Old 08-07-2008, 09:27 PM   #1 (permalink)
advice on hauling truck
I'm shopping for a new(used) truck to haul cattle and hogs for the farm. Right now we have a 97 2WD, 5spd with 7.3 and 4.10 gearing. It is a high mileage truck that pulls exceptionally well but the 2WD and age has me looking at:
99 F250 4WD, reg cab, 5 spd 7.3 geared 4.10, with 97k miles for $13k. The truck has been well cared for.
01 F250 4WD, sup cab, 7.3 geared 3.73 w/ exhaust brake, with 6 spd and 87k miles for $16k
We farm several hundred acres in the steep mountains and the 2WD falls short wit hthe heavy motor in the front. Otherwise I am amazed at how well the truck pulls and how little it cost me.
My heavy loads will be 12,000-14,000 lbs but those are less than ten a year. The tows are 140 miles round trip with one 5 mile steep grade. Otherwise it is just 6-8,000 lb loads and driving around the farm.
I guess my biggest questions are:
1) Are the 01 models any better than the 99?
2) Would the 3.73 be a better choice for fuel economy, given the relatively little amount we tow heavy loads? 350 days a year it's just for getting around the farm.
3) How does the super cab affect visability backing up or towing in general?
Thanks all, there are more trucks out there, but these are ones currently for sale that most closely meet my needs -- I think.
Thanks for any help-
farmpower is offline
Old 08-07-2008, 11:24 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (33)
99 F250 4WD, reg cab, 5 spd 7.3 geared 4.10, ...
No such thing from the factory. All '99 F-250 PSDs had either a 4-speed automagic tranny or a 6-speed ZF manual. The ZF is marked low, plus 1,2,3,4,+5th is OD. So if you glance quickly at the shifter knob, you might see the 1,2,3,4,5 and miss the granny low, so you'd maybe think it was a 5-speed.
Also, all '99 F-250 PSDs had a 3.73 rear axle ratio. If that one has a 4.10, somebody changed it after if left the factory.
The 3.73 should handle a 12k trailer just fine. But with a 14k trailer you'll be overloaded a bunch and might wish you had the 4.10.
Care and condition count for a lot more than whether it was produced 7 or 9 years ago. Or if it's an "early" '99, it could be over 10 years old by now.
But with equal care and condition, it depends on month of production. If the '01 was produced before December 2000, then it probably has the 235 HP tune. But if it was produced after Thanskgiving, then it probably has the 275 HP tune. With 235 ponies, the '01 doesn't have a catalytic converter. But with 275 horses, it has a cat.
For the '99, those puppies were produced from January 1998 thru June, 1999. Generally, the ones produced in CY 1998 have a cat, and the ones produced in CY 1999 we call '99.5 and they don't have a cat.
SmokeyWren is online now
Old 08-07-2008, 11:35 PM   #3 (permalink)
My Photos: (33)
honestly I would go with the 01. I never heard anyone say they wish they would have bought a regular cab.
if you can live with the hand shaker vs the auto Trans then that's definitely more truck for the buck. Plus the the low hole you can really crawl along in low range 4 wheel drive.
Really makes getting rolling on the hills loaded no big thing.
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Dualie is offline
Old 08-08-2008, 10:08 AM   #4 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Don't the 01's have powder rods? If you start adding fuel don't they head south?
MarkEkberg is online now
Old 08-08-2008, 10:51 AM   #5 (permalink)
88beast's Avatar
id go with the 01 its a large cab for more ppl if a cow gets loose or whatever you can rush over there quick
and its got a 6 spd which i wish i had in my 88
also it sonlds like the 99 guy either extensivly modded it or is lieing to get more money off it so id also steer away because if he did the work on his own then you get his bad workmanship if you buy it
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 08-08-2008, 12:31 PM   #6 (permalink)
year model
Smoky Wren-
I got the year model wrong, it is a '97. I'm going to ride up there now and look at the truck and buy a load of hay while I'm at it.
Sorry for the bad info, but your response is good info while I keep looking.
I appreciate all the responses and hope to get more based on year model revision-
Old 08-08-2008, 02:38 PM   #7 (permalink)
I'd negotiate the price, especially if you decide to go with the '97. With the price of diesel as high as it is, most people are paying considerable under NADA or Kelly Blue Book prices.
NADA on the '97 is around $12,000 for clean retail price. Used Car Value - Ford F250 PICKUP-3/4 Ton-V8; W25 7.5L V8 Heavy Duty XL
NADA on the "01 is around $20,000 for clean retail price. Used Car Value - Ford F250 Super Duty Pickup-3/4 Ton-V8 Crew Cab XL (4WD)
2001 F350 XLT 4X4, shift on the fly, 38 gal fuel tank, running boards, sliding rear window, black, crew cab, long bed, 4.10, automatic transmission, 11,500 gvwr, 20,000 gcwr, 7500 gvw, dual rear wheels, 7.3l turbo diesel, completely stock, 114,00 miles when purchased, now has 125,000 miles, repairs so far: starter, batteries, cps.
DonWarkentin is offline
Old 08-08-2008, 02:40 PM   #8 (permalink)
Steve250's Avatar
I've backed up both regular cab 350 and supercab 250 to trailers and it's not to much more difficult... unless you take the tailgate off of the reg cab then you can't much more than super anyway. I'd say go with the super.
'92 F-250 7.3 IDI Diesel 4:10 (just hit 90k) 4x4 ext cab (Prodigy brake controller)
'98 Ranger 4x4 ext cab - wheelin' in the mud
Steve250 is offline
