Old 01-25-2008, 09:32 AM   #1 (permalink)
Ballpark towing specs
I have a 88 F350 Crew Cab 7.3 Diesel with 5 speed manual transmission. I have a gooseneck hitch and regular Class IV hitch. I'm looking for info on max weight I can tow.
tjfisher55 is offline
Old 01-25-2008, 10:37 AM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I would venture a estimate of 10-12K. You will not be going fast with that weight, but it should do it in fine fasion.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 01-25-2008, 11:59 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (42)
My specs don't go back that far, but probably the max GCWR you would have is 16,000 pounds. That requires a 4.10 rear axle with the diesel engine, and also assumes you have stock-size tires.
So if your GCWR is 16,000 pounds, then weigh the wet and loaded truck and subtract that weight from 16,000. The answer is the max weight of any trailer you should tie onto.
Typical wet and loaded truck weight would be 7,500 pounds before you tie onto the trailer. That would leave 8,500 pounds as the heaviest loaded trailer you should attempt to tow.
Sure, that diesel engine will pull more weight than the GCWR would allow, but you'll be pulling the guts out of your tow vehicle.
If I had the GCWR I would know better what your max trailer weight should be. I suspect with the manual tranny your GCWR was less than 16,000 pounds. With the 3.55 rear end, it was only 12,000 pounds, but I suspect the 3.55 rear end was available only on F-250 diesels.
Asking questions about working a 20-year-old pickup hard indicates that the Ford diesel pickups were an excellent buy 20 years ago.
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; Ford Severe Duty Air Induction System (AIS); 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and Turbo Temp Monitor (TTM); Auxiliary Idle Controller (AIC); SP-Diesel exhaust brake and torque converter controller. Top Job front end replacement. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is offline
Old 01-25-2008, 12:31 PM   #4 (permalink)
suv7734's Avatar
Here re the pages straight from the 1988 F-series owners manual:
For every action there is an equal and opposite malfunction
1988 F350 CC 4x4 SRW, 7.3 Banks non-wastegated turbo, C6 w/ HD torque converter, Tru-Cool 4590 trans cooler, Highjacker 'softride' 4" lift, pre/post luber, coolant filter, Racor fuel filter/separator, pyro and boost gauges, Progressive 16x8 wheels, 285-75x16 rubber, 3" downpipe into 4" straight pipe over the rear axle and into 5" SS tip. 1994 Alpenlite 33' 5th wheel trailer
suv7734 is offline
Old 01-25-2008, 12:44 PM   #5 (permalink)
Got it. Thanks. Now, I need to figure out what rear end I have.....
Old 01-25-2008, 05:00 PM   #6 (permalink)
SmokeyWren's Avatar
My Photos: (42)
The specs suv7734 posted says you have 14,000 GCWR and 9,000 max trailer weight and a max of 60 sq ft frontal area if you have a 4.10 rear axle ratio. But take that max trailer weight with a grain of salt, because it assumes your wet and loaded tow vehicle weighs only 5,000 pounds. And we know it weighs a lot more than that.
Similar Threads
Towing specs tjfisher55 7.3L IDI Diesels (Not Power Strokes) 4 01-24-2008 11:53 PM
Need tech specs - torque specs on brake line stuckinthemud 6.0L Power Stroke Engine and Drivetrain 3 10-06-2006 03:32 PM
Ballpark for a lift kit saintdog Upgrades and Aftermarket - General 26 03-14-2006 03:22 PM
A/C specs zekex2 6.9L Diesels 8 07-20-2005 08:24 PM
