd 190,000 stock for now
I used to have a 99 F250 with the 7.3. I did have a Banks Powerpack kit on it, but it towed great. I could haul 15K up the mountain passes with no problems, and it pulled strong off the line.
Now I have an 05 F350. I only have an intake and exhaust mod on it, no tuner, but it does not pull well at all. Even towing a 5K trailer, I will have my foot to the floor to go up any grade and try to maintain speed. It is totally dead off the line with or with out towing, but that is something I expected from the 6.0L. However, I did not expect it to be so gutless at freeway speed while towing. I have towed 16K with it and it handled the load OK, so long as I did not mind doing 45 MPH up the hills.
My opnion, if you have the chance to get a 7.3 powerstroke, do it. I really miss that engine. I am looking into tuner options for my 6.0 right now, so hopefully that will help as I really like the truck other than the dog engine.
_________________________________________________
Current truck 2005 F350
