I lifted my truck 6" with 37" tires this winter and I'm trying to figure out how I'm going to tow my 6 x 12 enclosed trailer come riding season.
Completely stock, I used a 4" drop hitch to keep my trailer level. With the change in lift and tire size, I estimate my truck is now 8.75" higher. That would mean I need a 12.75" drop hitch! [img]/ubbthreads/images/graemlins/eek.gif[/img] I have not seen any out there longer than 9". Does anyone make a 13" drop hitch that will hold at least 4,000/400? Or do I need to start looking for a custom fabricator?
2005 Black/Tan F250 Lariat PSD CC SB FX4, 6" Skyjacker lift, 37" Toyo MTs on chrome 18" AR Trax 8s, Edge Juice Platinum w/ Attitude, AFE stage II PG 7, 4" MBRP SS turbo back Cool Duals, Line-X. 26,000 miles...
2005 35th Anniversary 350Z, Bone Stock.
The bikes: 06' GSXR 1000, 04' GSXR 750 track bike, 04' R1 modded out, 04' Duc 999s, 03' Fat Boy
I did see one the other day that was more than 10". It was at a local 4x4 shop... I have a 10" aluminum drop hitch for my truck and it works great. I know they are out there...you might find it on ebay.
good luck,
Steven
01 F350 CC LB 4x4 SRW,(w/forged rods), 6" Lift, 37"ToyoMT, 22"MKW M19's, Mini Mes, GTP38R, BTS Chip, Spearco, Headstuds, 910 Springs, 4" exhaust, Coolingmist Water Injection, BTS Tranny, 6.0 Trans cooler, 05' Conv. w/ Mirrors, AFE2, Truspeed, Isspro Guages, ORU Diff Covers, Hella 500s, Transfer Tank, ITP Boost fooler, AMP powerstep, Heat Extractor Hood, custom paint, billet badges, Train horns, Recon lights, strobes!
4/8/08 402hp, 824 ft-lbs Mustang Dyno
8/2/08 14.39 in the 1/4 @ 93.5mph on 37's @ 8950 lbs
There are some cheap looking 12" and 14" drop hitches for sale on ebay with 500TW/5,000GTW. But that's hard to believe considering their 2" drop hitches carry the same max 500TW/5,000GTW. Does this sound right?
I have a B&W 10" drop hitch with the 2" and 2 5/16th" balls on it. Rated at 10k...works great! I have a 18ft heavy equipment trailer that sits perfect on it.
Hmmm, don't know where my sig went, but I am running a 7" lift with 37's
2007 F350 White King Ranch Crew Cab 4x4
7" EDGE 4 Link Suspension, Fox Remote Reservoir Racing Shocks all the way around with Duals up Front, and Dual Steering Stabilizer. 37" Toyo MT's on 20" wheels.
Fully polished MBRP T304 turbo back exhaust finshed off with a 6" x 18" tip from ITP Diesel...Thanks Dennis!
Future mods, DePricol White Faced Gauges and a 24 volt inverter and power supply mounted in the bed,
I don't have as big of a lift as you, but I fabricated 4" spacers between my frame and receiver hitch. I actually cut some very thick-walled square steel tubing the length of the receiver hitch and drilled the mounting holes to match the receiver hitch. Used some longer expensive bolts from the local Cat dealership.
I actually did this to drop the receiver hitch below my dropped bumper, I just didn't trust that thing with my heavy loads, but if you did it, it would get you 4" closer to where you need to be.
'99 F250 PSD 4wd CC LWB, 262K Hard Miles!!!
Never been in the shop in it's life!!!
I just fabricated 1 1/2" lift blocks for my trailer. I needed to get some tire clearance in the fender wells. I used three pieces of 1/2" flat bar 2" wide. Drilled a 5/8" hole in two pieces, welded a 1" piece if 5/8" round bar in the hole flush with one side. Placed the piece with no holes in the center. Welded up the sides of the three pieces. Ground the sides flat and made notches for the U bolts because the springs are 1 3/4" inch wide. Metal was $36 to buy, the U bolts were $114(WOW!!!!), Custom made because of the length required.
Back to your question, YES,, above is one way to lift your trailer. I did it yesterday. Installing the 4" lift on the truck starting today...
__________________ My Truck: Early '99 F350 CC LWB 4X4
Annoy A Liberal
Work Hard, Succeed, Live Happy!
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
