Old 08-24-2007, 09:05 AM   #1 (permalink)
Best load range E tires for hauling around a camper insert
Any thoughts on the best load range E tires for hauling around a camper insert?
The OEM sized tires for my 2003 crew long bed were 235/85RR16 that will handle up to 3,045 lbs. Many of the 265/75RR16 will handle up to 3,400 lbs. Will probably go with the 265s.
What brand has been holding up to this kind of load best?
I'll ask this same question over on NATCOA (National Truck Campers of America) site, and will repost any answers I get there.
2003, F-250, Crew, 6.0L, PSD, 8' bed (stock)
skopje is offline
Old 08-24-2007, 10:30 AM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Re: Best load range E tires for hauling around a camper insert
I would stick with your 235/85R16's and get Michelin XPS Tractions.
haul_n_horses2 is offline
Old 08-24-2007, 01:14 PM   #3 (permalink)
My Photos: (5)
My truck ('01 350 4x4) came with Firestone R4S Steeltrax 265/75-16, I was very happy with them pulling a 12k lbs. trailer and would have no problem replacing them with the new 'stones, Trans-Force AT, they seem to be the next progression in the line, although they did steal a 32nd in the tread depth. Do not know how they would handle the slide in but the weight on the 5th wheel must be all of that. I would also consider what your truck is rated for (250?) why spend the extra coin, let along the increase in unsrung weight of a heavier tire you don't need. Remember you need to spin it and stop it too, fuel economy is more important every day.
Good luck and keep us posted.
'06 Ford F-350 4X4 6.0 Bone stock, crew cab
Sold'01 Ford F-350 4X4 extended cab,
Banks Otto mind chip +90hp(?),
4" Red Deer exhaust,
Banks Transcommand.
Tymar Intake
Pillar mount Auto Meter gages: (EGT/trans-temp/boost)
'08 32' Wildcat QBBS '5er
buelligan is offline
Old 08-24-2007, 03:13 PM   #4 (permalink)
teamroper60's Avatar
You didn't say if you have an SRW or DRW. I know that tire size is standard on the DRW, but it may be on the SRW too, I dunno....
Anyway, recently bought the Michelin XPS Tractions like haul_n_horses2 recommended. I only have about 5k on them so far, but at least 60% of that is towing my 5er. Gotta say, they are working great thus far...
2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, (still running the original flash!), AIC, MBRP turbo-back exhaust, Tuning by Total Diesel Performance, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers. 376hp
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 08-24-2007, 05:06 PM   #5 (permalink)
Truck is SRW.
Why stick with the 235s if the 265s handle 400 lbs more load?
skopje is offline
Old 08-24-2007, 05:59 PM   #6 (permalink)
Truck is SRW.
First of all, it's the size that came on your truck. Changing sizes effectively changes your final drive ratio to something less than what you have, meaning it will seem less "peppy" than it does now.
Secondly, the XPS is a commercial grade tire, so it'll last longer.
Third, the XPS has all steel belts, even in the sidewalls, so it's more puncture resistant, which could be really important with a load on.
pics
#43
Old 08-24-2007, 07:58 PM   #7 (permalink)
what weight slide-in camper??? if its heavy i suggest you go with 3400 pound rated tire....gives you 6800 lbs at the axle which would allow for about a 3600lb wet camper. the f250 at 8800lb gvwr doesn't allow much more than an 1800lb camper to be legal...
basutoland is offline
Old 08-27-2007, 03:30 AM   #8 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: skopje</div><div class="ubbcode-body">Truck is SRW.
Why stick with the 235s if the 265s handle 400 lbs more load? </div></div>
Exactly.......just do it. The 235/85 and 265/75 are virtually the same diameter, and both were the standard size tires that came on the truck. The 265/75 was a factory optional tire size and trucks could be ordered both ways. I also haul a camper, and like you, I want the highest rated tire I can put on the truck.
Sorry, I don't have any brand recomendations. I doubt there's much hard evidence to justify one brand over another.
'96 F250 S/C 4x4 4.10 auto, Tymar intake, 3-4" DP 4" exhaust, Edge Evolution, Hypermax IC, Autometer gauges, Hayden 679 trans cooler, Airlift bags w/compressor and in-cab controller, built trans from KTS, Rancho 9000's, 19.5" rims and tires.
