Anyone tow a 5th wheel with a lifted truck? - Diesel Forum - TheDieselStop.com
Old 04-17-2006, 07:36 AM   #1 (permalink)
Mine is mildly lifted, with 35's under it. We are currently shopping for an RV. I'm thinking no on the fiver, for clearance problems.
Thanks,
Barrett Hall
2003 F250 CC FX4
6.0 PSD, Torqueshift Tranny
3.73 Gears, Limited slip rear end
4" Procomp lift, 35" Cooper S/T's on 16x10 Centerline Hellcats
bearintex is offline
Old 04-17-2006, 08:53 AM   #2 (permalink)
GS
Re: Anyone tow a 5th wheel with a lifted truck?
I've got a 4" lift and running 315's on stock rims. I had the springs flipped on the 5ver before I lifted the truck, it was needed just to get under it with stock truck height.
I put some helper springs on the rear pack and that made all the difference with the sag on my F250. I've got about 6" clearance on the bedrails on the cab end, maybe an inch less at the tailgate.
Been towing it this way for about 3 years now with no problems. I really like the way the truck/5ver mate up with my current setup, it can be done. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Bowhuntr
99.5 Red Metallic F250 SWB 4x4 Off Road, DAC2 PSD CC Lariat, Isspro EV Pyro/Boost, SCMT, SB CON-O, Modified Zoodad Intake w/K&N filter, 4" DPPI exhaust w/6" SS Tip, 6 speed, Man hubs, C/TT, 3.73 LS, 4whl ABS, 4" Procomp/Dual Rancho 9000's, Rear add leaf, 315 BFG MT's. Pulling 30' Savanna 5er
GS is offline
Old 04-17-2006, 09:04 AM   #3 (permalink)
JimTJr's Avatar
My Photos: (20)
Yep,, just like GS said, they flip the springs on the 5er. Guess you need taller steps to get in and out of it thru the door now?
Maybe build yourself a wooden STOOP out of 2x6s..this would help keep the tracking of dirt out of it too!
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 04-17-2006, 10:52 AM   #4 (permalink)
I talso depends on the brand of 5'r, Tehra re as many different pin box hights as there are mfgr's. our wildcat has another 3 inches of lift in the leaf sprng shackles before considering flipping the axels. We have a 4x2 with a 6" lift and the rig is nose down at the lowest setting.
All things in Moderation accept ACCELERATION!!!!
Zip ties... the duct tape of the new milenia!
truckosaurus
2001 F250 Crew, 25,000+ miles, PSD, 4X2, ProComp 6" lift, Short Bed, SCMT, Tymar set up, BTM, ISSPRO Pyro, boost, and Trans Gauges, in tank mods and harpooned, 28" air horn w/ on board air and tank also full set of train horns! 6 gallons of 150 PSI air. Prodigy, Draw tite Signature series 18K 5'r hitch. TTM
2005 wildcat 29RLBS 5'r, parallel EU2000i's
2003 Explorer, EddieBower, V8 4X4
2003 Explorer XLT, V8 4X4
2002 XR50
2001 PW50
taxgod4u is offline
Old 04-17-2006, 03:38 PM   #5 (permalink)
My truck is lifted 4" on 35's and I tow a 37' Weekend Warrior 5er with it. Instead of flipping the axles (which I think sits too high) I had them build it with a 2" spacer between the spring perches and the frame.... the trailer sits absolutely perfect with this combination.
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 04-19-2006, 06:47 PM   #6 (permalink)
jetskier's Avatar
My Photos: (23)
I'm with taxgod4u, you might want to look at the Wildcat's by Forest River. You can order them online through a couple wholesale-type dealers. I picked mine up a few weeks ago and with my truck's stock suspension, the trailer was nose down 3". The trailer has adjustable hanger mounts. I upgraded to 16" wheels with 235/80R16 tires adding another couple inches over the 15" wheels. It is setup from the factory with the highest holes in the hanger bracket. This is the lowest the trailer can be set. If you move the springs to the lowest mount holes, it gives you another 2-1/2" to 3" of lift on the trailer. With my truck, I had to move the pin box down and raise the hitch to the highest setting to eat up the 3". It now sits nearly level and has about 8-9" of clearance at the bedrails. Most 5th wheels I've seen are always nose high. This trailer is different. If I lifted my truck, the trailer would be easy to level out the way it is setup.
2000 F350 XLT 4x4 CC LB SRW, PSD, 4R100, MSOF, 3.73 TrueTrac, OTC, wired keypad, AIC, DRL, Gauges, DP F6 Live Tuned, Ford AIS w/ sleeve & Zoodad, ATS housing, 31-row trans cooler, HPX line, Magnaflow & BrakeSmart.
jetskier is offline
Old 04-25-2006, 08:17 PM   #7 (permalink)
You should be fine with a 4" lift or less. I have a friend that used to pull a gooseneck stock trailer with a 12" lift and 40's, he just put it on the receiver hitch lol.
