Auxiliary Tank Install - It is great !! - Diesel Forum - TheDieselStop.com
Old 09-29-2009, 07:24 PM   #1 (permalink)
DRDON's Avatar
I just installed a 45 gallon, under cover, tank and it is fantastic. Total capacity now 83 gallons. I will no longer be held hostage by the fuel gauge. I can pick and choose where I get fuel. Do not have to worry whether or not my 5th wheel will fit under the gas station roof.
The tank is an ATTA (Aluminum Tank & Truck Accessories) diamond plate tank, L-shaped, that fits under the cannister for the Retrax cover. I mounted the pump behind the tank, in the bed, to keep it out of the weather, etc. Simple install, just put a T into the factory return line and then tapped into the factory sending unit wire. When the factory tank gets to half full the auxiliary tank pump comes on and pumps into the factory tank. You always have true reading on the factory fuel gauge and the miles to empty reading is accurate. Really cool. I mounted the fuel gauge for the auxiliary tank under the dash. You always know how much fuel you have.
I did put a few pictures into my Webshots. I would recommend to anyone who tows to get an auxiliary tank. Costs a little for a lot of piece of mind.
DRDON
2008 F350 Lariat CC PSD 2WD Auto. 172" Dark Blue Pearl Clearcoat Metallic/Pueblo Gold 5"Chrome CabSteps Camper Pkg. HD Alt. Tow Command Upfitter Switches, 25K Air Safe Hitch, Retrax Cover, Ride Rites, ATTA Auxiliary Tank, Trains Horns, On-Board Air, and more
2007 Ameri-Camp Summit Ridge Reserve 40' 5th wheel trailer, 3/Slides, Mor-ryde IS suspension, disc brakes, dual A/C, theatre system, solid surface counter tops, king bed, bigfoot levelers, 50 AMP service, heated tanks, 17.5 Alcoa Wheels, Michelin Tires and more
MY PICTURES:
http://good-times.webshots.com/album/558384049kmtqSi
DRDON is offline
Old 09-29-2009, 08:26 PM   #2 (permalink)
Nice job on the install, looks good. How much did the whole thing run? Been looking at either getting the replacement tank under the bed or going with something like this.
Steve
2001 Ford F-350 drw 4x2 auto,4.10 gears,Turbonetics ball bearing turbo, Turbo Master Wastegate controller, Dieselsite Boots, ceramic coated up-pipes and exaust manifolds, DIY Tymar, 4 inch exaust turbo to tip, Isspro guages EGT,Boost, Trans temp from DieselManor, 6.0 trans cooler, AIH delete with boost attachment, ITP Regulated Fuel Return kit,hutch and harpoon mod done, ITP in tank and prepump mod kit, Rotella ELC, 203 Stat. Oil Guard by-pass filter system
DP Tuner-no start, stock,40,60,80E,120
BTS Transmission,(BTS-BUBBA)
105,000 miles, built to tow
Toys: 03 Screaming Eagle Duece Harley
37ft Cyclone by Heartland 5th wheel toy hauler
ford4me2 is offline
Old 09-29-2009, 08:43 PM   #3 (permalink)
TonkaThunder's Avatar
My Photos: (6)
I second the interest
03 F-350 DRW Lariat 7.3,4x4 6-Speed, 4.10Gears , 4 inch ProComp lift, BFG AT LT315/75R16, 3 in. spacer between duals.
GT38R 1.0 Housing
Banks Monster Exhaust, w/Turbo Elbow, AFE Stage 2 Cold Air Kit, South Bend Stage 2 Clutch and Cyro'ed Flywheel
DP 80econ -Stuck there for now because someone stole my SCT box
2 Optima Red Tops
Auto Meter Boost and Pyro Gauges
8,200lbs---Cat Scale---Thats me and and 38 Gallons of Diesel
1987 Mustang GT Cobra Clone- crate motor, cage and more suspension than I know what to do with
Loves to run down Vettes and Vipers on the road course
34 Ft Kaufman Solid Deck 2-Car Hauler
TonkaThunder is offline
Old 09-30-2009, 01:54 AM   #4 (permalink)
BlueMuleTrucking's Avatar
Send a message via AIM to BlueMuleTrucking
Nice install. Just wondering where you ran the Coax for the CB Antenna. I have an 03 and looking to do bed mounted CB Antennas.
Evan-
2003 Ford F-350 Crew Cab L/B/Dually XLT FX4 7.3L/Auto- Gooseneck Hitch Fifth Wheel Rails, Firestone Air Bags/ Toolbox
BlueMuleTrucking is offline
Old 09-30-2009, 07:30 AM   #5 (permalink)
DRDON's Avatar
BlueMuleTrucking
Thanks. I ran the coax down the stake pocket into the bed then went through the rubber grommet in the bed and then the rubber grommet in the cab. I then went under the carpet, under the driver seat and then out by the CB Radio. You will have to take off the plastic piece (whatever it is called) next to the driver seat that hold down the carpet.
