2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: solrpwrd</div><div class="ubbcode-body">what would the down side be to using a 5ver air ride hitch that is double the needed capacity? loose any benefits? other issues? thanks, rich </div></div>Adjusted pressure relating to pin weight, no difference I would think.
The hitch itself will be heavier (mine weighs 300+ lbs) but if the air is adjusted for the pin weight (which it always should be) then there shouldn't be a problem.