2001 F-250 4x4 PSD CC Longbed, 6-Speed, Custom 4" Dual Side Exit Straight Exhaust, Custom 4" Intake Kit w/ AFE Filter & Battery Relocation, DP Tuner 80hp econo PCM Flash, ISSPRO Overhead Gauges, Dieselsite Blow Off Valve, Wastegate Disconnected, CCV Routed to Exhaust, Zoodad Mod, 5" Lift, 36" Radial IROKs, Warn Premium Hubs, Red Head Steering Gear, Cowl Induction Hood, Warn M8000 Winch, Onboard Compressed Air System, 2006 Harley Davidson Headlights / LUKS Bulbs /Upgraded Harness , Boston Acoustics SX60 6.5" Component Speakers, Boston Acoustics GT-40 Amplifier, Boston Acoustics G5 10" Subwoofer, Boston Acoustics GT-22 Amplifier, Kenwood Excelon X689 Head Unit, Kenwood Music Keg, XM Radio.
http://community.webshots.com/user/big_green_diesel
gatorgrizz27 is offline
Old 04-25-2006, 11:37 PM   #8 (permalink)
see here
sandjunkie is offline
Old 04-26-2006, 10:16 AM   #9 (permalink)
I have a 38' Rampage toybox 5er and pull it with the truck in my sig. That being said I have the axel's flipped, 2" lift and the springs set on the bottom hole on the Jake plate. I don't really recommend this set up for everyone and if you haven't towed alot before. I have around 9 inches of bed rail clearace, which is nice but you really only need 6 or 7. I will be moving my springs up on the Jake plate and lowering the unit 2" soon. I just didn't want to drive up to my new trailer and not be able to get under it. 02.
2005 F-350, 6.0 PSD, Lariat,4x4,CC,LB,Torqshift,7" ProComp StageII Lift, MX-6 Reservoir 6 Way Adjustable Shocks, 37" Toyo MT's, 18" Mazzi Hulk Wheels, Duel Steering Stabilizers, 6 Piece Billet Grille, Isspro 3 Guage A-Pillar, AFE SS 4" Turbo Back Exhaust, 4:56's, Firestone Air Bags, SCT by ID, ARP's Studs, WC Motorsports Track Bar, Plates that read SndYaht
desertsands is offline
Old 04-26-2006, 01:26 PM   #10 (permalink)
Towing what is in my sig for 2yrs. No issues. They should be able tell you if a particular 5er is made with the understanding that it will be towed by a lifted 4x4 or not.
Edmguy
2000 F-250PSD,White,Crew Cab,Shorty,4X4,6 Speed,Luk Clutch,3.73Ls,DP-Tuner F-5 with 16prgms,Tymar Intake,Non-Wastegated Van Turbo w/ATS housing & Stock Wheel,4in Exhaust From Turbo,Zoodad,CCV Mod,ITP SS HPX Line,AIH Delete,ITP Regulated Over-Boost Eliminator,Autometer x3,Fabtech 4inch Lift,Bilstein 5100's,Eagle Alloys 16x8 w/Pro-Comp All-Terrain 35's,Powerslots w/Hawk Pads,Valley 16k Slider 5th-Wheel Hitch,$30 Custom Grille,100,000miles
325hp/721tq 4/06 on Dunbar's Rollers
Towed Item :2004 Cedar Creek 36'BB2S Bunkhouse Fifth-Wheel (12,500lbs)
<font color="blue">My Truck & Fiver :</font>
Click Here
Spare Time Activities:MHFR
<font color="red">Can You Keep Up?</font>
edmguy69 is offline
Old 04-26-2006, 03:54 PM   #11 (permalink)
I pull a 29.5T artic fox 5th wheel with truck listed below,6" blocks in rear oru kit on front rig is almost level.If you look around you can find most of the newer ones set up off the ground quite a bit. [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2006 GMC DURAMAX/6 SPEED ALLISION/CREW CAB
4" TUFF COUNTRY KIT,12.50-33-18 TOYO OPEN COUNTRY ON POLISHED MHT WHEELS,MBRP DUALS,COBALT GAUGES,EDGE EVO.TUNER,AFE INTAKE & MORE.
OTHER RIG 97 F350 Literally "SMOKED" by swamps
warrenrh is offline
Old 04-26-2006, 04:36 PM   #12 (permalink)
ChevDog1's Avatar
I used to have a 6" lift and 37's when I first started pulling my 5er. Had to lift the trailer quite a bit - but towed just fine.
2000 F-250 CC SB Lariat - Island Blue
Edge 2" mini-spring 35x12.5x17 Toyo MT's
Zoodad, 4"/5" Exhaust(Straight-Piped), Remote Mount CB, Drop in K&N, Tony Wildman 4 Position Chip, Wicked Wheel, Boost Regulator, Acetoned Badges, Silverstar 9007's, Bushwacker Flares, Triplelock TC, SP TC Lock Controller, Built Trans...
ChevDog1 is offline
Old 04-26-2006, 08:53 PM   #13 (permalink)
sandjunkie are yu usinn air bags in the rear? ive been thinkinn about gettinn some.
2002 f350 crew cab short box 3inch tuff country level kit 315 toyo mudd terrains on 8 inch nitto rims afe stage11 intake with pre filter window tint leer canopy auto meter quages . 4 inch mbrp exhaust. superchips 1805 tuner. towinn our 2004 27 ts komfort tt.
http://community.webshots.com/user/rws444psd
rws444psd is offline
Old 04-27-2006, 12:50 PM   #14 (permalink)
No, I thought about getting some. The sag in the rear isn't really severe enough to warrant them. The handling is fine and I have experience no adverse affects from the small amount of sag. The truck rides so good empty or full now that I don't want to screw with it.
