Old 06-08-2005, 07:35 PM   #1 (permalink)
7 pin in bed connector for 5th wheel
I'm about to install my 5th wheel hitch in my 05 F350. It has the factory tow and camper packages.Is there a 7 pin connector with mount and wiring harness that will plug into the stock wiring harness without having to cut or splice the stocker?
Thanks for any help or advice...
05 F350 Lariat,Tow Boss,Fx4,CC,DRW,8'Bed,White with Tan int.
Stock...
fpizzo is offline
Old 06-08-2005, 09:59 PM   #2 (permalink)
96STROKE's Avatar
My Photos: (6)
Re: 7 pin in bed connector for 5th wheel
I had a plug installed in the rear of the bed, I regret it now. Next truck I will just use a extention cord and plug into the stock outlet on the rear bumper. You can make or buy a cord that will fit between the tailgate the bed and can be easily removed when not towing. This also will keep the cord from going over the tailgate and scratching it.
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady
Photos
96STROKE is offline
Old 06-08-2005, 11:09 PM   #3 (permalink)
I just cleaned up my wiring harness from the bed to the splice into the factory 7-pin. The first thing I did was to remove all of those dumb a$$ vampire taps the idiots spiced into the stock harness with, cleaned it all up and retaped it. I then just put a plug onto the other end of the harness that was coming from the bed, laced it down to the stock 7-pin and when I tow I plug the trailer into the bed and then the other end of the "extension cord" into the stock 7-pin.
Easy as pie......
L1
2K2, F350, Lariat, PSD, CC, 4X, LB, SRW, Shadow Gray, 6" Lift w/Centerline Arrows & 35" Toyo MT , 4:30s 4" MBRP SS exhaust, John Woods trans/6.0L Billet TC, AFE stage II intake, Banks compressor wheel, Autometer gauges, Edge Evolution w/line pressure delete.
Loser1 is offline
Old 06-09-2005, 11:06 AM   #4 (permalink)
lincster's Avatar
My Photos: (22)
Why do you regret putting a plug in your bed?
I am getting a 5er soon and have to make a decision.
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... man does this thing tow, Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
lincster is offline
Old 06-09-2005, 01:03 PM   #5 (permalink)
I had a plug in connector installed on the inside sidewall near the tailgate. I wanted it done this way because I didn't want the 5th wheel cord scratching my paint or flopping around in the wind. The recepticle is identical to the one next to my bumper hitch, and blends in well with the spray on liner. It was spliced in using the proper connectors(not cut and tape)for a clean safe install. I have had no problems with this setup. Installation time was about 15 minutes.
2004 F350 Lariat 4WD SRW CC 6.0 PSD Dark Toreador Red/Arizona Beige, Leather Every option but Moon Roof & Kitchen Sink, Fumoto valve, Wildcat 31QBHS 5th wheel
Mike_Costello is offline
Old 06-10-2005, 12:16 PM   #6 (permalink)
I just had to replace the plug in the bed and on the bumper of my truck. I put a plug in the bed of my last truck and loved it. The only downside of putting the plug in the bed is how it is done can make a huge differnce. It took me several hours to do it right and I have a lot of tools and dry place to work. You can have major headaces if it is done poorly (bad wiring connections) and you start to have problems in a year or two
DENNY
1999 F350 CC SRW LB 4X4 SIX SPEED.
DENNY is offline
Old 06-10-2005, 07:47 PM   #7 (permalink)
05TowBoss,
I looked into installing a connector in the bed but was concerned over splicing into the factory wires. As others posted, it really must be done right, otherwise it will definately be a royal pain to troubleshoot in 2-3 years. I picked up a 6 foot cord from an RV dealer and installed a 7 pin female receptacle on the tag end. This extension cord has worked flawlessly and for about $30 was worth every penny. I use a bungee cord to hold it in place at the hitch so it can't get into trouble. Later, bOOmer
2002 F350 7.3L Lariat CC DRW, PermaCool Trans Cooler, BD Deep Sump Tranny Cover, Transgo Shift Kit, BD PressueLoc, Volant Cool Air Intake, K&N 2ndGen Filter, TS Performance 6 Pos Program, Cyclone Power Fan, BD "Xmonitor" A pillar mount(Trans temp,Pyro,& Boost), Autometer 3 gauge dashtop cluster(Oil Press,Water temp,&Volts), MagHyTec diff cover. Banks 4" Monster Exhaust (turbo back), Stanadyne Performance Formula (At every fuel up), XM Radio, Retrax Bed Cover, Yaesu FT-100 w/ATAS-100 antenna, Clifford RSX 3.5
bOOmerF350 is offline
Old 06-11-2005, 10:32 AM   #8 (permalink)
buy an extension cord and plug ,then run it down through the holes near the drivers rear tail light. it'll come out right buy the factory receptacle. you can buy the receptacle and cord as a unit. i unscrewed the factory one and moved it to the side.
