Old 11-25-2006, 05:07 PM   #1 (permalink)
Anyone change a bumper pull to a goose neck?
I have been looking for a 2 place goose neck trailer to haul 2 jeeps on for a while now. Anything for a decent price is junk, and anything nice is the price on new.
We got a new trailer to haul our track machine for work, and I was thinking ahout using the old trailer for this. By old i mean a 2001. The trailer is a 14,000gvw deck over bumper pull at 28ft long. It has plenty of deck for the two jeeps.
Has anyone tried to change a bumper pull to a goose neck before? Would there be any legal problems?
I don't see any problem with doing the work/ welding myself. if not my good friend in a certified welder.
I plan on going from MA to Utah and down to PA quite a bit. And for the longer trips, I hear the goose neck is just a lot nicer to drive.
The best thing is the trailer would be able to be used for just about anything, Not just vehicals like a normal 2 place.
If this won't work, I guess i will have to see if i can set up the deckover with some load levelers and sway control.
New truck
3/27/03 build F-350,CC,SB,DRW,6.0,auto,Black on Black,Blacked out bumpers/grill,285/75/16 Toyo A/T, 2" spacer, Alpine everything,Vector 1000w Inverter,16k Reese slider,Prodigy brake controler,MBRP cat back with muffler delete,Autometer luners on the A-pillar,Viper 5900,XM Radio
04 F-350 6.0,auto,supercab,shortbed, 8ft Fisher X-Blade, Hideaway Strobes, XM Radio,Alpine Head unit,X-codes, Edge Mini spring pack, Edge adjustable track bar,International helper springs 315/75/16 Toyo A/t,Prodigy brake controler,MBRP 3.5" downpipe,5"stacks
Last truck
sick, 1/7/03 build
2003 F-350 XLT supercab 6.0 powerstroke
4"lift 37 MT/R 372HP
http://www.putfile.com/ipkyss
http://community.webshots.com/user/traxx400-date
ipkyss is offline
Old 11-25-2006, 07:50 PM   #2 (permalink)
JimTJr's Avatar
My Photos: (6)
Re: Anyone change a bumper pull to a goose neck?
I have a 32' gooseneck, and love it. After pulling many bumperpulls in my life the GN is wonderful. Trust me, if you are capable of doing that give it your all. Seems there is a "Junk" GN on EBay right now if I remember right. MAYBE you could buy it, and with the two make one the way you want? Could be cheaper than fabricating a GN from scratch.
I will try to find it again and link it to ya.
Cant find it now, must have ended. I am keeping my eyes on EBAY for a larger one now too,
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is online now
Old 11-25-2006, 09:13 PM   #3 (permalink)
Albin's Avatar
My Photos: (24)
Somebody at Shop Floor has done it, don't recall who, but he's a regular, should be easy to find. Tons of pics.
Here's the link:
http://www.shopfloortalk.com/forums/...splay.php?f=13
Good luck.
Al
'06 F-350 SRW 6.0 PSD
Albin is offline
Old 11-26-2006, 07:55 AM   #4 (permalink)
I am assuming that it has a I beam frame, all you need to do is cut the tounge off flat with the front of the trailer then get some 12" x 19# I Beam you will need roughly 25 to 30 feet depending on your deminsions, you will need two 24" x 30" gussets 1 25K coupler and misc steel for the sub structure between th I beams. I use 3" channel 3' long mid way back and 3x5 angle where the neck transitions to the virtical legs then I put some .375x2 flat bar from the channel to the 3x5 angle and that is where the spare tire goes oh and you will need a plate or tube to mount a break away kit on you will also need some grade 70 .375 saftey chains with the weld on retainers, weld it all in uphill and you will have no problems. I build trailers for a living thats where the deminsions came from [img]/ubbthreads/images/graemlins/phoney.gif[/img]
durantdiesel is offline
Old 11-26-2006, 11:37 AM   #5 (permalink)
It seems that easy in my mind. The trailer is actually 10x2 channel steal for the frame. Could be 8". have not taken a tape measure to it yet. I am going to take a ride over to a local trailer place and take some measurements today. They have the same trailer there, just brand new with a goose neck on it. Only they want $9,500 for it.
Would there be any need for it to be inspected when I get it done? Is a goose neck registered any different? I just don't want to have any problems while traveling cross country.
I looked through the post on the shop floor forums and found one post about a removable goose neck set up for a bumper pull trailer. Is that the one you wanted me to find? That did help some with Ideas. Thank you.
New truck
Last truck
sick, 1/7/03 build
ipkyss is offline
Old 11-26-2006, 02:42 PM   #6 (permalink)
Finally got to take a look at it. Its 8x2" channel steal. Looks like it should not be a problem. Would the same 8x2" cahnnel be strong enough to make the goose neck or would something else be better?
New truck
Last truck
sick, 1/7/03 build
ipkyss is offline
Old 11-29-2006, 04:48 PM   #7 (permalink)
NCHornet's Avatar
Aren't trailers DOT approved? If you are changing the structual integrity of thr trailer and I would think it would need to be recertified by somebody. If not and you are in a wreck a lawyer would have a field day with this. Just my .02
Kevin L. Mnt Airy, NC.
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 11-29-2006, 06:59 PM   #8 (permalink)
Hi ipkyss,
Check on trailer builders around (100 miles) of Dallas Tx as there dirt cheap.
a Legend 20+5 Dexter tandum duals oil bath forward self adjusting, 12" #19 I-beam, Cooper tires, 3"C cross frame on 16"OC, 6"C side rail, 2-3/8" rub rail, 6" torque tube, rubber mounted lites with side turns, Bulldog GN coupler and landing gear, $5400 new, About $400 delivered. Excellant craftmanship.
I have a 2005 27+5 Legend that's 40ft overall. A very nice trailer and pulls like a dream as there's no road rocking empty or loaded.
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run
Define Union:
A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
T_Bone is offline
Old 11-29-2006, 11:01 PM   #9 (permalink)
I know there are some cheap nice trailers out there. If I was to get a new trailer, I would buy just what i want. And thats about 8-9k. I was just trying to save the money and make something nice. It seems it would just make more sense to sell this one and get what i want. Its just hard spending that much money, and not making any off it. My personal recreation has taken a backseat lately. Trying to fix that problem. Thanks for the info everyone.
New truck
Last truck
sick, 1/7/03 build
ipkyss is offline
Old 11-30-2006, 07:31 AM   #10 (permalink)
NCHornet's Avatar
OFF Subject, but what kind of Jeeps do you have? I am doing a frame off on a 77 CJ5 with 304 V8. Can't wait to go wheel'in.
White Stroker
NCHornet is offline
Old 11-30-2006, 11:46 PM   #11 (permalink)
I am into the Cherokee's. My friend has one locked on 35s. My street xj is locked on 33s. I am now building an Xj buggy. 95 xj, 40" MT/Rs HP dana 60 front locked. Locked 14bolt rear. Links and coil springs all around.
New truck
Last truck
sick, 1/7/03 build
ipkyss is offline
Old 12-01-2006, 03:33 PM   #12 (permalink)
A friend of mine way telling me a while back that he knew of a place that built the Gooseneck hitch for bumper pull trailers. It cost around 500.00 bucks to have it crossed over.
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
Down South is offline
