Old 06-26-2007, 03:14 PM   #1 (permalink)
Air Bags ? Areu able to run them empty ?
I have been reading alot of post on everyone with air bags and have found the major con of running air bags is the stiffness in the ride.
Is it possible to run around unloaded with air bags and have no air in them and still achieve the somewhat stock ride?
2000 F-250 7.3 Liter Diesel CrewCab Short Bed, 3.73rearend,4x4 Automatic,Guages, TS Performance Chip on 50hp (so that she will keep up with other stock diesels)Looking for bigger trans cooler
jimmyjames4900 is offline
Old 06-26-2007, 03:16 PM   #2 (permalink)
STurbo90's Avatar
My Photos: (9)
Re: Air Bags ? Areu able to run them empty ?
I believe that minimum of 5 psi is required at all times so the bag doesn't fold over and rub a hole in its side.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 06-26-2007, 03:19 PM   #3 (permalink)
My airbags rubbed a hole even with 5 lbs. The installer said a bolt rubbed the hole and replaced free of charge after grinding down the bolt. He told me to run at least 20 lbs. What I've noticed is, that even when empty, the airbags (Firestone ride rites) have a spacer in them which takes away all of the lower travel of the stock suspension, so you really can't ever get a stock ride.
Dennis
'99.5 F250 4x4 SC 6 speed 3.73 LS, Magnaflow 4" exhaust, South Bend con-o clutch.
The_Dude is offline
Old 06-26-2007, 03:42 PM   #4 (permalink)
Thanks, that is what I was expecting.
And I guess that the Firestone air bags are probably the best, seems like everyone is running them.
Either way sounds like I am going to have to get a set and try them out.
Old 06-26-2007, 05:45 PM   #5 (permalink)
I've been running the Firestones for over a year without any problems. I keep a minimum of 10 psi in them and it rides alright. Remember, this is 3/4 ton truck and was never meant to ride like a luxury car.
2003 F250 7.3L 4x4 extended cab shortbox
Line-X
AutoMeter pyro, boost, tranny gauges
A.I.S. Severe Duty Kit
A.R.E. topper
Firestone Ride Rite airbags
28 foot Keystone Hornet Hideout toyhauler TT
1997 Harley Davidson Softail Custom
S&S Super E carb
Andrews EV27 cam
2004 Harley Davidson Ultra Classic
Big Bore Kit
NRA member
"The 2nd Amendment: America's Original Homeland Security"
[color:"red"]MY PICTURES[/color]
Djc94 is offline
Old 06-26-2007, 06:01 PM   #6 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
[/ QUOTE ]Air down your tires. My dually could be holding the axle weight at 35 psi but I won't air down that low. I run 40 psi rear and it is smoother than a luxury car. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
haul_n_horses2 is offline
Old 06-26-2007, 08:07 PM   #7 (permalink)
yea I would expect this truck to ride like a car,
just trying to figure out how rough it will be.
Had a jeep and installed a PROCOMP lift on there, and the sh&* was so still the shocks never ever once compressed. the springs would not let them.
So I will do all my research before I ever do anything with suspension again.
thanks for all the info
by the way will never buy anything with procomp name on it again...they lied to me
Old 06-28-2007, 12:08 AM   #8 (permalink)
Btravelen's Avatar
....And I guess that the Firestone air bags are probably the best, seems like everyone is running them....
Don't believe it. Lots of folks use Air Lifts, also. I've had mine on two vehicles since '01 w/o a problem.
Firestone brought you the biggest tire recall in years. (ever?) [img]/ubbthreads/images/graemlins/wink.gif[/img]
Take Care
'05 Excursion 6.0L with Air Lifts and Bilsteins, high idle mod., only 'tuner' is in the radio, towing an '00 HR Alumascape 31SKS with a Hensley.
Btravelen is offline
Old 06-28-2007, 01:52 PM   #9 (permalink)
Send a message via ICQ to sandfun
i know a guy who ...when running empty he removes the valve cores....so when the suspension is moveing his bags act like a shock absorber....suck and blow
2001 f250 4x4 cc sb , 6 in lift, cheyenne wheels, 3.73 gears, 4 in exhaust with muff delete ,piller gagues, trans coolers, dp 6 pos chip, zoodad ,exhaust wrap insolation on air return ,air bags,ladder bars, 3 extra leaf kit ,,,,,,john wood transmission ,,,6.4 torque converter----so far
sandfun is offline
Old 07-02-2007, 10:51 PM   #10 (permalink)
I run with no air in mine all the time with no problems.
I don't air them up until I attach my boat or travel trailer or load the bed heavy.
2006, F-350, 6.0, 4x4, Lariat, Crew Cab, Long Bed
Leer model 180 bed cap
MagnaFlow 4" turbo back muffler & exhaust system (no cat),
Firestone #2400 Ride-Rite rear air bags
Isspro three gauge pillar set
HID Bi-Xenon headlights
Accufab intake elbow
DFuser coolant filter
Bilsteins all around
HFCM drain plug
Up-idle switch
Fumoto valve
Zoodad
johnfjensen is offline
Old 07-13-2007, 01:04 AM   #11 (permalink)
Mine has a sensor that kick's the compressor on if you deflate more than 5 psi.And my truck is a 01 3/4 ton supercab with a 7.3 and rides like a brick unless I have 300# or more in the truck. I put reflex shock's on a 17K,didn't help,then air bags which didn't help either even a 5psi. And I have Goodyear wrangler tires which didn't help the ride either. Like the truck, hate the ride.
bayou49 is offline
Old 07-13-2007, 07:17 AM   #12 (permalink)
My Photos: (17)
Hey Bro', What are the inflation pressures in your tires?
Old 07-15-2007, 10:49 AM   #13 (permalink)
96STROKE's Avatar
My Photos: (6)
I agree that tire pressure affects ride more than anything. You must inflate tires AS well as the air bags to the load you are carrying, and you will be more than happy with the ride of a superduty truck. (no it will never ride like a car, but it was never supposed to either)
I air down the rear tires to 40psi when empty and depending on load, upto 70-80. Air bags 5-10 empty and 15-50 depending on load. This is what works for me and I think it rides great.
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady
Photos
96STROKE is offline
