11-06-2007, 10:09 AM
#1 (permalink )
Best choices for brake controller for 97' 250 pulling toy hauler?
Looking into buying a new 5th wheel toyhauler and wondering what are the best choices out there now for brake controllers?
97' F250 4x4 crew cab. 4:10 gears,High Idle mod, Dana 60 conversion using 3"SKY RSK w/03' SD springs and 3 3/4" rear blocks to level. Tymar, Issopro gauges on 3 gauge pod, 3" down pipe, shimmed FPR and DP tuner 6 pos. chip (12-13-07).
http://community.webshots.com/user/amberjax
11-06-2007, 11:29 AM
#2 (permalink )
Re: Best choices for brake controller for 97' 250 pulling toy hauler?
Tekonsha Prodigy.
Bob
Retired: UAW 383 12.01.03 after 32 years at BENDIX, Allied, AlliedSignal, BOSCH, St Joseph MI Plant
99.5 F-250 CC SRW: Automatic, 3:73 Gears, Tymar Intake, SpeedLiner Bed Coating, Timbren Rubber Springs, Hayden Trans Cooler, Perma Cool Trans Filter, Sonnax Valve & Tricumulator Springs, Reese 15,000lb 5th Wheel Hitch, Tekonsha Prodigy Trailer Brake Controller, Handy Flow Thru T-gate, AFE 4" Exhaust, Warn Hubs, SP Diesel EB, GOS Headlight Harness, Smoked Headlights & Corners with Sylvania Silverstar ULTRA SU bulbs, 08 Sterling Alum Diff Cover, Delphi XM Radio, TomTom One XL-S GPS with ProClip mount
DIESELSITE Stuff: Super Chip 1705 Programmer, AutoMeter Lunar Gauges In Under The Cubby Hole Mount, AC Control Valve, AIH Plug, Coolant filter, Wicked Wheel, BilletTstat Housing, 203 degree Tstat & HX cross over hose..
11-06-2007, 02:54 PM
#3 (permalink )
We use Draw-Tite Digitals on all our trucks. With a Lifetime Warranty, if there is a hint of a problem, traveling anywhere in the country, any retail location will swap 'em out, no receipts, no questions.
2005 Chev Duramax/Allison 3500LS DRW Crew Cab
B&W 30K-Turnover GN, Putnam XDR 15K, A/T Revos
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 9'Flat-GN
A/T Revos
DON'T STEAL! The Government Hates Competition
11-06-2007, 04:10 PM
#4 (permalink )
I have a Hayes Genesis and it works pretty well and the price is reasonable for what it is.Check out
http://www.brakecontroller.com
2001 F350,XLT,CC,4x4,PSD,6-SPD,SRW,156"WB,OFF-ROAD,LS,PTTTM,AIC,HAYES GENESIS BRAKE CONTROLLER,BILSTEIN SHOCKS,BRIDGESTONE DUELER A/T REVOS,POWERSLOT ROTORS AND HAWK LTS PADS,PML REAR DIFF COVER,RHINO LINING,GARMIN STREETPILOT 2720,SIRIUS RADIO,TRUE BLUE
2006 F350,XLT,SC,4x4,6.0L,TORQSHIFT,SRW,142"WB,FX4,LS,E SOF,TOW
COMMAND,UPFITTERS,LINE-X,WEATHERTECH MATS,GARMIN GPS V,DARK GREEN SATIN W/SILVER
11-06-2007, 10:55 PM
#5 (permalink )
easternmarine.com
01 CC,4"lift,315/75-16coppers on ultra star wheels,
NAPA 6637,w/tourqe tube,4"turbo back exhaust,
6.0 trans cooler,CCV mod.,ZooDad.X-wheel,
HP X line,ISSPRO gauges boost,pyro,trans.
Defuser 18k mod.,A/C mod.AIH delete
Linear Mode
» Site Navigation
» Other Sites
» Network Links