'97 F350 C/C 4x4, 3.55 auto.....just starting to mod
Lance 921 camper, 9.5' w/slide-out
'88 Jeep Cherokee, 4dr pick-up conversion rock crawler, D44/D60, Warns, CTM's, 37's, etc.
rocknxj is offline
Old 08-27-2007, 08:41 AM   #9 (permalink)
My Photos: (17)
Why stick with the 235s if the 265s handle 400 lbs more load? </div></div>Just check out the posts on the XPS tires. I think you will be very secure.
Old 08-27-2007, 11:05 AM   #10 (permalink)
Many camper guys are going to the new 285/75-16LT E rated tires on their superduty SRW trucks.
The rating is 3750 per tire.
I would stick with the 265/75-16LT E rated tires (all rated at 3415 lbs each). They fit better on the rim and give you less SWAY.
What camper do you have? What do you tow when the camper is aboard?
2008 F550 6.4 w/ pickup bed
kehale is offline
Old 08-27-2007, 04:19 PM   #11 (permalink)
I have the stock 265x16 E BF Goodrich ATs on my 2004 and love them. Currently 33000 and they will go at least another 15000 or so. Even with heavy snow across the passes they worked great.
The 2000 came with Firestones and they gave poor traction and wore in less than 25000 miles.
2004 F350 Lariat CC LB FX4 Auto, camper package, superhitch, rear susp air bags, Rancho 9000 shocks, 800W/1600W 115v power converter, Ultralite gauges in overhead 4 gauge pod, 04/04 build and engine Reman shortblock at 34,000 Due to oil leaks, MBRP turbo back, SCT extreme street by ID
10.5' camper, 20.5" Bayliner Cuddy 5.0 V8
1999 Kawasaki ZRX1100
rubystargoats is offline
Old 09-03-2007, 10:23 PM   #12 (permalink)
michlin XPS hand's down,no contest,been there,done that with a slide in before going to the 5th wheel,will run you around $200.00 each mounted and balanced.
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, pulling a 2004 Sunnybrook 31bwks triple slide 5th wheel. , Total Gross 20900#.truck wt empty 7420# all at the scale, born 05/02/02. bought 06/18/02 & the wife's 2007 eddie bower expedtion 5.4,6 speed automatic ,power everything,redfire & tan.
My truck and 5er.
poppie is offline
Old 09-06-2007, 12:06 AM   #13 (permalink)
Michelin XPS is hard to beat. I have run them many miles, check my signature. This is the best tire I have found for stability, mieage, and cost per mile. Every other tire I have used feels squirmy in comparison.
02 F350 Lariat CrewCab Toreador Red/ Silver DRW AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 752,243 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 XLT SC DI DRW 5Speed 314,000
04 Grand Marquis LS sure wish it had a BTS!
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
62 Corvair 95 Bus
HighwayPrisoner is offline
Old 09-06-2007, 09:14 AM   #14 (permalink)
NCHornet's Avatar
Michelin LTX are suppose to be one of the best truck tires out there. I contacted many tire shops and they all said the LTX was the best tire. I used the M/S version.
Kevin L. Mnt Airy, NC.
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 09-06-2007, 10:53 PM   #15 (permalink)
Michelline's for me. I was a die-hard BFG AT fan, (only a few sizes in LR E), but my first set of michellines has changed my mind.
2002 PSD 350 CC 4x4; AIS Intake w/ Fender Sleeve; Walker BTM; ISSPRO Tranny, Boost, Pyro; CCV Mod; Zoodad; Blue CPS(in the glovebox); Powerslot Rotors w/ Hawk Pads; Baldwin Fuel Filter; LineX Bedliner; Southwest Fabricators Rear Bumper; 285 Michelline LTX M/S's; and a cracked windshield.
92 8' Six-Pac Slide in Camper;
94 Charmac 3 Horse Slant Bumper Pull;
25' 1976 Jayco TT;
http://community.webshots.com/user/NVCowboy100
nvcowboy is offline
» Site Navigation
» Home
