Advice on LED lights - Diesel Forum - TheDieselStop.com
Old 04-21-2006, 10:43 AM   #1 (permalink)
I'm going to put 4 six inch oval led lights on the back of my trailer, but after looking at the various types I'm confused. Some say that the more led's in the lights are better, and some say the less led's are better. What gives? Can anybody shed some light on this? (No pun intended)
1988 F-250 regular cab 2wd, 7.3 IDI, C-6 (SOLD!!)
1994 F-250 XL regular cab 2wd, 7.3 non-turbo, E4OD
Installed Bronco overhead console, Eddie Bauer dash trim and power door locks/windows, bucket seats, A-pillar gauges, Banks Trans-Command.
... finally getting close to installing Banks Sidewinder
Discbrks is offline
Old 04-21-2006, 12:44 PM   #2 (permalink)
Sapps's Avatar
Re: Advice on LED lights
The more diodes the brighter = better.
I run these on all my equipment, you wont find a better light or better price. Make sure the elctrical connections are covered in grease and you wont have any issues.
CLICK HERE
<font color="blue">edited to narrow link</font>
95 F250
97 F250
02 F350 Dually
07 Dodge 3500 Dually
Soon to be 2011 F350 Dually
Sapps is offline
Old 04-21-2006, 02:09 PM   #3 (permalink)
That's what I thought - the more led's the better &amp; brighter. But after reading more I saw that more lights mean more chance for diode or resistor failure. Now I'm confused.
Discbrks is offline
Old 04-21-2006, 02:31 PM   #4 (permalink)
My Photos: (23)
More LIGHTS=More MONEY
My "7" LED lights will blind the person behind me. I have 4 on the back of my Mack. They light up the world [img]/ubbthreads/images/graemlins/cool.gif[/img]
THE ORIGINAL "FREIGHTRAIN"
1959 B61 Mack...15 gears of twin stick, black smoke huffin' fun
1967 F100 LB....352 ci/4 spd, nice daily runner
1969 F100 SB.....428 cubic inches of dual quad, 4 speed terror.
1964 Galaxie......390 cubic inches of blown big block...with a 4 speed
1964 Galaxie Country Sedan Wagon.....428 ci and 5 speeds of wheelstanding race car
40ft Haulmark trailer..for the car, quad, AND kitchen sink
FOKISD MEMBER
ATHS MEMBER
....old trucks RULE!
Freightrain is offline
Old 04-21-2006, 07:25 PM   #5 (permalink)
Do yourself a favor and stick with a good name brand light like Trucklite. The junk you get at the truck stops on the wall are not up to the test when it comes to the shock and moisture they will get on the back of a trailer. I run Trucklite 4in. super 44's with 6 diodes (4 reds and 2 Amber's)on over 30 Flat bed trailers and have good luck with them. I have tried other brands and they seem to draw condensation and burn out the diodes one at a time. Nothing looks worse than having mismatched bulbs with different number of diodes and brightness or partially burned out bulbs on the back of a trailer.They also make the oval lights you are looking for.
bikerforchrist is offline
Old 04-28-2006, 09:27 PM   #6 (permalink)
My Photos: (33)
I second what Elkchazer said. Cheeper lights usually the one's with more diodes will burn the diodes out faster. Usually start to look like crap after a 6 months. Friend put the same brand you were looking at on his trailking beavertail and ended up replacing them less than a year later. Trucklite, Peterson, Grote, are the big three trusted brands.
00'F350 psd CC Drw 2wd Bright Amber Western Hauler, exhaust brake transfer flow 50 gal tank tool, 30K Cody goose neck hitch, hawk pads, cryo'ed rotors, stainless lines, 380,000 miles
02' Psd Excursion Limited ultimate Estate Green 7.3L Auto 2x4 hellwig swaybars and rancho 9000's. 381,000 miles.
1993 F-superduty (F-450) 7.3L Gutless non turbo 2x4 Auto, Tire eating S.O.B. 12,750lbs 80,000miles lincoln Vantage 500 Duetz bolted in the back.
1994 7.3 I.D.I.T. factory turbo, auto 2x4 DRW with lots of upgrades, 11 transmissions under 100K factory warranty. 280,000 miles Currently Cavitated and parked.
96 F-800 24'flat 5.9L cummins, 4spd allison juice brakes.
89 F-800 6.6L 5+2 27,00lbs light weight with National 556A crane behind the cab.
2006 T800 KW 550 C-15 18spd 22K front, 52K rears murray ramps, 195" W.B. CA spec heavy haul SOLD
2006 Murray 16 tire professional lowbed SOLD
1996 fetherlite 4 horse GN, Walton 18' 14K tag tilt equipment trailer.
Dualie is offline
Old 04-30-2006, 05:05 AM   #7 (permalink)
Sapps's Avatar
[img]/ubbthreads/images/graemlins/shrug.gif[/img] I must be the only one who has had no problems with those lights. I own about 60 of the ovals I linked to on ebay, over 300K on most without a burned out diode or moisture......but the more expensive dimmer brand names will work great also [img]/ubbthreads/images/graemlins/wink.gif[/img]
95 F250
97 F250
02 F350 Dually
Sapps is offline
Old 04-30-2006, 07:47 AM   #8 (permalink)
Hey Freightrain, mind if I ask, what brand of 7" led's your using to lite up the world? lol, btw, real sharp looking old Mack you got there too, thanks Paul.
2001 F-350 7.3 Lariat CC 4X4 lwb dually
4R100 3:73 esof dual-alts reverse-sensor
mods so far:
Line-X,Gene Louder AIC w/ITP bracket,Muth heated/signal tt mirrors,Proflaps,acetoned badges
Lund interceptor bug sheild,wilson 5000 roof mount antenna w/galaxy 88HL
DPPI 4" 304 dual exhaust,Isspro EV gauges pyro trans boost on A pillar,04 headlights and corner
suv-lights dual-harnesses and silverstars,husky liners,Marinco plug mod,AIS
2004 F-350 6.0 xlt reg cab
4x4 5R100 3:73LS manual hubs
mods so far,
aic,husky liners,hood insulation pad
Lund interceptor bug sheild, 8'HD plow setup,Marinco plug mod,
husky mudflaps
Hardtail99 is offline
