Re: 99 F250 7.3L diesel super duty TOWING?
as long as what your hauling has a good set of brakes on it, you should be good to go. the driveline will more than handle it. there are guys towing 30,000 gross out there. these trucks are way underrated at 19,000 gcvw. the 9900 gvw is just so the truck will still fall under a "light duty" classification. short of the dana 135 rear end i believe a 4-550 is mostly the same short of a lower red line.
1999.5 (5/99) F-350 SC, LB, ZF-6, 4X4: ATS Compressor Housing, BBH, K&N FIPK & Drycharger, DP Tunes 60T, Isspro Pyro & Boost, 4" MBRP & Delete Pipe, AD's (for now) ITP HPX, OBA & Reg Return, AIH Delete, Oil Guard, Couple Dongles
Oil Pan @ 133,000
PSN rocks my world [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