Have fun. Thanks,
DRDON
MY PICTURES:
DRDON is offline
Old 09-30-2009, 07:34 AM   #6 (permalink)
DRDON's Avatar
Thanks. Forgot the costs. Sorry about that. The tank cost $1050 with everything I mentioned. The killer is the shipping. The company is located in Texas and shipped to my house in Maryland was $400.
The reason I picked an in-bed tank is that when I get a new truck down the road it will be a SuperDuty and there is a good chance that this tank will fit that truck.
Good Luck,
DRDON
MY PICTURES:
DRDON is offline
Old 09-30-2009, 08:38 PM   #7 (permalink)
Originally Posted by DRDON View Post
BlueMuleTrucking
Have fun. Thanks,
DRDON
Thanks. I'll have to go up to the roof since I have a console and that's where the CB is mounted. Wheres the grommet for the cab?
Evan-
Old 09-30-2009, 11:11 PM   #8 (permalink)
fulltimer50's Avatar
My Photos: (16)
So I guess you have loaded up with fuel and your hitch and everything else you have on board when you tow your trailer and gotten the whole thing weighed?
George
6/2011 F350 PSD Lariate, CC, 4x4, LB, DRW
06 Newmar Cypress 29KSRE 5th wheel/MorRyde IS, Kodiac Disc Brakes.
fulltimer50 is offline
Old 10-01-2009, 12:04 AM   #9 (permalink)
If interested: 2009 F450 4x4: with 60gal tank/toolbox, B&W/companion hitch, loaded for vacation--10,300lbs. 9450lbs without fuel and running solo. GCW: 27,300.
2009 F450 Lariat 4x4
2007 F350 KR DRW CC 4x4-Gone
2005 Mobile Suites 36TK3
wingnut60 is offline
Old 10-01-2009, 06:56 AM   #10 (permalink)
BLOWINSMOKE99STROKE's Avatar
Blue: if you lay under the truck and look basically under the drivers seat there are rubber grommets there, just poke a hole big enough to fit the wire through, then feed it under the carpet to the pillar and up to the roof. I ran mine the same way the OP did, and it worked great!
EARLY 99 F350, CREW CAB, LONG BED. 4X4 7.3L AUTOMATIC. EDGE JUICE W/ ATTITUDE. 4" EXHAUST, NO MUFFLER, 6" TIP, COLD AIR INTAKE, BD: CCV KIT (WON ONLINE, THANK YOU BD). DVD PLAYER, PS2, IN DASH TV, POWER INVERTER, 2-10" INFINITY SUBS IN PORTED BOX. CLASS 5 REESE TOW PACKAGE, FLIP UP GOSENECK HITCH. CB/PA, WITH DUAL TRUCKER WHIPS. TOW MIRRORS, AND CAB LIGHTS, RECON LED TAILGATEBAR W/ REVERSE LIGHT, BUG GUARD AND WINDOW VISORS. 05 GRILL AND HEADLIGHT SWAP, 08 TAILGATE, 285/75 BFG ALL-TERRAINS, SHACKLE LEVELING KIT, AND BILSTIEN SHOCKS. 5% TINT ALL THE WAY AROUND, AND 50% ON THE WINDSHEILD.
SOON TO COME: 08 TAIL LIGHTS, CLEAR CABLIGHTS, RECON ESCALADE STYLE 3RD BRAKE LIGHT, STROBE LIGHTS, PROJECTOR BACKUP LIGHTS, 33X12.50 BFG ALL TERRAINS ON BLACK DICK CEPEK 17" RIMS, EDGE EVOLUTION PROGRAMMER (STACKED), RAPTOR HIGH PERFORMANCE FUEL PUMP, HIGH PERFORMANCE HPOP, POSSIBLY 10" STACKS!
BLOWINSMOKE99STROKE is offline
Old 10-01-2009, 04:34 PM   #11 (permalink)
Thanks Blowin. I think I'm going to wait till spring for this one.
Evan-
Old 10-11-2009, 09:18 PM   #12 (permalink)
Send a message via AIM to Jerryc
Just one question. When you buy a new tank like that, does a new butt come with it? My butt won't last as long as my standard 38 gal tank as it is.
JC
F-450, 4wd, club cab, 4.88, KR, satellite, navigation, hi-capacity trailer towing, reverse sensor, memory mirrors/pedals/seats and tailgate step. Also Linex, TruckCoverUSA bed cover, CrimeStopper Remote Start and Alarm and a 25K Air Safe Air Ride 5er hitch. Also Banks with IQ.
Jerryc is offline
Old 10-12-2009, 07:26 AM   #13 (permalink)
I've got a 91-gallon RDS aluminum tank for my 96 for $500 from Northern Tools. I use it to refuel a diesel tractor and RTV in the field, so I installed a pump and nozzle for that, and refuel the F250 that way too.
Relative to butt behavior, I like to rest it in rest areas and not running around truck stops dodging cars and etc. It sure is nice being able to pick your refueling stop every few days while on the road rather than every day.
MichaelPatrick is offline
