Originally Posted by laz
Today I checked out a '91 E350 with the 7.3L non-turbo diesel, 4.10 ratio rear. It's an ambulance, and weighs 7400lbs with a GVWR tag on the door of 9000lbs.
How do you know it weighs only 7,400 pounds? CAT scale receipt? If not a CAT scale receipt, then you need to weigh it. Load it with driver, any passenger(s) you'll normally have with you, and anything else that will normally be in the truck when on the road. Then go to a truckstop that has a CAT scale and fill up with fuel. Then weigh the rig.
I couldn't find anything in the docs they had or the door tags that indicated a GCWR.
The GCWR will be in the diesel supplement to the Owner's Guide. Probably somewhere between 12,000 to 16,000 pounds.
It's got a class 2 hitch, so I'll assume it was used to tow something sometime.
If the receiver is less than 2" wide, then replace it with a Class III/IV receiver that will accept a 2" wide drawbar/ball mount.
I'm planning on towing my 2500lb race car on an open trailer , but would like to keep the door open to buying an enclosed trailer in the future. Will this ambulance meet my needs, should I look at stripping the cabinets, or should I be looking at another vehicle?
It will probably meet your needs to a "T". But yeah, get rid of anything inside the rear end that you don't need for race stuff, including some of the heavy cabinets and storage areas. Since your GVWR is only 9,000 pounds, you want the wet and loaded van to gross less than 8,000 before you tie onto the trailer.
Know your weights. Get to know a certified automated truck (CAT) scale. When the van is loaded with everything including the wet and loaded trailer, hit the scales. If the GCW (gross combined weight) is more than about 15,000 pounds, you're trying to haul too much junk. If the combined weight on the two van axles is more than 9,000 pounds you're overloaded.
Open trailer is a "make do". When you upgrade to an enclosed race trailer, you'll enjoy towing much more. But the race trailers are heavy, so don't even think about one that includes LQ (living quarters).
Load the trailer so the hitch weight is 11 to 12 percent of the gross trailer weight. Confirm the weights on a CAT scale.
To determine hitch weight, weigh the wet and loaded van without the trailer. Then weigh it again with the trailer. Compare the GVW without to the trailer to the GVW with the trailer and the difference is hitch weight. GVW = the weight on the two van axles. Hitch weight plus the weight on the trailer axle(s) is gross trailer weight. Hitch weight divided by gross trailer weight = percent of hitch weight, which you want at 11 to 12 percent.
If the hitch weight is anywhere near 500 pounds, then you need a weight-distributing hitch that includes sway control.
