Old 11-22-2006, 12:00 PM   #1 (permalink)
Aftermarket Brake Controller and ABS
Anyone ever have any problems with their ABS conflicting with their brake controller. When stopping my trailer has started jumping violently. I am thinking it is the antilock brakes being amplified thru the trailer brakes. Any suggestions?
2004 Ford F250 Lariat FX4 6.0 Powerstoke Diesel SCT Xcal 2 aFe Stage 2 Cold Air Intake 4" Pro Comp Lift Firestone Air lift
35 x 12.50 x 16 Toyo Open Country A/T
2003 Excursion Limited 6.0 Powerstroke Loaded!
Powerslot Cryo'd Rotors and Hawk pads.
Destinsb is offline
Old 11-22-2006, 12:25 PM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Re: Aftermarket Brake Controller and ABS
What kind of brakes are on the trailer and which controller are you using?
haul_n_horses2 is offline
Old 11-22-2006, 12:33 PM   #3 (permalink)
Not sure about the trailer other than they are electric and on all 3 axles. The contoller is a Drawtite Activator II.
Destinsb is offline
Old 11-22-2006, 01:53 PM   #4 (permalink)
What electrical source are you using to activate the controller?
It should be wired to the brake switch. Sounds like it could be wired in somewhere else, or you have another problem.
2002 F250 7.3 PSD XLT 4x4 EXT Cab Shortbox - EVO2, AIS w/Zoodad, MBRP 4" 409SS, 08 rear diff cover, Heated tow mirrors w/signals
1988 Mustang GT 9.71 @ 143 (1.43 60ft)
Blk88GT is offline
Old 11-22-2006, 05:13 PM   #5 (permalink)
I'm pretty sure it is wired to the brake switch. I'll check, I had it installed and did not do it myself. Any other ideas?
Destinsb is offline
Old 11-22-2006, 06:55 PM   #6 (permalink)
Maybe you have it adjusted too high. With brakes on all three axles, that's a lot of braking power. I've not heard of one back feeding through and messing up the ABS.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
Old 11-22-2006, 11:14 PM   #7 (permalink)
I dont think I have it too high. I usually dont set it over 3.5 and that is on really heavy loads. 2.5 is probably average. Its not really backfeeding and screwing up the abs, it seems to be the other way around. Its kinda hard to explain but here goes: abs works by applying and releasing the brakes several times a second in order to keep the tires from locking up, right? So it feels as if this applying and releasing is amplified thru the trailer and it "pulses" violently, and ofcourse if you re really on the brakes hard it shakes the truck violently causing your foot to jump up and down on the pedal making the problem much worse! Does that description make sense?
Destinsb is offline
Old 11-22-2006, 11:39 PM   #8 (permalink)
Fever's Avatar
My Photos: (9)
Send a message via ICQ to Fever
I think i'd take a peek under the dash and see if it was installed in the factory plug-in or wired elsewhere...
2002 F-250 Super Duty Super Cab Short Box 4x4
7.3L PSD, 4R100 Automatic, 3.73 LSD Gears,
BTS Valve Body Kit, Tymar Intake, Muffler Delete,
DP Tuner F-5 (60T/80E/120R/Hi-Idle),
ISSPro A-Pilar Guages (Pyro/Boost/Trans Temp),
Powerslot Cryo Rotors/Hawk LTS pads,
285/75-16 Yokohama GeoLander A/T II Tires,
Tekonsha Prodigy Brake Controller
2006 Sunset Creek 269BH Travel Trailer
Fever is offline
Old 11-23-2006, 06:14 AM   #9 (permalink)
I'd check the trailer brakes to see if there was a broken drum or rotor.
Capt Ron
May 2003 F-350, CC, DRW, 6.0L, 6sp man, LB, Al Wheels, Moon Roof, 52gal tranfer tank. Hitches: Draw-Tite 16K 4X and B&W GN, 8040lbs GVW. Towing 35' Newmar Kountry Star 5th Wheel Camper, 14,000lbs GVW, or Wells Cargo 24' Car Hauler, 12,000lbs GVW.
CaptRon is offline
Old 11-23-2006, 04:23 PM   #10 (permalink)
As I understand it, the antilock only takes effect if you are in a potential or actual skid situation. There would be no signal from the antilock in a moderately normal stopping situation. I have felt the antilock a time or two when driving solo, but never when towing (and I never want to).
Housted
2007 RAM 2500 4x4 5.9 CTD Quadcab fiberglass Shell
Sold 2001 F250 4x2 Xcab 7.3 TD
My pics - http://community.webshots.com/user/edgwen1
housted is offline
Old 11-23-2006, 05:00 PM   #11 (permalink)
Just by chance, it doesn't do it only when the turn signals are on does it? Like it could be a wire touching in the plug? Just a thought today.
Joe
