My thoughts exactly, poor design. Those things should be engineered to take more then that. I think the guy that hit it won't be the only one in trouble, engineer/designer should have some heat on them as well.
no the clearence bar you go under beforehand is supposed to remove liability form the engineer of the structure in this case
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
<span style="color: red">i have created a website for old ford diesels please check it out and tell me what you think</span> http://oldforddiesels.googlepages.com/home
no he just drove around cant you see how far out he is ?
they are only for one lane they also have another lane for ppl working on the building or the power company anyone who needs a service truck in there
he took that one lol
wait its all his fault (most banks do this) he crossed the yellow line!!! (ive seen them mostly yellow )
I just got done camping with my slide-in. On top of it I have a good size saw horse to help support the camper so I am 13'3" high.
I really pay attention to fuel stop heights.
1996 F-250 extended cab long box five speed. Home made Tymar, 203 Stat, 60 gal in bed fuel cell, 315/75's, no cat, no muffler, ebpv welded open 3" to 3" DP, Babies. 255K, still chugging, and still smoking when cold.
IMO, anyone driving a "tall" set up should be aware of overhead obstructions - even if there is no clearance bar.
yup, last year I started to pull into a hotel with a Penske truck. As I stopped the guy came out screaming. It turns out someone had run into the over hang the day before and he just had it repaired....he was a little wound up.....
1994 F350 XL Crewcab 4x4 SRW 7.3 NA
Dana 60 Sterling 10.25 3.55 285/75 16 Dayton Timberlines
TC lockup Mod
Pyro Installed!!!
TO DO: Boost guage, Tekonsha Voyager Brake controller and Turbo when I acquire one!!!
