Old 02-13-2007, 01:20 PM   #1 (permalink)
Adjusting trailer brakes
Is there a tool made to adjust the star wheels on a trailer with drop axles, I have a few different tools nothing fits because the axle is in the way.
ransil is offline
Old 02-14-2007, 03:42 PM   #2 (permalink)
Re: Adjusting trailer brakes
Yup, They make a brake adjustment tool. It has a crooked end so to speak that should allow you to get by the axle. Here is a link to one.
<font color="red"> </font> Brake Adjustment Tool
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
Down South is offline
Old 02-14-2007, 06:22 PM   #3 (permalink)
My Photos: (27)
Mine's like the one Down South shows, but I think the sharp angled end is bent more than his illustration. Over the years it's adjusted about everything known to civilized man that was hard to get at, you might give one like that a try.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 02-15-2007, 01:11 PM   #4 (permalink)
I have ( had ) that type It does not fit, the axle is in the way. I did try to bend it and it broke.
ransil is offline
Old 02-16-2007, 10:12 AM   #5 (permalink)
Black05's Avatar
Get another, heat it with an acetylene torch, and then bend it -- it won't break that way.
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
Old 02-16-2007, 01:38 PM   #6 (permalink)
Yep I was gonna say the same thing, heat it dull red and bend.
A lot of tools will snap off before they will bend, the steel is brittle. Sometimes I've been amazed by how easily some steel products will break right off!
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 02-16-2007, 04:59 PM   #7 (permalink)
Pull the drum and be done with it.
Repack the bearings ,Replace the seals and adjust the shoes .
O5 F-250 SuperDuty CC SWR 4x4 Lariat
8' box 6.0 PSD Tow Comand new 04/05
2001 40' Alfa Toyhouse
Pulls better stock than my 01 with a programmer
New engine at 42k . Hope my luck with this 6.0 is changed .
firesoutmatt is offline
Old 02-16-2007, 06:17 PM   #8 (permalink)
I hate those tools too. I just yank the drums and do it by hand.
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 02-17-2007, 08:39 AM   #9 (permalink)
Take an old blade screwdriver (wider if you have one) and use a torch to heat the end. Bend it about 30-40 degrees. Most brake adjustment tools are too large for appropriate use in the slot of a brake backplate.
Bruce & Carolyn Wittmeier
bruce.wittmeier@cox.net
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, Chrome Step, Line-X bedliner, Reese 16K slider, Jordan Ultima 2020, AirLift Airbags, Sunnybrook
Are you over weight?
wittmeba is offline
Old 02-17-2007, 11:50 AM   #10 (permalink)
My Photos: (27)
Duh, I forgot about that, a few times the only thing I found that would work is my wide bladed screwdriver (unbent, though). It's an old Craftsman, the blade is only about an inch long but reg. size handle. Many times it's handier than my brake tool even when both would work.
LMJD is offline
Old 02-17-2007, 01:40 PM   #11 (permalink)
JimTJr's Avatar
My Photos: (6)
[/ QUOTE ] My slots in my two trailers backing plates are the normal size from allll the drum brakes I have messed with,,(ALONG TIME AGO,,when CARS had DRUMS!!!! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/depressed.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img] I know, I am getting old now,,, [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img])
Maybe some trailer manufacturers use different ones,, I dont know.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is online now
Old 02-20-2007, 01:20 PM   #12 (permalink)
That is what I was trying to avoid, I did some searching seems there are brake tools bent around 80-85 degrees that will work. I will either find one or bend up my own.
ransil is offline
Old 02-20-2007, 03:20 PM   #13 (permalink)
My Photos: (27)
That's what I was saying above, maybe I wasn't clear but that's the way mine is---not much it won't catch. The end that has the sharper angle is shorter. By that I mean the tip that actually goes through the backing plate.
Plus you don't get an accurate adjustment trying to do it with the drum off then sliding it on.
LMJD is offline
