I got my B&W 1108R in the mail today, and was wanting to know some tips and tricks for the install. I sure hope they will work with my firestone air bags (2330). Maybe some one has some pictures of their install they could send me?
2002 XLT 350 crew cab white
am/fm/cass/cd 4x4 auto
carpet delete 265/75/16 3.73
limited slip 9900lb package
X springs ranchhand bumpers
B&W hitch
Firestone airbags & compressor
Rancho shocks 136K and all stock
Where are you air bags mounted exactly. I've seen some pictures of trucks with air bags and there is no way that the side plate for the B&W will fit around the air bags and honestly I don't think B&W sell one that will fit around air bags. Look at the pictures in the instructions and you'll see where the side plate go, most likely that's where your air bags are installed right now. I just installed the 1108 on my truck and the only pain was getting the pieces which look like angle iron in between my truck bed and frame. My bed must have slightly sagged over time because I had to use a hammer to pound the rear angle piece back into position. If you can get yours to fit just take your time and follow the instructions, it took me about 4 hours to do but I took my time. Plan on doing a lot of crawling under the truck, and make sure to torque you hardware as they say.
My air bags mount inside the frame. They are the no drill ones (2330). I just wanted to know if I would have any problems with the hitch and the airbags.
B&W hitch
I have a turnover ball and the Companion 5'er hitch. I had to use the Ride Rite #2398 when I added airbags. I have the truck below.
Bud
BudMan5
"A couple of quarter sticks of dynamite can turn an otherwise dull day fun!"
2006 F350 Crew Cab 2WD DRW 98 gal Transfer Flow aux tank, Crew Cab Sleeper, Ride Rite Air Bags with Dual Air Command II compressor and tank, B&W Companion 5'er and Gooseneck, Garmin GPS, XM Radio
I spoke with B&W today and they said that 1108 will work with the air bags that mount inside the frame.I'm not sure where the pipe spacers go that come in the kit. Does someone have pictures of their hitch install on their truck?
B&W hitch
1999 Case IH C50
2007 Cougar 302RLS
That's one thing they don't have picture of in the instructions. It goes in between the frame and the side plate at the large hole in the side plate. The side plate, pipe spacer, and frame are all bolted together with the 3/4 inch bolt that is supplied. This gives proper spacing for the side plate to frame because there is a little "curve" to the frame at that point. Hope that explained it.
Well the wife just called me in for dinner so I guess the install will be a two afternoon job. One thing I did not know was how tight the angles are between the frame and bed. They are tight. Doakster was you install the same way?
B&W hitch
1999 Case IH C50
2007 Cougar 302RLS
Doakster, would you have any pictures of the side plates installed on your truck?
I can't remember if the install instructions had a decent photo of the side plats installed or not, probably not, I'll try to get some photos of the hitch installed maybe Saturday.
Well the wife just called me in for dinner so I guess the install will be a to afternoon job. One thing I did not know was how tight the angels are between the frame and bed. They are tight. Doakster was you install the same way?
Yup that was the same on mine to, I could "just slide" the rear angle back into place like they said, I had slide it in place up front across the frame rails and between the bed, and they use a hammer to tap it back a little one side at a time so it went back evenly. It was just tight between the frame and the bed, this was probably because the bed sagged a little over time as things were loaded on it, it was kind of a pain to get back there but it will go.
