On my 94 psd i have air bags with no over loads, i have a set of overloads on my 97 parts truck, should i put them on my 94 or just run the airbags for overloads?
1964 F350, 24v 5.9 Cummins not even close to broke in, New Nv4500, Turned Np205, Custom Dana 70s Front and Rear, Two 20000lb PTO winchs, 14' lift, 49" iroks!!, 97 PSD acc. with wire harness swap, 87 F350 frame (still sits in shop with fresh coat of JD green paint "Built Not Bought" 0 miles,
Depends on what your going to use the truck for. I had air bags only on my '93 F250 4x4, for hauling a very heavy fifth wheel.
When I bought my '05 F350 4x4, I discovered that the pin weight from the trailer would cause one end of the leaf spring overloads to rest on it's frame bracket and the other end of the spring was 1/2" from touching it's frame bracket. Got a lot of spring slap while driving down the road. I removed the overload springs and installed air bags.
The ride, handling, and load adjustability is much better with air bags for my purposes. If your going to hauling 2k+ (tools, compressors, water tanks, etc)in the bed of your truck most of the time, then I'd probably go with overload springs.
think i will just stay with the airbags, i see no point of spending time and putting the overloads, i hauled 3 cords of wet wood today (1 in truck and 2 on trailer), pumped the bags up and had no problems, still sat a little low but drove fine, whats the max psi that you should put in the bags? thanks
The max pressure depends on the brand and model, but my Air Lift brand is 100 lbs. I've never been near it.
2000 Ford SD; PSD; Crew Cab; SB; Lariet; Air Lift suspension; K&N; Dynomax exhaust; ATS BB turbo; A-pillar three gage pod with Auto Meter pyro, boost and tranny temp gages; Prodigy brake controller; Rancho 9000 shocks; DP Tuner; 4R100 by Trans-Craft.
Timbrens. No maintence, no worries, does not affect ride when it is unloaded. Ran them on the F-250 for years without issues. Would not doubt doing it again. Oh yeah, and they are cheaper..
It is the soldier, Who salutes the flag, Who serves beneath the flag, And whose coffin is draped by the flag, Who allows the protestor to burn the flag.