2004/04 engine-psd-cc-4x4-auto-lb-engine blown-ford putting in a new one-gave back to ford engine still puking antifreeze-vin-1ftsw31p84eb24255-watch out for this in canada.
2004 cardinal 35ts
new 06 PSD same as above only it's a Lariat, this one started puking as well.
dvincent1 is offline
Old 06-11-2005, 10:45 AM   #9 (permalink)
JimmyDee's Avatar
My Photos: (24)
THIS is how I mounted my in bed plug. Out of the way, out of the rain and it handy to get at. I did splice into the main cable to make it work but didn't find that any big deal.
Jim
2001, F250 4x4, CC, Auto; Mobil 1 in transfer case&Trans.; Frantz Bypass Filter; "Hutch" fuel mods; Sonnax/Tricum mod; 4" Exhaust, 30" MagnaFlow; Attitude in A-Pillar and tranny gauge in Dash; AIS; EASE Diagnostics; Reese Slider Hitch; Fr Rotors, Cryo Treated&Slotted by ART.
JimmyDee is offline
Old 06-11-2005, 11:44 AM   #10 (permalink)
One of the amusing things about this site is all the extended analysis that goes on here. Next thing you know, this guy will get out of RVing because of concerns about hooking up a 7 pin connector. Just do it!
Old 06-11-2005, 06:46 PM   #11 (permalink)
LOGHOMEMAN...
The only thing I find amusing about this site are the smart ass comments from asses like you!
I'm more than capable of installing a 7 pin connector...but it's nice to be able to get ideas and info from others that have done similar mods to their trucks...it usually saves you time,$$$ and headaches! This site is about sharing info and helping others...
Luckily there aren't too many RVers out there like you...or I would get out...
Thanks for the help...
[img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Stock...
fpizzo is offline
Old 06-11-2005, 10:06 PM   #12 (permalink)
FaC
I put a 6pin connector in the same place that JimmyDee put the 7pin connector. One trick that helped a lot on the '02 was that I was able to unplug the factory harness that went to the stock 7pin on the bumper, disconnect the 7pin from the bumper and do all of the splices on the workbench rather than upside down under the truck ;-)
I never did find a pre-built harness tap and I needed to get the plug in...
Since I only wanted to do this once, I soldered all of the connections and tinned the ends of the wires that went into the new plug. I did not use the little blue clamp on things.
Once I had the splices and the end prepped, it was a pretty simple deal to drill the hole, thread the wire thru and install the plug. I did go with a plastic 6pin plug because I had had some previous shorting problems with the all metal plugs on the previous truck...
FWIW - FaC
2002 F-250 4x4 XLT CC PSD 6sp
ISSPro Gauges, pre-pump, Walker BTM, Fumoto
PopUp GN Hitch
Cougar 304BHS TT
FaC is offline
Old 06-11-2005, 11:05 PM   #13 (permalink)
05TowBoss--If you had read my post properly and taken it in context, you would have seen it as a light hearted comment on what goes on in this forum; it wasn't a personel shot at you or anyone else. So lighten up before you become a candidate for cardiac corner! By the way, I meet some of the nicest people ever when I go RVing; and if I ever chance to meet you I'll still shake your hand and offer you a cold one. Good luck with that 7 pin connecter.
Old 06-12-2005, 12:15 AM   #14 (permalink)
I agree totally. You get one or two guys together in a thread that tell the same story, and suddenly it becomes the gospel around here. There is no other way to do it according to them, and then people make posts like TowBoss did. They make posts belittleing anyone that goes against popular opinion. I got a big fat finger right in the middle of my hand for those people. And you guy talk about the nice people you meet while RV'ing?
*This space for rent*
FYRMAN is offline
Old 06-12-2005, 12:18 AM   #15 (permalink)
The other thing that gets to me is that I just answered this identical question for someone else last week.
READ THROUGH THE OLD POSTS BEFORE YOU ASK A QUESTION!
He could have found his answer, and none of this would have happened.
Hoppy makes the 5th wheel T-connector.
FYRMAN is offline
