Old 10-30-2007, 07:01 PM   #1 (permalink)
Accident with propane tanks.
Thought I would pass this along for others with similar rigs. A person I know has a horse trailer with living qtrs. He had two new 40lb tanks installed with all new mounting on front of trailer under the overhang.While driving on the interstate he heard a loud bang like a blowout only much louder. Seems the mount on one tank broke and tank hit pavement sparks ignited leaking gas. The truckers that stopped told him that there was a fireball that engulfed the entire trailer.
He suggested if you have a similar setup to run a chain through the tank handle and secure to crankshaft.
Trailer did not actually catch fire and horses were alright.
fieldtrialer is offline
Old 10-31-2007, 04:30 AM   #2 (permalink)
PSDfreak's Avatar
Re: Accident with propane tanks.
[img]/forums/images/%%GRAEMLIN_URL%%/shocked.gif[/img]
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is online now
Old 10-31-2007, 08:37 PM   #3 (permalink)
possible horseburgers??????
2008 F-450 Lariat loaded on order 7/3/07 delivered 9/13/2007 Pueblo Gold and all the goodies except Nav radio and moonroof and Fisher 8'6" X-blade
2005
F-350 Lariat LOADED CC SRW LB 6.0 SOLD
Med. Wedgewood Blue
All Options except moon roof
8'6" Fisher X-blade SS
2003 PSD 6.0 Lariat CC SB SOLD
All options but the moon roof
Scottb NY is offline
Old 10-31-2007, 10:29 PM   #4 (permalink)
Hi ft,
I too had a brain $art when I was younger and decided that the 40# drawband was too tight, so I loosen them up so I could wiggle the LP cyl out when they needed filled.
I'm heading East bound I-90 outside of Wallace,Id when I hit a sharp 6 inch pavement drop off and the drop off extended accross the concrete Interstate thus my tag hitching bottomed on the concrete and threw out one LP bottle onto the pavement while doing 60mph.
I caught the tank in the mirror cornner as it spun on concrete on the flexable LP pipe. As it was, it only put a few scratchs in the tank wall paint before I could stop.
I had not strapped down the tank to the frame. (the BF)
Thanks to the ID DOT, there were NO warning signs of any construction being done. There were more than six such crossing on down the road. This was before cell phones or the ID-DOT would have got a piece of my mind and I'd be in jail right now [img]/forums/images/%%GRAEMLIN_URL%%/shocked.gif[/img]
[img]/forums/images/%%GRAEMLIN_URL%%/cool.gif[/img]
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run
Define Union:
A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
T_Bone is offline
Old 11-01-2007, 09:28 AM   #5 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I am guessing either the ball was too small or the hitch did not hook to the ball.
I have lost three trailers. One, the whole receiver hitch broke under the truck from too much weight on it. The second was a snomobile trailer with sleds on it. The hitch froze closed and did not hook on the ball properly. Made it 10+ miles before it popped off and went to the median of the interstate. Both sleds stayed on the trailer. The last time was the same trailer. Empty and doing 80 on the interstate that trailer popped up from hitting the edge of a bridge abutment. I am assuming this pried the hitch off the ball. You have no idea how far a trailer rolls after the chains wear through!!!!
MarkEkberg is offline
Old 11-03-2007, 09:01 PM   #6 (permalink)
My Photos: (12)
Mark, I think you were responding to the dropped-horse trailer thread, not this great-balls-o-fire one..
Man, those horses must have been some put out for a few moments!!!! I bet those truckers' scrotums also tightened up a wad or two.
Glad everyone was okay.
Sold: 1999 White Lariat CC SB F-250. Sold to next-door neighbor in 2001....received final payment 2007! Still going strong at 198Kmiles as of Dec'07
Sold: 2001 Bright Amber Lariat CC LB F-250 with 4 million candlepower of LightForce lights in the bow. Line-X bedliner. Dual alternator. Clearance lights. Glass-tite cap. 250-gallon auxiliary tank for trips to the Lesser 48. 70-gallon auxiliary for trips around Alaska.
Rec'd Dec'07: '08 ForestGreen/Gold F-350 CC LB. Handshaker, as always, Rear stabilizer, rear static video, rear step, dual alternators. B&W turnover ball on its way; soon to be Line-X'd. LightForces on their way.
Alaska Ranger is offline
Old 11-03-2007, 10:48 PM   #7 (permalink)
MarkEkberg's Avatar
My Photos: (13)
oppps. Your right. How did I do that?
