Old 08-06-2008, 04:50 PM   #1 (permalink)
aux. brake controller
had a brake controller installed on my '00 F-250 yesterday, everything plugged into factory harnesses.... installer said it worked at first but lights were flickering when brakes were applied and when he connected the trailer it went out & never came back. He started troubleshooting and discovered my engine shutdown timer which is tied into my brake as a security feature and said nothing was wrong with the brake controller, it had to be my "extra stuff under there" that was causing it not to work and he wasn't fooling with it.
So.... now it's up to me to figure out how to get this thing to work in conjunction with the EST... but right now brake controller doesn't even have power to it and I can't find any blown fuses anywhere. Does anybody know where the factory brake controller harness gets it's power from or what fuses I may be over-looking?
2000 F-250 Lariat PSD 4X4 Auto CC SB 204,000 miles, 2" leveling kit/315's
Tymar intake, 4" turbo back MBRP exhaust, AIH delete, AC mod, ISSPRO gauges, 5 position DP tuner, Monsterbox Tranny, Tru-Cool Max
bmcnabb02 is offline
Old 08-06-2008, 05:20 PM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
I would ask a moderator to move this to the towing forum. You will find alot more towing pro's there.
haul_n_horses2 is offline
Old 08-06-2008, 05:21 PM   #3 (permalink)
Fever's Avatar
My Photos: (9)
Send a message via ICQ to Fever
under the hood on your year if i recall, but, may want to make sure the pigtail is wired right...the colors DO NOT MATCH from the controller wires to the pigtail that connects under your dash...
2002 F-250 Super Duty Super Cab Short Box 4x4
7.3L PSD, 4R100 Automatic, 3.73 LSD Gears,
BTS Valve Body Kit, Tymar Intake, Muffler Delete,
DP Tuner F-5 (60T/80E/120R/Hi-Idle),
ISSPro A-Pilar Guages (Pyro/Boost/Trans Temp),
Powerslot Cryo Rotors/Hawk LTS pads,
285/75-16 Yokohama GeoLander A/T II Tires,
Tekonsha Prodigy Brake Controller
2006 Sunset Creek 269BH Travel Trailer
Fever is offline
Old 08-06-2008, 05:24 PM   #4 (permalink)
sorry if I put it in the wrong forum, I'll post up there too. Please move/delete as necessary mods.
Old 08-06-2008, 09:39 PM   #5 (permalink)
found online owner's manual by searching here and found where the fuse was supposed to be.... no fuse. Apparently the EST does back feed some voltage to the brake controller which was the "flickering" the installer saw... but it was never even powered up to begin with that's why it "completely went out" when he hooked the trailer up. Everything seems to be working now.... I knew I should have just did it myself to begin with. lol
Old 08-07-2008, 08:09 AM   #6 (permalink)
SmokeyWren's Avatar
My Photos: (33)
I spent 20 years at Air Force headquarters, as a "headquarters type". I was always amazed at the guys in the field that didn't understand that the answers to their questions are usually in the manual for their functional area. Our constant refrain was RTFM = read the functional manual.
For Y2K model year, the trailer tow pkg was an option. It included a trailer brake wiring kit and some fuses and relays in a sack in the glovebox. But to wire up the trailer brakes and trailer plug, you had to install those relays and fuses. It sounds like either your truck didn't have the trailer towing pkg, or else no one ever installed it.
SmokeyWren is online now
Old 08-07-2008, 12:06 PM   #7 (permalink)
it's there now.... and it'll lock 'em up on the 32' deck over dual tandem gooseneck I just bought. lol
thanks
Old 08-07-2008, 09:45 PM   #8 (permalink)
westvandude's Avatar
Glad you got it working.
I installed a Tekonsha Primus brake controller a month ago. Of course, it does nothing without a trailer hooked up. (no lights, etc)
Next week I'm towing a 26' car hauler. Hope it works like it's supposed to!
2001 F250 4x4 crew lariat 7.3L auto, clear corners & taillights, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, PI Stallion converter, modded valve body, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Walker 21470 BTM muffler, dieselsite boots & coolant filter & HX crossover, Fleetguard LF9027 or LF3630 hi-cap oil filter, Rotella T 15w40, DIY Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck.
westvandude is offline
