Old 06-10-2008, 06:59 PM   #1 (permalink)
Attention Crew Cab Sleeper Owners!
The Feds deemed the CCS conversion NOT a compliant sleeper!!! Here is
an email from them. Please pass this info along to any towing websites,
lets try to prevent any of our friends and other haulers from getting
put out of service and being fined!
From: Tyson Labbe [mailtoabbeheavyindustries@hotmail.com]
Sent: Tuesday, June 10, 2008 10:39 AM
To: xxxxxxxx
Subject: RE: Written Consent
This just in:
The US Federal Department of transport has inspected a Crew Cab Sleeper
at the Dually Depot. in Elkahart In. yesterday. The officers involved
stated that they like the product and what it is designed to do for
drivers. However they have to enforce the law as it is written. They
determined that by the wording of the federal document 393.76 that our
sleeper kits do not qualify as legal sleeper berths.
At this time there are a lot of regional and state offices still
allowing the use of these kits. This may change depending on what paper
work is filed federally. Now we have more work to do.
We will be lobbying governments on both sides of the border to allow
the use of this type of kit. The apperent problem is the reduction of
dimensions in the window insert area. Because we do not maintain 24"
vertically and 24" horizontally. There is very little any one can do
about this based on the size of the vehicles structural door openings.
If you or anyone you know of in this industry is serious about getting
the government to allow this type of sleeper berth for current or
future use we have to get moving on it now.
If you know of a contact in the government or a lobby group etc. that
may be of use, please let us know. We will be fighting to get the
wording changed on the sleeper berth document. Perhaps even an annual
operators permit could be devised to allow one ton operators to use
this type of sleeper berth. We will keep you updated as things progress.
Please let me know if you have recieved this email and any further information would always be helpfull.
Tyson L'Abbe
LABBE HEAVY INDUSTRIES
306-260-5457
2007 Dodge Mega Cab Dually
5.9, G56 6 speed, 2wd
Retired
2006 Dmax
2006dmax is offline
Old 09-04-2008, 04:48 PM   #2 (permalink)
powerdome's Avatar
https://www.woodhouse.com/store/sleeper_berth.htm
Woodhouse Sleeper Berth (Patent Pending)
• • • DOT Compliant • • •
Finally, a low cost DOT Compliant sleeper berth exclusively for 1-ton pickup haulers. The Woodhouse Sleeper Berth eliminates driver's concerns over DOT sleeping requirements and keeps drivers on the road with a better nights sleep.
Details
• Available for 2003 and newer Dodge Quad Cab 1-ton trucks
• Available for 2006 and newer Dodge Mega Cab 1-ton trucks
• Available for 1999 and newer Ford F350 Crew Cab 1-ton trucks
• Only Sleeper Berth available without modifying the vehicle frame or cab
• No outside appearance changes
• Vehicle can be restored back to original configuration and appearance in hours
• One year component failure replacement warranty
• The perfect legal solution for the Hot Shot Operator
• Can be converted into existing vehicle or
financed into a New/Used Vehicle Purchase
• Eliminates costly motel charges
• Eliminates DOT violations
Specifications
• Compliant w/ DOT Regulation 49 CFR 393.76
• Innerspring Mattress measures 76" x 26" x 6" (DOT requires at least 75"x 24")
• Restraint system tested and exceeds the required 6,000 lb restraint Pull-Test
Restraint system manufactured exclusively for the Woodhouse Sleeper Berth by Indiana Mills and Manufacturing, Inc., an industry leader in cargo harness restraint systems.
How to get one?
Call or email Jeff Mabry or Ron Blankenship. This conversion can be installed in less than one day by our professional staff at the Woodhouse Truck Center, your centrally located 1-ton diesel experts.
2001 PSD, CCSB 4x4, 4R100, Precision Industries 1900stall TC,ISSPRO pyro-tranny-boost, Detroil Locker in rear, 35"pro-comp xterrains, 4" turbo-back to 6" stacks, Roll-bar, "Wreckers Special" light-bar, Dual In-Dash DVD, Polk Audio Door Speakers, 1200 watt Rockford Amp, 2 10" JL w1, Midland CB
powerdome is offline
Old 09-04-2008, 08:26 PM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
That has been debated before. Too bad they need to do things like that. We have a 00 and a 06 crew that we sleep in all the time. DOT never questions it. If they were to ever ask if you slept there just say no.
You do not have to prove where you rested, only that you did.
MarkEkberg is offline
Old 09-06-2008, 10:47 AM   #4 (permalink)
fastzr1's Avatar
Where did the passenger seat go?
Ed
04' F250 C/C, SWB, 6.0L, 4x4, True Blue/Silver
ISSPRO Gauges, Firestone Air Bags, LEER Cap, Super Liner Spray In
I love my truck.
fastzr1 is offline
