Air bags and lift kits - Diesel Forum - TheDieselStop.com
Old 08-27-2007, 03:07 AM   #1 (permalink)
Hi, My truck is a F350 Superduty with a 4.5" lift and 325/65R/18. I'm pulling a 34ft. Elite horse trailer with LQ, and would like to level the rear of the truck. Does anyone make an airbag that fits lifted trucks?
89carlson is offline
Old 08-27-2007, 04:19 PM   #2 (permalink)
Re: Air bags and lift kits
I would check the Firestones.
2003, F250, Super Duty, Super Cab, 7.3, Auto, 4X4 Silver, 2" lift in front only, 46 gal fuel tank, Billet Grill, 285X75X16 BFG MT, Bilsteins, Firestone Air Rear, B&W Gooseneck, We call it the "Silver Knocker"
reba is offline
Old 08-27-2007, 09:48 PM   #3 (permalink)
Any airbag would work just build a "lift kit" for your bags.
drrj is offline
Old 08-27-2007, 11:30 PM   #4 (permalink)
Look Here:
http://www.suspensionconnection.com/cgi-...ers:id=pgXXHBNJ
Keep Strokin'
My Truck: Early '99 F350 CC LWB 4X4
Annoy A Liberal
Work Hard, Succeed, Live Happy!
Family of 5 saved by Grace.....
strokin_early_99 is offline
Old 08-29-2007, 05:18 PM   #5 (permalink)
PSDfreak's Avatar
Just installed a set of Firestone's today. A buddy of mine who owed me a favor down at Les Schwab did it actually. My truck is lifted 4" (4" in front and 2" in rear I believe. He was going to put in a 2" spacer but it ended up not even needing it. There are spacing kits out there though should you need one.
-Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
Old 09-02-2007, 04:54 AM   #6 (permalink)
Send a message via ICQ to sandfun
my firestones sit right on top of the leaf pack,i have a 6in lift..no prob....
2001 f250 4x4 cc sb , 6 in lift, cheyenne wheels, 3.73 gears, 4 in exhaust with muff delete ,piller gagues, dp 6 pos chip, zoodad ,john wood transmission
sandfun is offline
Old 09-02-2007, 07:48 PM   #7 (permalink)
88beast's Avatar
skyjacker has a up to 12 in lift for newer fords that is air will give stock to 12 in lift and can be rated way above your tires 4500 lbs per airbag and higher (i think thats base model) and it will give youa more stable reilable 4 link setup no welding some cutting and a few bolt holes to drill but not enough to weaken the frame its great check them out
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 09-03-2007, 04:56 AM   #8 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 88beast</div><div class="ubbcode-body">skyjacker has a up to 12 in lift for newer fords that is air will give stock to 12 in lift and can be rated way above your tires 4500 lbs per airbag and higher (i think thats base model) and it will give youa more stable reilable 4 link setup no welding some cutting and a few bolt holes to drill but not enough to weaken the frame its great check them out </div></div>
yea but what's that cost bout 5000.00 dollers.....
sandfun is offline
Old 09-03-2007, 05:19 PM   #9 (permalink)
88beast's Avatar
not sure maybe i never looked but it is the best out there and if thats what youre looking for then go for it
i also think they make a 6 in lift for like 1200 but idk about the price of the large lift
88beast is offline
